I've looked at the aquaboxen, but they don't appear to be ipaq 5550-sized. Has anyone any other sensible ideas, apart from the top of the tank bag? -- Cheers! Fr Jack B12S (The Red Mist), CB450DX (The Moped) FRJACKUKRM AT GMAIL DOT COM Red death, to set you free
I've looked at these cases for my xda, not found a mounting device yet though. http://www.proporta.com/F02/PPF02P05.php?t_id=1077&t_mode=des
Been there - but you may notice a lack of waterproofing. And these: http://www.ram-mount-uk.com/aqua.htm don't fit. -- Cheers! Fr Jack B12S (The Red Mist), CB450DX (The Moped) FRJACKUKRM AT GMAIL DOT COM Red death, to set you free
Bit bloody steep, that is. -- Cheers! Fr Jack B12S (The Red Mist), CB450DX (The Moped) FRJACKUKRM AT GMAIL DOT COM Red death, to set you free
Will do...ta! Tried, earlier at work, but it didn't want to play..... See if I have more luck, now. -- Cheers! Fr Jack B12S (The Red Mist), CB450DX (The Moped) FRJACKUKRM AT GMAIL DOT COM Red death, to set you free
I'm doing exactly the same for a Medion MDPNA100. There are generic cradles you can get and mounted using the ram mount components, the real problem though is getting a waterproof housing of the right size. I'll let you know if I manage to get anything sorted. -- jeremy '01 Triumph Sprint ST in green _______________________________________ jeremy0505 at gmail.com
Ah that looks good - I didn't see a spec on that site - I am looking to mount a Medion MDPNA100 (74mm wide x 20mm deep by 150mm (to tip of antenna)) - any info on the max dimensions it can accommodate? E-mailing brodit.se -- jeremy '01 Triumph Sprint ST in green _______________________________________ jeremy0505 at gmail.com
What type of bike are you planning to mount it on? I think it is designed to mount directly on the bars - this won't work for me anyway as there is no room on the bars for such a bracket. I am looking at stuff that mounts onto the tank bolt. -- jeremy '01 Triumph Sprint ST in green _______________________________________ jeremy0505 at gmail.com
ATM I use a RAM mount on my K1100 LT, subject to further investigation, the Brodit thing would replace it.
Thanks, Darren. Silly me for not x-posting to the GPS group! -- Cheers! Fr Jack B12S (The Red Mist), CB450DX (The Moped) FRJACKUKRM AT GMAIL DOT COM Red death, to set you free
