It was all going so well, too.
Discussion in 'UK Motorcycles' started by SD, Feb 2, 2007.
  1. SD
    SD Guest
    Took a day off today, to get the Wing back together.
    The new belts went on easily enough, but the tensioner pulleys were a
    bit of a chore, to be honest. Very difficult to line up the bolts with
    the holes, against the tension of the belts, and in between the
    various hoses and cables in the way.
    Still, they're on now. All the "up" marks line up, too - even after
    turning the engine over a couple of times by hand.
    So, onto the clutch.
    Despite having new: plates, spring, slave cylinder, lifter rod, master
    cylinder internals and fluid it was still slipping as bad as ever.
    Diagnosis then pointed at the lifter plate - this is the plate against
    which the lifter rod presses to separate the plates, and it's held to
    the pressure plate by four bolts. When I took it apart two years back,
    one of the bolts was suspiciously easy to undo, and on retightening it
    offered very little resistance to my 10mm ratchet spanner. That'll be
    a stripped thread, then. Presumably done when it had the clutch
    replaced while Pip and I visited the Manchester Museum of Technology.
    Either that, or it's always been duff. It certainly wasn't me,
    yerroner.
    Anyway, I reckoned it was this plate, with it's failing fitting, that
    was being stressed off the perpendicular, that caused the clutch to
    not centre correctly in use. You never know.
    So, a new pressure plate, with intact threads, was acquired, for a
    King's ransom, and I set to with renewed hope.
    First thing that has to come off is the alternator. Platy, look away
    now. This is easy - three shiny 12mm headed bolts.
    Of course, it needs its electrical connections undoing first. So, in
    with a 10mm spanner, and I'm almost blinded by a big spark and a bang.
    As the lights in my eyes begin to fade, I can vaguely discern a big
    white sticker on the frame by the alternator. "Important. Disconnect
    battery before attempting to remove alternator connections." Oops.
    With the battery disconnected, the alternator connections came apart
    without drama. I then set about the three bolts holding the alternator
    to the rear of the motor. The first two undid easily enough, but the
    third seemed a little stiff. Then it didn't, all at once. Happy day -
    it had sheared. Flush with the rear of the threaded hole in which it
    had been inserted.
    All suggestions as to how to remove it gratefully received. No, I
    can't get that piece on the bench to drill it, as it's the lhs of the
    crankcase. It's got Plus Gas on it at the moment.
    Once again, the clutch cover came off without disturbing the gasket.
    Quite odd. I can't find my blue Hylomar anywhere, so it's off to
    Halfords in the he morning.
    The thread on the lifter plate was worse than I remembered, and when
    the bolt was removed, it still had its little plug of JB Weld around
    the thread. I'd put it on the bolt in the same manner that one might
    put an elastoplast on a knife wound - you never know, it might do some
    good.
    The clutch pack was clamped in the vice, circlip removed, all the
    plates swapped to the new pressure plate, and the spring refitted. All
    ready to go back in tomorrow.
    To cap it all, I noticed the rear tyre is down to its wear bars, so
    that's more expense, unless I fancy swapping wheels, and sticking that
    bloody Avon back on.
    Ho hum.
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Feb 2, 2007
  2. SD
    SD Guest
    Considering the clutch has been knackered since the weekend you rode
    it, I reckon it's done quite well. I'm now firmly of the belief that
    it was scuppered by them halfwits in Cheshire. Bit difficult to prove,
    60k miles down the line, though.
    Changing the cambelts at 88000 miles isn't something a Ducati owner
    would be doing for the first time.
    I think "mechanical" is stretching it a bit.
    | ___ Salad Dodger
    SD, Feb 2, 2007
  3. As it happens, I'm in That London (or at least Twickenham) next week. Do
    you want me and my left-handed drill bits to pay a visit one evening?
    Can't do much this weekend, if you're in a hurry thobut.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Feb 2, 2007
  4. SD
    SD Guest
    Thanks, uncle. Trouble is, there's no more than 4" of clearance to
    work with. Unless you have a very tiny drill, this could be an issue.
    I was thinking of a drill bit in my Dremel-o-like with the flexi-shaft
    thing.
    Drill a little hole ( or dent) on one side to allow a punch to gain
    purchase.
    Even if the thread gets damaged, it's a through hole, iyswim, so I can
    bung a nut on the end of a longer bolt.
    | ___ Salad Dodger
    SD, Feb 3, 2007
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    I say! That's a tad personal.
    Sounds like a plan.
    Definitely a plan. Good luck, Carruthers.
    Wicked Uncle Nigel, Feb 3, 2007
  6. SD
    SD Guest
    Cor. A good idea. I must write it down. Oh, I have.
    Ta.
    | ___ Salad Dodger
    SD, Feb 3, 2007
  7. SD
    SD Guest
    No. It was replaced shortly after, in Cheshire. It still gave issues,
    so I replaced it in 2004.
    What didn't get replaced was the pressure plate with the knackered
    threads.
    I'm getting old - bound to be a little unsteady on me pins.
    | ___ Salad Dodger
    SD, Feb 3, 2007
  8. Put a blob of weld on it. It won't stick to the casing because steel
    doesn't weld to alloy. Then weld a socket head to the blob of weld. Then
    apply socket bar.
    The Older Gentleman, Feb 3, 2007
  9. <<VVBG>
    No, indeed.
  10. SD
    snip>
    If it's just a broken stud in a casing then you might be able to
    knock it round with a very small centre punch and watch it unscrew
    like magic. Hit it close to the edge but not on the thread iyswim and
    it should move a little bit. Then tap it the other way to shift any
    debris before trying to unscrew it all the way. Once it's out half a
    turn the job's easy.
    If that doesn't work then find someone with access to a Hiab (Robbo
    might be able to assist) and use it to dump the bike in a skip along
    with any other Hondas you own. Why you expect a company that made the
    CG125 to produce anything worth having I'll never know.
    Andy Bonwick, Feb 3, 2007
  11. SD
    SD Guest
    It's out! :) [1]
    Now - what's the current favourite gloop for sticking bits of alloy
    engine casings back together? :(
    [1] Big drill charger completely fubared - so a trip to B&Q was called
    for. They didn't have one, but the did have Ryobi 18v drill and 90deg
    drill combo sets on special offer. That's £135 I won't be seeing
    again. They're dead good, though. Honest.
    | ___ Salad Dodger
    SD, Feb 10, 2007
  12. SD
    SD Guest
    JB-Weld was the gloop of choice. Mainly cos that's all I had.
    Nice, tidy, repair, too.
    Time will tell how strong it is.
    | ___ Salad Dodger
    SD, Feb 11, 2007
  13. SD
    SD says...
    Belzona has been filling a huge hole in the crankcase of my Bandit for
    about 3 years now.
    Lozzo, Feb 11, 2007
  14. SD
    SD Guest
    It's not a hole, thankfully. It's a side of the third alternator
    mounting lug. The remainder has thread, and the bolt seems secure
    enough.
    It's more cosmetic, than anything.
    | ___ Salad Dodger
    SD, Feb 11, 2007
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    You've moulded the JB Weld around the bolt, haven't you?
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, Feb 11, 2007
  16. SD
    SD Guest
    Not necessary, the JB weld is holding the original piece to the
    engine.
    The smooth bit of the bolt is wrapped in Sellotape to prevent future
    disasters.
    | ___ Salad Dodger
    SD, Feb 11, 2007
  17. SD
    Euphemism of the week...
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
    platypus, Feb 11, 2007
  18. SD
    Rich B Guest
    JB Weld reconstructed a rotten propeller on a boat I was selling - held up
    at 25 knots in sea water long enough for a convincing sea trial and a quick
    sell. Excellent stuff.
    Rich
    2001 Disco II ES auto
    1971 S2a 88" petrol
    2005 XT660R
    Rich B, Feb 11, 2007
