is part of my goldwing carburetor tee _missing_ or what?? (pix)
Discussion in 'Motorbike Technical Discussion' started by bill yohler, Oct 1, 2003.
  1. bill yohler
    bill yohler Guest
    my goldwing six has a seemingly uncureable hunting or surging problem,
    possibly caused by this missing <?> plastic piece on the side of my
    carb tee <?>
    bike starts and idles fine hot or cold. accerates fine up through ALL
    gears (as long as it's 'floored'). runs fine at any steady RPM, but
    -only- while on the centerstand (using throttle lock).
    bike will _NOT_ hold any steady cruise speed on the hiway in 3rd, 4th,
    or 5th gear. weirdly, it runs fine (& @ any steady cruise speeds) in
    1st or 2nd. gearshift sensor is fine (tested out completely), fuel
    pump and filter output excellent and steady by test, electric _to_
    fuel pump steady on hiway by test, air cleaner clean, gas fresh, plugs
    clean and gapped -
    I've rebuilt these carbs _twice_ this past month, and still the same
    nuisance. acts as if either ign key being shut off or as if run
    _completely_ and _suddenly_ out of fuel when ANY steady RPM range or
    hiway speed attempted in 3, 4 , or 5th gear. very near unrideable.
    carbs are both 'cleaner than clean' (carb bodies cleaning involving,
    in part: pot-scrub dishwasher cycle, pressure washing at 3500 psi,
    blown out with 175 psi air, soaked in carb cleaners and lacquer
    thinners for days, etc)
    is part of this plastic <carb vacuum ?> "tee" fitting missing? please
    see pix at
    members.cox.net/tool_box
    this is drivin' me _nuts_
  2. bill yohler
    Charlie Gary Guest
    Are they synchronized?
    Later,
    Charlie
    fix the e-mail address and it will get to me
    Charlie Gary, Oct 1, 2003
  3. bill yohler
    mtm Guest
    Bill .....
    What year is this bike?
    Didn't some Wings have some kinda fuse, fuseable wire, shorted wire near
    the battery, intermittent miss, dying in mid stream sorta problem, on
    'some' older models?
    A bare wire kinda thing?
    It's been awhile :)
    mtm
    '95 750 Nighthawk (big red)
    '95 Helix (little red)
    mtm, Oct 1, 2003
  4. bill yohler
    mtm Guest
    Site does not come up valid.....
    mtm
    mtm, Oct 1, 2003
  5. Maybe it could also be an ignition problem. If your timing is wandering
    around, you can get all kinds of strange engine behavior.
    r_kleinschmidt, Oct 1, 2003
  6. bill yohler
    bill yohler Guest
    thanks guys for your replies
    regarding all your suggestions, the bike -=ONLY=- has 'surging',
    jerking, -very- "herky-jerky" behavior in 3rd, 4th, and 5th gears. so,
    what carb synch problem or fuseable, shorted wire, or ignition timing
    problem could occur ONLY in the UPPER gears? could that be possible?
    regarding the harness connector mentioned, are you saying the
    connector might have a problem where it connects brain to the harness?
    it has an outer 'hard cap' cover (2 snaps) and an inner push-on (2
    'click-ears') connector. all was 'clean as a whistle' in there, and
    still is. seems ok. is there a wire in the harness that 'could' cause
    strange behavior but _only_ in certain (the upper 3) gears?
    there's _never_ a problem in 1st or 2nd gear; the bike'll run fine at
    any speed, 'throttle lock on' or not, but only IF it's in 1st or 2nd
    gear. I checked the gear position sensor (the only item I thought that
    could maybe cause this, or that seemed 'road speed or gearbox
    position-related to me) per the factory manual procedure with volt
    ohmmeter, in all gear positions (neutral, 1st, 2nd, 3rd, 4th and 5th),
    and it tests correctly in all six positions.
    still can't find any procedure in factory manual for testing the brain
    'itself', only the items that 'feed' it, some of which tests I can't
    do, because the way they're written (or translated from japaneese)
    makes them undoable, even with lots of 'educated guesswork' about what
    they're trying to say :-(. steps are missing, vacuum specs for parts
    of the test and other procedural steps just -aren't- in the book, and
    I'm suspecting one airjet/vacuum solenoids 'test results' chart is in
    the wrong place, or the wrong chart is in the right place in the
    manual - very frustrating. stuff like "hook a vacuum pump to the
    brain, and do the rest of these steps, apply this amount vacuum to
    both solenoids with another two vacuum pumps" (but never a MENTION
    anywhere of how much vacuum or when to apply it to the 'brain'!) -
    illustrations show 3 speperate vac pumps in use. this = total
    confusuion. why even BOTHER hooking a vac pump to the brain IF it's
    not gonna be used? are they just using it as a 'blind cap'? ....they
    never say, & I got no clue.... there's simply too much info missing
    entirely or transposed in the book to even complete the test<s>
    well, the brain circuit board itself looks 'factory brand new' clean.
    it has no visible burnt stuff <resistors, diodes/whatevers> or leaking
    capacitors, no strange goo on it, no scratches, no scrapes or dirt,
    etc... :-(
    so, I'm asking myself (and you guys too ;-):
    is there ANYthing other than the ECU/"brain" that could _possibly_
    cause this wildly surgey/herky-jerky krap but _only_ in the upper 3
    gears? (not trying to be a 'wise guy' here, just asking).
    think I'm gonna go have root canal this afternoon "for some fun" (this
    is still drivin' me nuts)
    bill yohler, Oct 10, 2003
  7. bill yohler
    bill yohler Guest
    hi keith, thanks. as I said earlier in thread, fuel pump AND fuel
    filter flow rate (output) BOTH test excellent. fuel pump and fuel
    filter (combined) 'output' more than double the factory 'minimum
    output' spec in cc per minute.
    fuel pump pressure also good, and, I went a little 'outside the box'
    and tested electric supply _TO_ fuel pump 'on the hiway' (by soldering
    a tiny lite bulb with longish leads to the fuel pump power and
    grounds, with bulb itself temporarily taped to the dash) and found the
    elctric supply to the pump _itself_ to be steady and continous, even
    when problem _is_ occuring (bike bucking wildly)....also, fuel filter
    itself optically clear (no dirt or sediment seen inside it). so, umm,
    anybody got any other idea? right now I'm thinkin' "what else COULD it
    be BUT the brain?" (but, sheesh, I don't know).
    I'm kinda from the 'points and condenser, simple carb, driver uses HIS
    brain, and it's the SOLE brain' era...
    thanks again :)/I'm still hoping for a sudden insight...
    bill yohler, Oct 12, 2003
  8. bill yohler
    bill yohler Guest
    bill yohler, Oct 13, 2003
