improving performance
Discussion in 'Motorbike Technical Discussion' started by James Cohern, Feb 29, 2008.
  1. James Cohern
    James Cohern Guest
    What is the least expensive way to improve the performance of a v twin
    motorcycle. I own a Vulcan 900, which has a top speed of 105 mph. I am
    not sure why is so slow at the top end. I have considered changing
    pipes, changing the air intake system, getting a commander that will
    change the timing of the fuel injection, or changing pulleys in increase
    top speed, but would lose acceleration.
  2. James Cohern
    Because it's not a high-performance engine for starters.
    It's the old saying - "speed costs money, how fast do you want to
    spend?"
    Playing with the exhaust and air intake, plus tweaking the FI may make a
    noticeable difference, but $deity only knows if it's worth the cash.
    Timo Geusch, Feb 29, 2008
  3. James Cohern
    . Guest
    Adjusting the stock camshaft timing. This is called "degreeing the
    cams".
    You will lose a little "low end torque" and gain more top end
    *horsepower*.
    I recommend that you find a web-based site dedicated to Vulcans and
    *carefully* read what the knowledgeable-sounding owners have to say.
    I don't know the details of your machine, but it's possible that your
    engine has a RPM limiter to stop it from revving any higher than it
    does, or if the cam shafts are set up to have zero overlap to meet EPA
    rules.
    If you can find out what the cam timing specifications are, you might
    be able to get a little more power out of the engine by retarding the
    exhaust cams and advancing the intake cams a few degrees to raise the
    power peak.
    This is usually done by removing the camshafts, unbolting the
    sprockets, and filing the bolt holes oval so you can move the
    sprockets in relation to the camshafts.
    ., Feb 29, 2008
  4. James Cohern
    TOG@Toil Guest
    Sell it and buy a cheaper faster bike. Seriously.
    TOG@Toil, Feb 29, 2008
  5. James Cohern
    Mark Olson Guest
    Exactly. Why do people buy bikes that aren't designed to go fast
    and spend lots of money to get them to do it, when there are bikes
    made with _very similar designs_ that will go much faster, for about
    the same money? And if performance was your object to begin with,
    why not buy a bike that goes fast, is comfortable (assuming someone
    who buys a Vulcan doesn't want a "crotch rocket") and handles
    quite well, too?
    Not that there is anything at all wrong with a Vulcan 900, a nice
    bike if you like that sort of bike, and a 105 mph top speed is
    certainly adequate for normal usage everywhere except the Autobahn
    or Autostrada.
    Mark Olson, Feb 29, 2008
  6. James Cohern
    T.Alan Kraus Guest
    What do you want to do? Go way past 105 or be fast on your take off.
    If it is going way past 105, gear up with sprocket changes and put an
    egg shaped faring on the bike you can hide behind. Frontal area air
    resistance is your enemy. If you want to take off fast also, than you
    need a tranny with more gears and the right ratios. 900 cc should be
    enough power to take you past 200mph with an aerodinamically correct bike.
    T.Alan Kraus, Feb 29, 2008
  7. And the A21 on my way to work...
    ....oops. What a giveaway.
    The Older Gentleman, Feb 29, 2008
  8. Rob Kleinschmidt, Feb 29, 2008
  9. James Cohern
    Mark Olson Guest
    UKRM anecdotal reports of lucky escapes/flagrant hoonery notwithstanding,
    is it not true that if you are nicked at over 100 mph in the UK you are
    facing a likely ban, just as you are in my home state?
    http://www.drivingban.co.uk/driving...n_100_mph_on_the_motorway._Is_a_ban_automatic
    http://www.house.leg.state.mn.us/hrd/issinfo/ssspdlt.htm#Q4
    Still grinning over the memory of darsy and adie's videotaped antics w/
    plod commentary.
  10. James Cohern
    oldgeezer Guest
    And the rear fender looks mandatory.
    oldgeezer, Feb 29, 2008
  11. It's likely, yes. Not a certainty, but likely. That's assuming 100mph in
    a 70mph zone, of course. If you're up for 100 in a 60, let alone lower,
    a ban is a near-certainty.
    To counterbalance this, many TrafPol (especially bike Plod) will
    actually put on the ticket that you were doing (say) 98mph instead of (a
    true) 100+, as long as you were riding fast in a safe manner and not
    being a ****.
    This is because they know that speed in itself isn't dangerous and that
    a ban would be unfair. I've escaped a ban once because of that, and a
    certain speeding penalty on another two occasions[1].
    Seriously, bike Plod tend to be very lenient - as long as you're not
    being a....
    [1] One of these involved a friend and myself doing 100+ speeds in a 60
    limit, early one sunny Sunday morning.[2]
    [2] And was the inspiration for my TOG tag. In the eyes of the bike cop
    who eventually caught up with us, I was "an older gentleman who should
    know better. Now off you go." :)
  12. The Older Gentleman, Feb 29, 2008
  13. LOL!
  14. I really don't want to look at it or think about it or find
    out how to bid on it.
  15. James Cohern
    Ford Perfect Guest
    Look no farther. If you have PULLEYS, that's your problem !! ;-)
    Seriously, if you really think you need to go faster than 105......on a
    cruiser, no less......then SELL IT AND BUY SOMETHING WITH MORE POWER.
    Or pour a shit load of money and time into it, only to find that <gasp> it
    will never be a race bike.
    IOW, get serious.
    Ford Perfect, Feb 29, 2008
  16. Heh. A very sensible reaction, sir. I understand Lawrence of Arabia's
    Brough is also extant.
    The Older Gentleman, Mar 1, 2008
  17. James Cohern
    Ian Singer Guest
    Castration helps the aerodynamic too. After all bulges slow you down
    Ian Singer, Mar 1, 2008
