Is it OK to............
Discussion in 'UK Motorcycles' started by gazzafield, Mar 27, 2005.
  1. gazzafield
    gazzafield Guest
    remove all shims that need changing at once? As you can tell I have never
    changed shims on a bike. All my previous four strokes have been SOB's with
    tattering chappets. I need to know that it would be OK to hoik out a shim
    then turn the engine for the next one etc and that the cam running directly
    on the bucket won't damage it at all.
  2. Yeah, that's fine. I mean, a cam lobe wiping a bucket at whatever speed
    your hand can turn over an engine isn't going to do any harm at all.
    However, if you're hoicking out a shim, better to replace it
    immediately, IMHO, otherwise you run the risk of forgetting which shim
    was atop which valve, and making a hash of the clearances.
    Measure gap, if necessary remove shim, calculate thickness required for
    new shim, insert new shim, move onto the next one. That's the best way.
    The Older Gentleman, Mar 27, 2005
  3. gazzafield
    I find that drawing a nice picture, or making up a nice little table on
    a bit of paper is best. You want cylinder number, in or ex valve actual
    clearance, shim size and target clearance.
    I dunno if the dealer will let you have the needed shims on the strength
    of you bringing the old ones back. Maybe it's best keeping some old
    shims so you don't have to gamble on the top of the empty shim bucket
    knackering the cam lobe if it's turned with no shim in there... and as
    Tog says, you don't want to muddle them up.
    Muck, Mar 27, 2005
  4. That's exactly what I do.
    Few dealers exchange shims these days. I keep old ones, because you
    often need them. Big ones can have their size inked on with indelible
    marker.
  5. gazzafield
    Shims can be as much as £10 each, so one dealer told me.. dunno how true
    this is though. I've always been able to exchange them at about £3 each.
    As do the little ones in my FZR. Although it's not hard to measure with
    a micrometer, just to double check.
    Muck, Mar 27, 2005
  6. gazzafield
    gazzafield Guest
    Just thought it might be better this way as I am twenty miles away from the
    nearest bike shop and don't have any shims. Just thought it would be easier
    to take them out, see what size I need and go buy or exchange them. This is
    my understanding of how to get shims but having never had to do it
    before......
  7. My Ducati ones vary - different price for opening or closing, and I
    unremember which. But one is about 4 quid and the other twice as much.
    True.
  8. Yes, I se the prob, but once you've taken one out and checked it, you
    can work out what size you need. If it's a matter of just two or three
    shims, as long as you make damn sure you know which shim came from which
    valve, you ought to be OK, yes.
  9. gazzafield wrote
    Spot on, well done.
    steve auvache, Mar 27, 2005
  10. Especially when you have a large plastic flip lid tray with ALL the shim's
    and their sizes neatly marked out in little compartments.
    eric the brave, Mar 27, 2005
  11. Not a problem. Just re-check the clearance after you have changed the
    shims.
  12. gazzafield
    Don't forget 'L' or 'R' if it's a four-valve...
    Pip Luscher, Mar 27, 2005
  13. gazzafield
    Yeh, I use W and A on the FZR, no ambiguity as W is for water pump and A
    is for alternator.
    Muck, Mar 27, 2005
  14. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember
    (The Older Gentleman) saying
    something like:
    On the ol GSs it slightly knocks the edge of the cam lobe against the
    bucket edge and just ever so slightly bevels the lobe edge... even at
    hand speed.
    Grimly Curmudgeon, Mar 28, 2005
  15. OK, I stand corrected.
    The Older Gentleman, Mar 28, 2005
  16. It was somewhere around Barstow, on the edge of the desert, when the
    something like:
    I stood aghast. After that I put a 2p piece in as a temp shim for turn
    over purposes.
  17. gazzafield
    Did it work, or did it just scratch the load bearing part of the cam?
    Muck, Mar 28, 2005
  18. gazzafield
    Excellent, thought so, but wasn't sure that the coins were 100% copper.
    Muck, Mar 29, 2005
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
    They're not.
    Wicked Uncle Nigel, Mar 29, 2005
  20. It was somewhere around Barstow, on the edge of the desert, when the
    They're not, but the thickness of the coating is enough.
    Steel core with a copper (or cupro-nickel) cover.
    Grimly Curmudgeon, Mar 29, 2005
Similar Threads
Loading...
