IQ scores
Discussion in 'UK Motorcycles' started by Lozzo, Sep 27, 2006.
  1. Lozzo
    TMack Guest
    TMack, Sep 27, 2006
    #41
  2. Lozzo
    The majority of the HA wouldn't realise until they were eating tarmac.
    Pip, Sep 27, 2006
    #42
  3. Lozzo
    TMack Guest
    Utterly meaningless bollocks propagated by a racist loony. The whole point
    of an IQ test is that is is standardised on a particular population - it is
    very dubious practice to try to compare results for different populations
    where there are substantial language and cultural difficulties as these will
    influence interpretation of test items and possibly influence other aspects
    such as motivation and perseverence. There is no effective way to control
    for such variables. Even the so-called culture-free tests have intrinsic
    bias. I suspect that we Northern Europeans might not fare so well on IQ
    tests devised by, say, the Bushmen of the Kalahari or by the Inuit.
    TMack, Sep 27, 2006
    #43
  4. Lozzo
    Mine was measured as 178 under exam conditions (quite a while ago.) If
    that doesn't prove that IQ means **** all, I don't know what does.
    ogden, Sep 27, 2006
    #44
  5. Lozzo
    TMack Guest
    Using which standardised test? I am curious because WAIS III (one of the
    most common adult tests) is maxed out at IQ 155. If tested as a child
    using the WISC (which maxes at 266 for 6 year olds and then has a decreasing
    potential maximum therafter) you should have shown the overall ability of an
    average 16year 11month old at age 9y 0m. You would be one of the top 60 or
    so most intelligent people in the UK - ahead of most Nobel prize winners and
    university professors.
    TMack, Sep 27, 2006
    #45
  6. Spete wrote:
    Heh. Dogweed, perhaps?
    prawn in the pub, Sep 27, 2006
    #46
  7. Lozzo
    TMack Guest
    Which standardised test?
    TMack, Sep 27, 2006
    #47
  8. Indeed. I'm quite good at all this IQ malarkey and apart from the fact
    I can sail through wanky programming and logic tests and get hired, I
    don't see the point of the IQ measurement system at all.
    <fx: re-thinks strategy>
    #48
  9. Lozzo
    No idea. Just dug out the cert (sad, huh?) and it says:
    "MENSA CERTIFICATE
    This is to certify that <insert name here> has taken the Mensa
    Supervised Test and achieved a score of 178 which is attained by 1 per
    cent of the population. This score gives a true IQ rating.
    Harold Gale BA
    Executive Director"
    I was about 14 or 15 when I did it, iirc. Had no interest in joining
    MENSA, just did one of those little puzzles in the back of the Radio
    Times once and it got me wondering. I was certainly no slouch in the
    bonce department at the time, but a few years of fairly fast living in
    my early/mid 20s blunted the scalpel somewhat.
    ogden, Sep 27, 2006
    #49
  10. Lozzo
    TMack Guest
    IQ of 148 in Cattell tests correspond to an IQ of 130 in Wechsler tests.
    TMack, Sep 27, 2006
    #50
  11. From my limited experience, IQ tests measure the ability to solve
    abstract problems. This ability has very limited use in the
    world-at-large. Tbe abiilty to solve abstract problems *should* inform
    people to *run away* _FAST_. Quite how it is so revered is beyond my
    ken.
    #51
  12. Lozzo
    Eiron Guest
    ogden wrote:
    Ah, the old 'take the test as a child to artificially boost your score' trick!
    From the Densa website:
    "A middle aged adult can only get a maximum IQ of 161 on the Cattell IIIB test."
    Eiron, Sep 27, 2006
    #52
  13. Lozzo
    DR Guest
    I've never heard of genuinely gifted children being considered
    'special needs' in state education. From my own experience, the
    Special Needs department of the comp I went to was dedicated
    exclusively to the school window-lickers. The education system is
    geared to producing a barely-acceptable mediocrity, and if you don't
    fit, tough shit.
    DR, Sep 27, 2006
    #53
  14. Lozzo
    Let me translate Rope's post for you.
    "My kids have all been lumped under 'special needs', but their mum says
    they're above average intelligence, so there must be something wrong
    with the education system."
    ogden, Sep 27, 2006
    #54
  15. Lozzo
    Rope says...
    There's no degree value when measuring in Kelvin units.
    Lozzo, Sep 27, 2006
    #55
  16. Lozzo
    Maybe not.
    273.14.
    Approximately.
    Pip Luscher, Sep 27, 2006
    #56
  17. Makes a change from factory fodder, I suppose. That's only because of
    the lack of factories, these days.
    Innit da troof.
    Grimly Curmudgeon, Sep 27, 2006
    #57
  18. Which is the odd grub out?
    Spot the leopard.
    Which polar bear is nearest and which is smallest?
    Which chief's daughter do you ****?
    #58
  19. Lozzo
    DR Guest
    Sort of, I can see what you mean. My point is that there is little or
    no extra help for those most able to benefit from it; there will
    always be the exceptional few who don't need it to excel, and good
    luck to them. IMO, however, those just above average, who have the
    potential to be so much more, are held back by the system, not helped
    up.
    DR, Sep 27, 2006
    #59
  20. Lozzo
    TMack Guest
    Cattell test - your score would probably be around 150 in Wechsler scales
    which is still impressive but not in the "one in a million" category that
    the raw score implied. There is also a problem if the test is supervised by
    an organisation that is keen to expand its membership rather than by a
    qualified professional who has no vested interest in the outcome.
    The problem with quoting scores without quoting the test is that different
    tests use different ways of rating intelligence. Also the tests do not
    fully correlate - for example the Cattell only has about a 0.72 correlation
    with the Wechsler scales. In the UK professional psychologists tend to use
    the Weschler scales or, for children, the British Ability Scales, both of
    which give lower scores than the Cattell.
    TMack, Sep 27, 2006
    #60
