In need of a good service?
Discussion in 'UK Motorcycles' started by Lady Nina, Mar 19, 2008.
  1. Lady Nina
    Lady Nina Guest
    Went to start it, strong turning over, no catching. Jump up and down
    in frustration, aim kick at swing am, try one last time, it catches.
    Go and put air in tyres, think 'you'd better not mess me around
    again', it starts no problem.
    Just shy of 100 miles later, [1] pull into the Tescos just down the
    road, come out, not even thinking about the previous issue and it
    refuses to start again. Swear, attempt to bump start, get hot and
    sweaty, give up, phone Aunty Carol.
    Sitting on the bike having a fag get chatting to a bloke about bikes,
    how he hasn't got one any more
    'too many kids'
    'that's an ideal reason to have one'
    He decides that actually he really should get a bike again, I say
    'I've obviously broken down just to convince you of this'. As he gets
    in the car I try one more time, it starts. Phone Aunty Carol, cancel
    recovery, come home.
    So, why is it messing me about? New spark plugs required? If so surely
    it wouldn't start with ease sometimes and not at others. Airlock has
    been suggested, any other ideas?
    [1] I headed north east rather than my usual west or south west, loads
    of roads have lowered speed limits since I was last out that way, road
    surface is awful once you get over the border into Notts and the
    stomach lurches you get when you think you are about to slide sideways
    on a very tight left hander are nowhere near as pleasant as the other
    sorts of stomach lurches.
  2. Lady Nina
    It needs the spiccy wand waving over it
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 19, 2008
  3. I'll let others go though the fault finding flowchart with you.....
    I had to visit Staffs LA in Hixon last week, by eck there are a shedload of
    speed cameras up there !
    Never seen so many in my life.
    Brownz @ Work, Mar 19, 2008
  4. Lady Nina
    Lady Nina Guest
    Madam is relaying the information as I type. There and back in a day
    would be good as I have to go to Portsmouth on the Wednesday evening.
    How long do shims take anyway?
  5. Lady Nina
    3 hours ish by the time you've taken all the bodywork, radiator and
    shite out of the way.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 19, 2008
  6. Lady Nina
    Lady Nina Guest
    OK I'll leave early and aim to be with you by 10am.
  7. Lady Nina
    antonye Guest
    Sounds like petrol to me - taking a long time to turnover suggests
    that the petrol isn't getting in quick enough. As it's turning over
    and it does start (eventually) it rules out things like electrics,
    battery, sparks, etc.
    I don't think it's an airlock in the breather as it runs fine once
    it starts. I would check your petrol filter for blockages, replacing
    it if it hasn't been done in a long time. You may also have some
    water in the tank from condensation build up over the winter? Remove
    tank, drain, let it air for a bit while you change the petrol filter,
    give it a wipe round and then refill with petrol.
    Also check obvious things like kinked petrol lines from the tank
    as it is sometimes easy to trap them when they go back on, but again
    it would suggest it not running at all/ dying when on full throttle
    rather than not starting.
    antonye, Mar 19, 2008
  8. Lady Nina
    That's cool. I can get oil and filter up the road, they keep them in
    stock. You'll need a new air filter too while we're at it. You going to
    source that, or shall I order one tomorrow from up the road? They aint
    cheap cos I doubt there's a pattern one available for your bike.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 19, 2008
  9. Lady Nina
    dog Guest
    don't do it too often, you'll go blind.
    dog, Mar 19, 2008
  10. Lady Nina
    Lady Nina Guest
    Oil and filter were changed, um about 2 to 3K ago so yes.
    Order air filter from up the road please.
    Spark plugs?
  11. Lady Nina
    Lady Nina Guest
    Or left over snow and ice from the elephant. It's been out 3 times
    since the end of January.
    <nods again>
    Thanks.
  12. Lady Nina
    I can get plugs up the road or in Luton.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 19, 2008
  13. Lady Nina
    Air filter is a washable foam one, so not buying a new one. Plugs are
    about 36 quid though, so that's taken up the saving on the air filter.
    At least they are in stock up the road.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 19, 2008
  14. Lady Nina
    Careful of his euphemisms, Nina.
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Mar 19, 2008
  15. Lady Nina
    prawn Guest
    To be fair, the subject is overloaded with euphamism. I think the Gel can
    take it,
    prawn, Mar 19, 2008
  16. Lady Nina
    Lady Nina Guest
    I'm not taking his spiccy wand!
  17. Lady Nina
    Pete Fisher Guest
    In communiqué
    The trouble with you youngsters is that you have never worked on SO
    Italian bikes with true CDI ignition [1]. Never rule out a weak spark
    ignition problem until proved otherwise.
    Though fuel ills may well be the most likely diagnosis on a modern bike
    with the symptoms described.
    [1] e.g. Morini and early Gilera Nordwest. Both can eventually and
    randomly start if turned over long enough and fast[2] enough to get
    lucky with a viable spark if the charging coil in the stator is
    sub-optimal.
    [2] Which can be a function of battery state or fatigue of kick starting
    leg.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 19, 2008
  18. Lady Nina
    There's plenty that have and plenty that will.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 19, 2008
  19. <snip>
    What bike is it?
    The Older Gentleman, Mar 19, 2008
  20. Lady Nina
    Chain and sprockets?
    platypus, Mar 19, 2008
