Irony is...
Discussion in 'Australian Motorcycles' started by Matt Palmer, Oct 28, 2003.
  1. Matt Palmer
    Matt Palmer Guest
    .... having your blinkers stop working on your way from getting the Pink Slip
    to going to the RTA to re-register the Beast.
    I shit you not.
    Now I have to play "tip-toe through the fscking wiring" to work out where
    it's all gone tits-up. I swear, I'm just going to rip it all out and
    replace it with the spare wiring harness I have. It's just not fscking
    worth it.
    - Matt
  2. Matt Palmer
    Matt Palmer Guest
    James Mayfield is of the opinion:
    Fucked fuse this time. No idea what the horn problem is, I'll just have to
    play "trace the volts" at some stage. It's not a high priority - if I had a
    horn, I'd probably wear it out honking at all the idiots obliviously
    trundling around.
    - Matt
    Matt Palmer, Oct 29, 2003
  3. Tee hee! Horn!
    Hammo
    Hamish Alker-Jones, Oct 30, 2003
  4. Matt Palmer
    I had the same problem with Nameless Boy the other day. I'd just
    discovered and fixed the case of the oil leak[1] and put the fairing
    back on, when I discovered that the blinkers wouldn't work. Then the
    headlight stopped working.
    It turned out that I'd snagged the right switchblock's cable while I
    was replacing the tank, and unplugged it from the rest of the wiring
    harness.
    As for the horn, while my mate Scotty was up here to pick up his
    GPz500 I waited until he was plugging the speedo cable into the wheel
    hub before sounding the horn and deafening him. Then when he got home
    to Melbourne and took it in for a roadworthy it wouldn't work any
    more. It happens. ;-)
    [1] A faulty alternator-cover gasket from new, which dripped onto the
    hot header pipe.
    BT Humble, Oct 30, 2003
  5. Matt Palmer
    Disconnect the spade lugs from the horn, and hook a test light up to
    it. Doesn't take too long, and in my mate's case the actual horn unit
    was faulty.
    Shut the hell up, Conehead/Hammo/Clem/Mick/Pat!
  6. Matt Palmer
    Matt Palmer Guest
    BT Humble is of the opinion:
    I've got a fair idea of how to work out what the problem is, I just couldn't
    be arsed.
    - Matt
    Matt Palmer, Oct 30, 2003
  7. ......................
    Silent Pat
    Pat Heslewood, Oct 31, 2003
  8. *Buys Matt another Rohypnol Cruiser*
    Poofman Pat
