Is it me, or the bike? BMW K1200RS question
Discussion in 'Bay Area Bikers' started by KS, Sep 4, 2003.
  1. KS
    KS Guest
    First, I'll give all the qualifications: I've owned this 2002 model
    about 2 years now. I bought it new. Prior to that, I hadn't ridden
    since I sold my ZX10 about 8 years ago. I'd owned that bike for about 2
    years, and a Magna 700 for about a year before that. I've never been on
    the track. I like twisty roads, but I'm not a particularly agressive rider.
    Now the question: Why can't I get this 640-lb behemoth to lean with any
    assurance that it will not lose traction and drop flat on its side?
    It's a sport-tourer and I expect some modicum of sporting behavior from
    it, but I've been completely unnerved by several incidents. One of
    these resulted in a low side during a surprise encounter with gravel,
    another in a rear end slide on seemingly clean pavement from which,
    through dumb luck, I managed to recover, and a third in front wheel
    slippage, also from which I managed to pull through, primarily because
    the turn simply ended. I stress that on none of these occasions was I
    really pushing the bike, and as far as I know, I was doing everything
    right--no untimely brake or throttle applications, for example. I
    wasn't leaning very hard, and wasn't even close to touching pegs.
    I've since had the bike's suspension checked by the dealer. As far as
    tire pressure goes, I'm rather particular about that, keeping it at
    BMW's recommended levels.
    Have others had similar experiences with this particular model bike? I
    know that normally the limit is the rider's ability, and nerve, not the
    physical capability of the bike to lean and maintain its grip, which in
    most normal circumstances is a non-issue. However, I've lost all
    confidence with this bike, and have become rather loathe to do any but
    the most rudimentary leaning. And that's no fun.
    Thanks for the input.
    Khaled
    KS, Sep 4, 2003
  2. KS
    Phyloe Guest
    You never touched upon tire condition. I have found that I need new tires
    every two years. They do not last more than 9,000 to 10,000 miles. Your bike
    is heavy. perhaps the tires are in need of replacement?
    Phyloe
    Phyloe, Sep 4, 2003
  3. KS
    KS Guest
    I don't think that's a factor in this case. Tire condition was good to
    great in all three situations. I change tires every 5K - 7K miles.
    Khaled
    KS, Sep 4, 2003
  4. KS
    bob prohaska Guest
    I'd suggest checking the steering head bearings for tight spots and maybe
    try different front tires. My '98 vfr did a pretty good job of convincing
    me that my sense of balance was going away. That turned out to be notchy
    steering head bearings. Then I acquired an sv650s and found it simply didn't
    like to turn. Replacing the 60 series front tire with a 70 (and raising the
    fork tubes in the triple clamps) made a wonderful improvement.
    Good luck!
    bob
    bob prohaska, Sep 4, 2003
  5. KS
    Bob Mann Guest
    I have worn out Metzelers on mine. Worn in the centre and like new on
    the edges.
    I experience a little slippage from time to time unless I am very
    smooth The bike doen't inspire a lot of confidence. I am putting a set
    of Michelins on when they arrive so I'll see how much difference that
    makes.
    Bob Mann
    It's always darkest just before dawn.
    So, if you're going to steal the neighbour's newspaper,
    That's the time to do it.
    Bob Mann, Sep 4, 2003
  6. the telelever BMW's have ball joints rather than conventional steering
    bearings, and I've never HEARD of them going bad, even on R11GS's with
    200,000 miles that have been used extensively on fire roads and other
    dirt...
    I've seen K12'RS bikes dropped 2-3 times right in front of me on group
    rides, once at fairly high speed. Miraculously, noone was hurt (one bike
    was totalled, another required minor tweaking to complete the trip).
    Each of these occasions, I was just a few 100' behind them on my lighter
    and nimbler R1100RS, having no problems at all.
    IMHO, the K1200RS is just too big and too heavy to really be a good
    'twisty road' bike. its in its element on big radius high speed sweeper
    turns.
    John R Pierce, Sep 4, 2003
  7. On my somewhat lighter and lower powered R1100RS, I've tried MeZ4, Dunlop
    D205, and Bridgestone BT020, and come to the conclusion that I like the
    handling and ride the best on the MeZ4 (MeZ4B in front for the BMW). I
    wear out a back tire about every 5000 miles (flat spotted in the middle,
    with only about 50% wear on the sides), while my fronts last ~7000 miles
    (worn evenly from chicken strip to chicken strip). When I first started
    riding this bike, I was wearing the fronts out FASTER than the rear.
    Now, my R11RS is about 100 lbs lighter than your K12RS, and it has maybe
    40-50 less HP. Its suspension is nearly identical (although subtle
    differnces in rake, and trail exist, and the K12 has a longer wheelbase)
  8. KS
    KS Guest
    Sadly, that's the conclusion I'm reaching.
    KS, Sep 4, 2003
  9. KS
    ken ward Guest
    I get new D-205's every 4000 miles. By then the front is cupped and the
    rear is worn enough that it's not worth it to only change the front. My
    K-RS leans until it drags the saddle bags, and it's still got the stock
    shock; never been dropped but I know the ABS works. I use the 15%
    pressure increase rule, which gives me 28 front and 30 rear, cold.
    YMMV. Every time it visits the dealer, it comes back with 32/34.
    There's probably a relationship between compound, pressure, mileage, and
    traction...
    Ken
    ken ward, Sep 4, 2003
  10. KS
    Dan Carter Guest
    A dissent here--I rode a friend's K12RS on one of our local twisty roads
    (2nd and 3rd gear turns mostly) and had lots of fun. I found it fairly
    light steering and more willing to lean than I was on a bike that didn't
    belong to me.
    I would suggest coming down a few pounds on the tires. Two of your
    incidents (not the gravel-induced lowside) could have been caused by
    excessive tire pressure. I'm not sure what's up with mfr's pressure
    recommendations these days, but they seem extraordinarily high. For
    example, there's no way I'm going to run the specified 36/42 on my VFR
    because it's way too skittish with the tires that hard. At 34/36 it
    feels much better.
    Dan Carter, Sep 4, 2003
  11. and I'd recommend upping that to 38-40 front, 42 rear, the telelever is
    murder on front tires, hence the cupping.
  12. KS
    hbarta Guest
    It you have any doubt about your skills, why not take a track
    school? It is bound to increase your skill level and a good instructor
    may be able to point out things that you could do better. Hopefully
    you would learn enough to determine whether it is your skill level
    or the bike that resulted in the situations you described.
    hbarta, Sep 4, 2003
  13. KS
    Andy Burnett Guest
    KS, you're getting conflicting advice on tire pressures now. Consider
    which problem you're trying to solve -- tire cupping or traction? FWIW,
    I'm with Dan that you might try lower pressures and see how the bike
    sticks.
    I ride an ST1100 which is heavier and has a less sophisticated
    suspension than your K12RS. With sport touring tires it'll stick until
    the peg is folded up and the fairing is dragging. Whiile I don't know
    how you ride, I do suspect rider input more than the bike unless there
    is something really wrong with the particular bike.
    A few things to look at in your riding would be:
    1) Throttle control - immediately after leaning the bike into the turn,
    crack on the throttle and maintain a gentle roll-on through the whole
    turn.
    2) One steering input per turn. In most turns it's possible to ride a
    constant arc through the turn. This will help you keep a steady load on
    the tires and will make judging traction a little easier.
    3) Relax on the bike mid-turn. You want your arms and torso loose on
    the bike as you ride the turn. Tense arms will interoduce unintended
    steering inputs that tend to upset the bike.
    ab
    Andy Burnett, Sep 4, 2003
  14. KS
    Andrew Guest
    I actually picked a friend early this summer after he lowsided on his
    K1200RS. We were going up a hill and then through a left. The rear end
    just stepped out and hit the guardrail, causing a lowside. I still don't
    know why it happened, but he was ok. The bike got totalled though.
    Andrew, Sep 4, 2003
  15. KS
    Charles Soto Guest
    It's you.
    Go slow. Think about the turn. Focus on makign every turn "sweet" and
    you will eventually pick up speed.
    Charles
    PS-you can always use a belt sander to wear off the "chikin strips"
    Charles Soto, Sep 4, 2003
  16. KS
    James Clark Guest
    Did you ask if he rolled off the throttle during the turn?
    James Clark, Sep 4, 2003
  17. KS
    Andrew Guest
    I know he didn't, I was right behind him when the rear end stepped out. We
    weren't really even going that fast, maybe 30mph. I really don't know why
    it happened, the tires were new but not brand spanking new, and the road
    conditions were fine and I made it through on a similar line on my daytona.
    Andrew
    00 Daytona
    00 Speed Triple
    http://ultrasupercool.com
    Andrew, Sep 5, 2003
  18. KS
    Mr Precision Guest
    Cos it's a ballistic missile. Had one on loan while my bike was being
    serviced. Terrifying going round corners on it. Had to ride like it was
    raining. It's a 1,000 motorway miles per day tourer with blue touch paper.
    Mr Precision, Sep 6, 2003
  19. KS
    Alan Moore Guest
    Hmm. I took the even larger, heavier, LT model over Mt Hamilton a
    couple of years ago, and it did everything I asked of it, even when I
    had to suddenly tighten my turn to avoid a car, crossing a trail of
    gravel. If it's giving you a conspicuous lack of confidence in these
    situations -- greater than you feel on some other machine -- I'd start
    searching for the cause. Start at the ground and work up. Tire
    condition, tire inflation, suspension set up...
    It's also possible that something about the steering geometry has
    resulted in it requiring a more vigorous input than you are used to
    for a given change, and you are reacting to your expectation of the
    behavior of some other motorcycle. A couple of hours in the twisties
    should take care of that, all else being OK...
    Al Moore
    DoD 734
    Alan Moore, Sep 6, 2003
  20. KS
    Brandon High Guest
    Too many fucking deer.
    -B
    Brandon High, Sep 8, 2003
