Is the internet semi borked?
Discussion in 'UK Motorcycles' started by JackH, Sep 8, 2005.
  1. JackH
    JackH Guest
    ....only, I'm having trouble accessing stuff like MSN Messenger this evening.
    TIA
    JackH, Sep 8, 2005
  2. JackH
    SteveH Guest
    You've been installing a WiFi router, haven't you?
    Might be worth checking that you've got the MSN ports opened on it.
    SteveH, Sep 9, 2005
  3. JackH
    JackH Guest
    Not just having trouble with MAN... certain webshites are apparently not
    'avin it', either.
    Which ports are we talking, anyway?
    TIA
    JackH, Sep 9, 2005
  4. JackH
    SteveH Guest
    1863 UDP and TCP.
    Also worth getting hold of the IPs of your ISPs DNS servers and ensuring
    they're entered manually both in the router config. and on the PC.
    SteveH, Sep 9, 2005
  5. JackH
    JackH Guest
    I've just entered the above - no change.
    If I ping websites I know are working, they return the packets... surprise
    surprise, the ones that aren't working, don't.
    JackH, Sep 9, 2005
  6. JackH
    Catman Guest
    No, really. Use the router for PC DNS unless you are having real issues
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Sep 9, 2005
  7. JackH
    tallbloke Guest
    Which ISP do you use?
    tallbloke, Sep 9, 2005
  8. JackH
    Cane Guest
    That's right mate, the entire world wide web is broken. I mean, it
    couldn't possibly be you, could it. ;-)
    Cane, Sep 9, 2005
  9. JackH
    JackH Guest
    It was these new fangled wireless routers needing something tweaked to work
    with my ISPs ADSL... still... it was quite confusing when some sites would,
    and some wouldn't.
    <hangs head in shame>
    JackH, Sep 9, 2005
  10. Sorry - it was my fault. I had to unplug it for a bit to do the
    hoovering.
    Lemmiwinks, The Gerbil King, Sep 9, 2005
