it's been ages...
Discussion in 'UK Motorcycles' started by darsy, May 29, 2007.
  1. Not surprising. Those air drums are pretty loud.
    *moshes*
    Antony Gelberg, May 29, 2007
    #41
  2. darsy
    Beav Guest
    Piece of piss fitting them to my Zed.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 29, 2007
    #42
  3. I've come to the conclusion that there simply is not a bike on the
    market that actually fits your requirements. There will always be some
    aspect that falls short.
    If darsy bought either of those it would send ukrm back to the days of
    Doc Gonzo and his Laverda. Can you imagine what would happen if there
    was even a hint of Italian unreliability?
    Paul Corfield, May 29, 2007
    #43
  4. darsy
    On my rather older bike there's a socket on the loom and nearby, a
    plug tied to the loom that goes into the socket. Once mated, this
    enables the diagnostic LED on the instrument panel.
    If yours has a similar setup then have a look at the code: this should
    give a clue.
    They don't remember the errors after the power's off but if yours is
    permanently dead then you ought to get something.
    Pip Luscher, May 29, 2007
    #44
  5. darsy
    Aha, you obviously can't hear me above that racket.
    <bellows>
    I SAID, I'M MORE TEMPTED BY A BREVA!
    </b>
    #45
  6. darsy
    Keef and me say :
    KTM SuperDuke.
    If you say it's outside your budget, then you are insufficiently
    committed. A ride will change your mind. It is quite simply a
    fabulous motorcycle.
    Champ, May 29, 2007
    #46
  7. darsy
    MikeH Guest
    You've fitted them the wrong way round - they should be at the front,
    not replacing the seat.
    MikeH, May 29, 2007
    #47
  8. darsy
    muddy cat Guest
    You've got the money, get one.
    muddy cat, May 29, 2007
    #48
  9. darsy
    Eh? it couldn't be easier
    Hog, May 30, 2007
    #49
  10. darsy
    Dan L Guest
    Okay, let me explain...
    Old bars came off no problem.
    New bars wouldn't fit in old risers without risers being packed "up"
    with washers, as knuckles on ends of centre part of Jotas were bearing
    directly on to top yoke. With washers in place the bars would only fit
    in one position, so much of the adjustability was unusable.
    Had to re-route cabling and hydraulics to suit new bar position, brake
    and clutch lines were a bit bent.
    Found front brake and clutch reservoirs would not fit against first
    joint of Jotas without being somewhat rotated to enable controls /
    grips to go on.
    Found that bars fouled tank on full lock, so had to be pushed out more
    than I wanted.
    Bought new bar risers to raise the Jotas higher so as to alleviate the
    lack of adjustment. Existing risers bolt through from top, new risers
    bolt through from underneath, so off with top yoke.
    Top yoke is threaded as are risers, have to try to get risers to mate
    to yoke without being pushed off due to threading of yoke.
    Used allen headed screws, but had to dremel underside of yoke to enable
    2 of the 4 to screw all the way in. Found son had trashed dremel, so
    had to use dremel attachment in 18V Bosch drill.
    Could have drilled out threading on yoke, but decided not to in case I
    wanted to return the bike to standard.
    I'm not even going to mention the initial adjustment, which looked fine
    on the centre stand, but somewhat lop eared when the bike was upright.
    Since fitting, on 2 occasions the joints have worked loose on the bars.
    Dan L
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 30, 2007
    #50
  11. darsy
    I don't know your Pipex address - drop me an email to this gmail
    account, and I'll get back to you.
    darsy, May 30, 2007
    #51
  12. darsy
    darsy, May 30, 2007
    #52
  13. darsy
    I am insufficiently committed[1].
    Or more accurately, I have a range of other things to which I also
    have commitments.
    I don't have an unlimited supply of cash, and I've spent nearly 18K on
    vehicle purchases already this year.
    [1] motorcycling is strictly a hobby for me these days - I just want
    something for weekend fun and the occasional jaunt to Europe.
    darsy, May 30, 2007
    #53
  14. darsy
    Although the design is fairly old now, I still think the original
    Monster design looks good, unlike say the Bandit, which looks
    decidedly old-hat nowadays.
    The S4 which I'm interested in looks "old fashioned" until you notice
    it's got a 916 motor instead of the old air cooled engine from the SS
    series.
    darsy, May 30, 2007
    #54
  15. darsy
    unfortunately, it's more a case of "we've got the money", which means
    that some of it is assigned to things like a new kitchen and holidays
    and children's educations etc.
    darsy, May 30, 2007
    #55
  16. darsy
    darsy, May 30, 2007
    #56
  17. darsy
    simonk Guest
    As discussed the other evening: the Yamaha MT-series? I like the
    MT03, but it's "only" a 600cc single.
    simonk, May 30, 2007
    #57
  18. darsy
    Champ, May 30, 2007
    #58
  19. darsy
    if I were buying a big single it'd be a supermoto, but I also want
    something to tour on.
    I like the MT-01, but it's out of the price range.
    darsy, May 30, 2007
    #59
  20. darsy
    bad form, second reply - I should point out that my objection to
    singles for touring isn't comfort etc., it's tank range.
    darsy, May 30, 2007
    #60
