IT LIVES . . . .{ it's life Jim, but not as we know it }
Discussion in 'Classic Motorbikes' started by ^..^ Lone Wolf, Dec 30, 2008.
  1. Wotcha.
    I now know how Dr. Frankenstein felt.
    After the best part of two years on the bench, the "project B33" ran for the
    first time on Sunday.
    OK - so it's an old BSA - almost fifty years old, but to me it's been the
    thing that I've spent a lot of time and money on. I've always wanted an
    alternator B33, and now I'm a damn sight closer to having one.
    http://www.moonshiners.org.uk/video/2008itlives.wmv
    I really don't like to say how much money I've sunk into this, but as far as
    I'm concerned, it's money well spent.
    All in all, a great way to end the year . . . I can feel a celebration curry
    coming on ;-)
  2. Hm. Couldn't get a picture on my Mac, but heard it running. Well done!
    The Older Gentleman, Dec 30, 2008
  3. pictures work here in VLC. wonder if VLC runs on the mac?
    Is that a belt primary drive? I thought they had chains?
    Austin Shackles, Dec 30, 2008
  4. ^..^ Lone Wolf
    Rusty_Hinge Guest
    The message <1isr5dp.1y2ssj71sxa12nN%>
    from (The Older Gentleman) contains these
    words:
    Glad I saw that before I looked - not set up for sound here.
    Rusty_Hinge, Dec 30, 2008
  5. Austin Shackles wrote:
    Wotcha.
    It has a lot of things that the original didn't have.
    Belt primary drive. - Tony Hayward, Triumph set up, modified.
    Front disc brake. - Once again, Triumph, T140 Bonnie.
    Cartridge oil filter. - Saves the crank, for the sake of £ 23
    Longer throw crank. - A bit of an error with the flywheel / crankpin hole
    Larger valves. - with seats to take unleaded.
    More stainless steel than you can shake a stick at.
    Japanese switch gear. - I ain't a purest, I want stuff that works, and works
    well.
    Direction indicators. - Today's drivers don't know what a hand signal is.
    It keeps me happy. I'm worried that once it's up and running, I'll have
    nowt to spend my time and money on. I dare say something will crop up.
  6. ^..^ Lone Wolf
    Looks great.
    Wish I had the staying power to complete a project like that.
    Pip Luscher, Dec 30, 2008
  7. Pip Luscher wrote:
    Wotcha.
    I think it reached a point where I had no choice but to continue.
    The phrase "good money after bad" did spring to mind more than once ;-)
  8. ^..^ Lone Wolf
    Rusty_Hinge Guest
    The message <gjdgu5$30sf$>
    Sure it's not one from a M21? People fitted those to turn the 500 into a
    600-ish.
  9. Rusty_Hinge wrote:
    Wotcha.
    Yep - that's the "bit of an error"
    Someone didn't know there was a difference twixt B33 / B31 / M20 / M21
    flywheels.
    By a stroke { see what I did there ;-) }of luck, I also had the "short"
    con-rod.
    The whole plot works out at 540cc, and with just under 1/8th of an inch
    barrel spacer, gives a CR of 7½ to 1.
    These little things are sent to try us.
    ^..^ Lone Wolf, Dec 31, 2008
  10. ^..^ Lone Wolf
    Paul - xxx Guest
    Very nice, sounds good too ... ;)
    LOL, YKIMS ... ;)
    Paul - xxx, Dec 31, 2008
  11. ^..^ Lone Wolf
    Rusty_Hinge Guest
    You can do the same trick with a Venom - makes (IIRC) a 600cc thingie if
    you use flywheels from a longstroke MSS.
    Rusty_Hinge, Dec 31, 2008
  12. ^..^ Lone Wolf
    Rusty_Hinge Guest
    Hogmanay TAAAW - what a combination.
    (Combination? Somewhere to keep the bottles?)
  13. ^..^ Lone Wolf
    mark Guest
    mark, Dec 31, 2008
  14. ^..^ Lone Wolf
    Last year, I trundled off to the bottle bank with the chair filled to the
    gunwales. The load made little clanking noises and stayed quite flat on the
    corners.
    platypus, Dec 31, 2008
  15. ^..^ Lone Wolf
    Rusty_Hinge Guest
    Just come back from Naaardge, having intended to get 2 litres of thin
    bleach, some loose tea and a jar or two of mild.
    Got the bleach and the tea, but some sort of magnet drew me into the
    Whisky Shop...
    Heavier bag, lighter pocket.
    Happy New year all!
  16. ^..^ Lone Wolf
    Simon Wilson Guest
    Looks and sounds nice. Why not go the whole hog, ditch the carb and go
    for FI? :)
    Simon Wilson, Jan 2, 2009
  17. Simon Wilson wrote:
    Wotcha.
    Simple. I can understand Amal carbs. I can strip 'em down, re-build 'em,
    and set 'em up to run right. I have enough Amal bits to hand so that I
    don't have to go out shopping. A new 32mm Concentric will set me back about
    £ 70 - I can live with that. FI is an arcane art - it needs magical
    electric bits ( unless it's a Wal Phillips - and I've got one of those ),
    fuel pumps, injectors and things I've probably never heard of. To me, fuel
    injection is a step backwards.
    Belt drive is an improvement over the original chain. Alternator is an
    improvement over the original. Disk front brake is an improvement etc. I
    can't see FI being an improvement. The original "Monobloc" carb has been
    replaced with a more modern "Concentric" - I may go for something like a
    Mikuni, or even a Dell'Orto, but fuel injection ? No thanks. . . .
    There again, I do like a challenge ;-)
    ^..^ Lone Wolf, Jan 2, 2009
