It must be nearly holiday time
Discussion in 'UK Motorcycles' started by Andy Bonwick, Aug 8, 2009.
  1. Andy Bonwick
    She would look interesting in a french maid uniform though.
    I've got a new leccy can opener with built in bottle opener and knife
    sharpener. Sorted.
    Hog, Aug 10, 2009
    #61
  2. Andy Bonwick
    I've got some morphine here if you'd like it...
    Ace, Aug 10, 2009
    #62
  3. Andy Bonwick
    Thanks but no.
    I'll just take whatever they give me and get the dose as low as
    possible as soon as possible so I can go to the pub.
    Andy Bonwick, Aug 10, 2009
    #63
  4. Andy Bonwick
    frag Guest
    took a blunt brush and painted...
    I tried a 1/4 of one of the 100mG morphine tabs I have here, they must be 6
    years old now. Did **** all. So I tried 1/2. Ditto. A whole one. Nothing.
    Last ditch attempt I tried some oramorph I found, still nothing.
    Doesn't last long in storage does it?
    frag, Aug 10, 2009
    #64
  5. Andy Bonwick
    It's not something I know anything about, TBH, although if it does 'go
    off' I'm quite surprised. And 100mg really should be noticeable. Just
    checked the boxes I've got, which are of 10mg tabs[1] - they were
    dispensed in late 2006, and they have a 'use by' date of Oct 2010.
    Of course, actual formulations vary; this is 'MST continuous' which
    apparently gives an equivalence of 75% with simple morphine, i.e. the
    10mg tabs are equal to 7.5mg, but last for 12 hours. So if there is
    any degradation it's quite possibly different for this formula.
    TBH though, I've not used any for about two years, so I've no idea
    what effect it would have now.
    [1] When I came out of hospital I was prescribed 70mg, 3 time daily,
    but I knew I didn't really need that and would reduce the dose quite
    quickly, so I got them to give me smaller tablets to allow for this.
    Ace, Aug 10, 2009
    #65
  6. I seem to remember there being some silly rule in the yuk, that a chemist
    won't seel you enough pills to kill yourself, without prescription. Is
    this still true? Was it ever?
    At my local chemist, if I ask for brufen, they give me 600mg tabs by
    default. I thought this was a bit over the top for a dull ache, so I had
    to order in some 200mg. A couple of years ago I had the flu, and they
    gave me paracetamol 1000mg pills. Bloody big.
    Paul Carmichael, Aug 11, 2009
    #66
  7. Andy Bonwick
    Yes & yes.
    Krusty, Aug 11, 2009
    #67
  8. Andy Bonwick
    Well no, not strictly. OTC pack sizes are generally limited in size,
    and anything sold outside a Pharmacy very much so.
    But if you ask for large amounts in a pharmacy, always assuming they
    have an appropriate pack size, the assistant will need to check with
    the pharmacist, who will interrogate you as to how and why you're
    using them - if satisfied they will still let you have them.
    I used to get this even just buying more than 100 ibuprofen at a time
    in Boots in the UK. Couldn't seem to get the 100 packs over here, and
    bubble-backs are _so_ much more expensive. Nowadays, of course, I just
    pick up a bottle or two of 750/1000 each time I'm in the US. $15-20 a
    go in any supermarket - bargain.
    Not that they'd kill you anyway, of course, unless you took enough to
    burn a hole in your stomach ;-}
    Ace, Aug 11, 2009
    #68
  9. Andy Bonwick
    boots Guest
    Yes, at least for paracetamol it's sold in packs of 16 of which two I
    think, are the maximum you can purchase at anyone time if there's no
    pharmacist present.
    Not sure if the same restrictions actually apply to ibuprofen and
    asprin. In supermarkets they're in the same size pack I suspect so as
    to not confuse the staff.
    I've bought much larger quantities from a proper pharmacy AKA the
    chemist. I was asked why I wanted so many, explained I was holidaying
    on a boat with no access to land for a week and got 200 of each.
    boots, Aug 11, 2009
    #69
  10. Andy Bonwick
    Yep sorry, I forgot the rule was brought in for non-chemist sales
    (supermarkets etc).
    #70
  11. MARKO sell large trade pack trays of them in the smaller sizes.
    Mick Whittingham, Aug 11, 2009
    #71
  12. Which is odd - lethal dosage of paracetamol is between 10g to 12g
    (depending on various factors like weight and general health). And
    32x500mg[1] is 16g..
    Phil
    [1] I assume that the tablets are 500mg
    Phil Launchbury, Aug 11, 2009
    #72
  13. Andy Bonwick
    Catman Guest
    Only if you're correctly licensed.
    www.cuore-sportivo.co.uk
    Catman, Aug 11, 2009
    #73
  14. Andy Bonwick
    Ah, that must be the little-seen Chimney Pig. Your place under the
    Piggy Flight Path, is it?
    Pip, Aug 12, 2009
    #74
  15. Andy Bonwick
    Sheltex, you fucker. Unless you're riding in a shellsuit, of course.
    Pip, Aug 12, 2009
    #75
