It is better to walk away...
Discussion in 'UK Motorcycles' started by Lozzo, Jan 2, 2004.
  1. Lozzo
    ....and have a cup of coffee and relax, before you lose it altogether and
    smash the fucking shit out of someone elses Bandit 600 with a lump
    hammer.
    Five out of the eight exhaust bolts came out no problem, three have
    broken. Two of them are the ones on number 2 cylinder, and the third is
    the outermost of number 1 cylinder. The two inner ones have left a 10mm
    shank for me to work with, but the one on number 1 cyl is broken flush
    with the head.
    I really don't want to take the head off because it just involves even
    more work and added time/expense.
    Ho hum, at least I have the skills and tools required to repair it.
    Lozzo, Jan 2, 2004
  2. Lozzo
    Mark Olson Guest
    Having seen the results of the application of a MAPP gas torch to exhaust
    studs, I am now a believer. At the first sign of recalitrant studs I
    would suggest application of FOAD amounts of heat.
    Mark Olson, Jan 2, 2004
  3. Lozzo
    Are they studs or bolts?
    Studs, first sign of "Hmm, I reckon that'll shear if I apply any more
    force" then it's nut splitters, air chisel or simply cut the nut off with
    gas torch.
    Unfortunately it's usually more a case of "I wish I hadn't applied any
    more force"
    sweller, Jan 2, 2004
  4. Lozzo
    spida Guest
    I'd go for the instant gratification option.
    <snip>
    Bandit 600 (Gone)
    GSX-R600(His) VFR800I(Hers)
    apf@BIN_ITdsl.pipex.com to reply.
    spida, Jan 2, 2004
  5. Lozzo
    sweller said...
    Bolts, tried the heat from a blowtorch and molegrips all to no avail.
    I've got the two stumps soaking in Plus-Gas at the mo. I'll see what
    they're like tomorrow. The other one will have to be drilled.
    Lozzo, Jan 2, 2004
  6. Lozzo
    Alan.T.Gower Guest
    Oh dear.
    That's nice for you.
    Alan.T.Gower, Jan 2, 2004
  7. Lozzo
    Andy Bonwick said...
    I thought she'd manage to scare it out by looking at it.
    Lozzo, Jan 2, 2004
  8. Lozzo
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Get her to wiggle her arse in leathers in front of it.
    When it gets longer grab the fucker with a pair of grips.
    Nigel Eaton, Jan 2, 2004
  9. Lozzo
    deadmail Guest
    Well, that'll only make Lozzo scream, won't it. What's the plan for the
    stud? Or are you trying to take his mind off of it?
    deadmail, Jan 3, 2004
  10. Lozzo
    Nigel Eaton Guest
    typed
    I'm only trying to help here. Got any better ideas?
    Nigel Eaton, Jan 3, 2004
  11. Lozzo
    deadmail Guest
    Heat, lots of it.
    Lots and lots and lots of heat.
    Then some more.
    Then chuck a few gallons of petrol about, then a match; it's the only
    way to be sure.
  12. Lozzo
    Nigel Eaton Guest
    typed
    Right. So that's dealt with Lozzo's hard-on. What are we going to do
    about the bike?
  13. Lozzo
    deadmail Guest
    There's a bike involved?
    Oh, **** that I'm too busy enjoying the fire.
  14. Lozzo
    Nigel Eaton said...
    People, people, please. My daughter reads this ffs.
    Lozzo, Jan 3, 2004
  15. Lozzo
    deadmail Guest
    Given some of the things you've posted in the past and the mild nature
    of this thread that's a little rich, don't you think?
  16. Lozzo
    Nigel Eaton Guest
    typed
    Heh, need a hand with that net Loz? After you've put your genital fire
    out, obviously.
  17. Lozzo
    said...
    She doesn't mind me swearing and whatever, but she naturally wants to be
    spared talk of my genitals.
    Lozzo, Jan 3, 2004
  18. Lozzo
    Nigel Eaton Guest
    "Talk of"? She'll have done fucking well to avoid a photo.
  19. Lozzo
    Nigel Eaton said...
    She didn't, she saw the earhole one, and gave me grief about it.
    Lozzo, Jan 3, 2004
  20. Lozzo
    deadmail Guest
    Well that's two of us then. Phew.
