Import a Yam WR 250 F
Discussion in 'UK Motorcycles' started by Denis Crespe, Sep 18, 2003.
  1. Denis Crespe
    Denis Crespe Guest
    Hello Guys,
    I own Yamaha WR 250 F and I'd like to bring it from the US to the UK. Does
    anybody know if there is any differences between Us and European models ? I
    want to make sure I could find parts there.
    Thank you,
    Kevin.
  2. Denis Crespe
    Denis Crespe fascinated us all by saying...
    US models are left-hand-drive. The throttle housing, clutch lever, front
    brake lever, gear change and rear brake lever will all need to be swopped
    from where they are now, to the other side of the machine.
    The seat will need to be modified so you can sit backwards on the
    machine, and a fair amount of cerebral tuning will need to be undertaken
    to ensure you can ride at above 55mph.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14.
    www.mjkleathers.com
    Lozzo, Sep 18, 2003
  3. The difference in the fuel between there and here will affect the
    handling of the machine. American 'gas' contains right-wing biasing
    effector additive which the bike is designed to cope with; running it
    on British fuel (petrol) will rob the bike of this influence and cause
    it to want to veer left all the time, with you ending up in the
    ditches and hedges quite a lot.
    Not worth it, not if you value your sanity.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Sep 18, 2003
  4. Denis Crespe
    Sean Doherty Guest
    Don't forget that tires don't grip on our roads and I think that
    having a muffler is illegal.
    Sean Doherty, Sep 18, 2003
  5. Denis Crespe
    linger Guest
    In
    Make your mind up it was France earlier ;-)
    linger, Sep 18, 2003
