Is this a carb problem? (long)
Discussion in 'UK Motorcycles' started by Dave Eades, Aug 23, 2004.
  1. Dave Eades
    Dave Eades Guest
    I need some suggestions here.
    Not ridden the zephyr 550 for a month or so, due to it needing a new oil
    seal, and me being lazy, and not getting it done.
    Anyway, Saturday arrived and i went and picked up the new seal from my local
    bike place.
    took a couple of hours to fit, and all seems fine.
    Sunday I ride to the petrol station to fill up and give the bike a run.
    I noticed that the bike was a little smokey (white smoke), and smelt heavily
    of petrol.
    I put £14 worth of petrol in, and set off for a good run.
    The white smoke was still there. when i pulled up, there was petrol dripping
    from the exhaust!
    anyway the outcome is.....
    The bike did 32 miles on £14 worth of petrol.
    carb problem?
  2. Dave Eades
    JB Guest
    I would seriously have someone check the vacuum-operated fuel tap for a
    split diaphragm and also all of the carb overflow pipes for fuel pissing
    out. There's *no way* you could burn £14 worth of fuel in 32M even. You say
    gave it a "good run". How did the bike feel? If it were overfuelling as
    seriously as you state, it would have ridden like a dog, if it had run at
    all. What seal did you change by the way?
    JB
    JB, Aug 23, 2004
  3. Dave Eades
    Dave Eades Guest
  4. Dave Eades
    Dave Eades Guest
    Bike felt OK, if a little lumpy!
    did not want to travel above 80 mph though.and the smoke really was
    horrendously bad.
    The seal i replaced was the one that sits behind the front sprocket (that
    seems fine now).
  5. You are Salad Dodger AICMFF H1s.
    The Older Gentleman, Aug 23, 2004
