Is this clutch fscked?
Discussion in 'UK Motorcycles' started by Wik, Feb 15, 2004.
  1. Wik
    Wik Guest
    www.ganzilla.pwp.blueyonder.co.uk/images/Clutch_1.jpg
    www.ganzilla.pwp.blueyonder.co.uk/images/Clutch_2.jpg
    www.ganzilla.pwp.blueyonder.co.uk/images/Clutch_3.jpg
    www.ganzilla.pwp.blueyonder.co.uk/images/Clutch_5.jpg
    www.ganzilla.pwp.blueyonder.co.uk/images/Clutch_6.jpg
    It's from Suze's CBR and the clutch has been refusing to disengage
    properly. Springs, release plate, bushings, bearings, etc. are all
    otherwise fine.
    All the plates are fine, also, but the grooves in the basket and housing
    (which I've tried to illustrate in the pics) are really quite pronounced.
    Not sure I want to spend several hours at them with a small file (which I
    don't currently have...) but will do so if the concenscus is that it can
    be rescued.
    Help me whilst the light's still good! =8-o
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Feb 15, 2004
  2. Wik
    Previously on ukrm, Wik said...
    Get the files out sunshine.
    Lozzo, Feb 15, 2004
  3. Wik
    mb Guest
    See if you can get the angle grinder in there...
    You could also try some emery cloth, if you don't have a small file.
    Or move the clutch assy aside and drink the alcohol you have standing
    there ;-)
    mb, Feb 15, 2004
  4. Wik
    Robbo Guest
    Dremel...........YKIMS
    Easier than filing.
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Feb 15, 2004
  5. Wik
    Previously on ukrm, Robbo said...
    FFS Robbo, will you PLEASE sort out your fucking attributions. It's
    impossible to tell wtf you're replying to. Even I've sussed how to do it
    and thick as you might be, it's easily within your capabilities.
    Lozzo, Feb 15, 2004
  6. Lozzo wrote
    **** his attributions. It is the other end entirely that needs dealing
    with.
    steve auvache, Feb 15, 2004
  7. Wik
    Previously on ukrm, steve auvache said...
    Maybe he should seriously rethink the manner in which he posts to ukrm.
    Others have been seriously plonked for far smaller misdemeanours. The
    attributions are all to shit and the .sig is so big that it takes up
    half a fucking screen. On top of that the content is rarely worth the
    click on a mouse button. Have a fucking word Robbo.
    Lozzo, Feb 15, 2004
  8. Wik
    Kiran Guest
    Easy. Go into the nearest new bike shop and ask Suze to say, "I'll have one
    of those please."
    Goawn, YKIMS.
    Kiran, Feb 15, 2004
  9. Wik
    Robbo Guest
    Lozzo wrote
    OI!
    You haven't seen my other end
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Feb 15, 2004
  10. Wik
    Greybeard Guest
    As the man sayeth.
    Greybeard, Feb 15, 2004
  11. Wik
    Suze Guest
    I think this is probably my favourite plan so far ;-)
    Suze, Feb 15, 2004
  12. Lozzo wrote
    That is downright silly.
    How many letters?
  13. Robbo wrote
    What I have seen is enough.
  14. Wik
    Suze Guest
    Thanks for all the good advice. Wik's dutifully putting the bike back
    together so it's rideable for tomorrow.
    We'll probably buy tools required this week and hopefully get it sorted
    next weekend.
    Thanks again guys.
    Suze, Feb 15, 2004
  15. Wik
    mb Guest
    OE:
    Tools>Options>send> check box "include message in reply"
    See also:
    Tools>options>signatures...
    mb, Feb 15, 2004
  16. Wik
    Simes Guest
    His 'references' header shows perfectly who he is replying to - so as long
    as you are using a decent news client, it's not a problem.
    Admittedly, he is a fuckwit anyway.
    Simes, Feb 15, 2004
  17. Wik
    Wik Guest
    Heh, I blame the photographer, meself.
    Arr. Still, I got it all back together and didn't have any bits left over
    and it ain't no worserer than wot it was when I started.
    No better either, mind.
    Still, it's an excuse to buy some nice jewellers files and maybe even a
    Dremel (or similar).
    On that latter point, would a mini-drill thing with a suitable bit -- I'm
    thinking ickle, very fine grit, grinding wheel, like, er, this:
    http://www.dremeleurope.com/cgi-bin/eu2002.storefront/181185271/Product/View/8153
    or similar be a good choice?
    Won't be able to do 'owt for over a week, though as I'm away much of next
    weekend.
    Ta to everyone for their assistance thus far.
    Wik, Feb 15, 2004
  18. Wik
    deadmail Guest
    <snip the normal pointless stuff>
    And still the thick **** makes no attempt to fix his attributions.
    deadmail, Feb 15, 2004
  19. Wik
    deadmail Guest
    But you've got to switch the header view on and then double click to
    open the previous message. Sure it only takes a few seconds but because
    of your next point it's not really worth the bother.
    It's so fucking easy to setup I don't understand why he refuses to do
    it.
    I suppose that he's too 'independent' to be told what to do. I did try
    asking reasonably a couple of times. IIRC Pip said I was wasting my
    typing.
  20. Wik
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Wik
    I'd go with hand files myself[1]. Dremels are very good, but you can
    remove a lot of material very quickly. More than you wanted to IME,
    which would be as bad or worse than the situation you're in now.
    You're still welcome to the use of my garage, BTW.
    [1] Actually, I probably wouldn't. I'd probably set it up in the mill
    and clean it up that way. But that's just me.
    Nigel Eaton, Feb 15, 2004
