The CB 750 sprang in to life this avo. Thanks to all who offered advice. I took the carbs off and cleaned them again. I'm not sure this had much effect. The CB750 has a vacuum operated fuel valve in series with the manual fuel tap. It only allows fuel through when the engine is running. If you can't start the engine owing to a lack of fuel - you're stuffed. OK, that wasn't the main problem but it sure didn't help. Hmm. Thinking about it, the vacuum device stopped a whole tank of fuel from evaporating out of the float chambers... So, perhaps a double edged sword. Slight leak from the sump plug. Tightened it slightly - felt ominous. I'll be thoroughly F'd O if it's stripped. So I'll stick it all back together tomorrow night, get an MOT and it'll be the eighties all over again. Cheers, Nick
