It almost lives
Discussion in 'Classic Motorbikes' started by Tim, Mar 8, 2008.
  1. Tim
    Tim Guest
    Time spent re-wiring the Norton has proved reasonable fruitful. The
    electrics work. Plenty of stuff still to do, but it's a start.
    Tim, Mar 8, 2008
  2. Tim
    Pete Fisher Guest
    The Forgotten Era project Morini is now in "it's life Jim.." mode.
    Running, but the swapping around (ace bars etc.) has completely
    unsettled the carb balance. Got it reasonably close the eye and finger
    method [1], but I am hoping the good old Morgan mercury manometer still
    works - particularly that I can find the inlet stub vacuum bleed
    adapters. Healthy spark with a mix of old bits and new plugs, leads and
    caps. Sounds great on the 2 -1, but may be even better if I can get a
    new state of the art ignition pickup.
    [1] peer at one slide while gently feeling the other. Carbs facing
    opposite directions can be a pain at times.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 8, 2008
  3. Tim
    TOG@Toil Guest
    Have you tried crossing your eyes?
    TOG@Toil, Mar 11, 2008
  4. Tim
    osvif Guest
    Only when accidentally touching the "hot" end of the HT leads when
    setting the points.
    osvif, Mar 11, 2008
  5. Tim
    Pete Fisher Guest
    In communiqué
    I did think of a magician's strategy - all done by mirrors.
    Pete Fisher, Mar 11, 2008
  6. Tim
    Pete Fisher Guest
    In communiqué
    What are these points to which you refer? It's Forgotten Era not
    Jurassic.
  7. Tim
    Tim Guest
    It's a mystic are handed down from bodger to bodger.
    Tim, Mar 11, 2008
