I'm not impressed with the new 2010 NT EU Maps
Discussion in 'UK Motorcycles' started by Greybeard, Jun 1, 2009.
  1. Greybeard
    Greybeard Guest
    Updated my Zumo 550 a couple of weeks ago now, and have been using it on
    routes I do fairly regularly. Whereas the route I used was exactly as the
    Zumo chose and would be the fastest/most efficient one, the new maps routing
    sends me off in the most weirdest of directions.
    Very odd routing off the M25 (UK) using A & B roads that are a long way from
    what I would have expected.
    I've checked my settings and all is correct, nothing changed from previous.
    Today, I borrowed a colleagues Zumo, that has also been updated, and that
    too sends me way off of the direction I should be going.
    So, IMHO, it looks like the road priority calculation used for routing is
    screwed.
    I'm looking at restoring the old mapset now, as it "works"!!
    Any body else find this an issue?
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy 2!)
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
  2. Greybeard
    Colin Irvine Guest
    Nope. Are you using the latest firmware? Does the route come out
    different using mapsource? Can you give me an example to try?
    Colin Irvine, Jun 1, 2009
  3. Greybeard
    Greybeard Guest
    Everything is up to date, according to the Garmin website.
    Mapsource does a lot of things differently to the Zumo.
    Route today, was to Thames ditton from Saffron Walden
    Started off by trying to send me up the A1M, I stayed on the M25, then
    messed me about all the way until I made my usual turn on to the A3 where it
    finally decided the "correct" route.
    Although when you look at the route on Mapsource, it seems the most direct
    way, it most certainly is not the fastest!!
    Before updating the maps, it "always" sent me the way I would normally go,
    hence I use that route, which would be the M25, A3 and then wiggle through
    the last couple of miles.
    Coming back was even more erratic!
    Had a chat with a Cabbie friend, and the route he suggested straight away
    was my usual one via the A3.
    At my first guess, I would say that the code crunchers have changed the road
    timings and priorities. The did this with an earlier set of maps, and then
    at the next update it all changed back again properly.
    This is not the only route that it has changed from previous, but every one!
    It didn't like the idea of me coming home on Sunday via Finchingfield, not
    that I could fault that really as the place was jammed with bikes to the
    point that getting on the Samford Road proved a navigation nightmare! :eek:)
    (not the GPS Fault on this occasion!)
    It's not unusable, but it is bloody annoying when it tells you a different
    route and not a better one, from what it's been telling you for the last
    couple of years or so!
    Greybeard
  4. Greybeard
    Gyp Guest
    It was able to recognise both the roads in Scotland then...
    That reminds me, I better magic you some money
    Gyp, Jun 1, 2009
  5. Greybeard
    Colin Irvine Guest
    Mapsource says the way it tried to send you takes 1h 32m and via the
    A3 takes 1h 39m. Googlemaps has little difference between the two
    routes. You'd need to time both routes yourself a number of times to
    have any idea which actually is the quicker - and of course the answer
    may differ bewteen bike and car.
    I'm sure you're right. And UK roads always seem to cause timing
    problems for Garmin and/or their map supplier.
    "Better" is in the eye of the beholder. Anyway, GPS is only for
    guidance. If you have a favourite route why not save it in the Zumo
    and use it?
  6. Greybeard
    Greybeard Guest
    Without a doubt, on all counts.
    Shame it's got a little cock-eyed coz it used to be very reliable. Things
    will back to "normal" in the release, no doubt.
    TBH with the code crunchers efforts, it may only take one road to have been
    miss-calculated on either a speed limit or distance issue to screw up the
    maths.
    I'll keep a keen eye on it for a while.
    Greybeard
  7. Greybeard
    <snip>
    Oh great, I hope the 2010.1 US maps are better, otherwise I'll be
    getting lost near Mickey Mouse a-fucking-gain tomorrow.
    You'd think I would have sussed out how to get from Orlando to the
    parents in law's place by now without either getting stuck in downtown
    Orlando or accidentally going via Cape Canaveral...
    Timo Geusch, Jun 1, 2009
  8. Greybeard
    those trailer parks all look the same...
    wessie, Jun 1, 2009
  9. Greybeard
    Indeed, and it's flatter than the Norfolk broads, too.
  10. Greybeard
    Gyp Guest
    Hope you've got a commode
    Gyp, Jun 2, 2009
  11. Greybeard
    Paul - xxx Guest
    Biggest issue is why bother using it on a route you already know?
    Paul - xxx, Jun 3, 2009
  12. Greybeard
    Seth Guest
    Sometimes I may be in thought and the GPS speaking up reminds me my exit is
    approaching.
    Seth, Jun 3, 2009
  13. So that when you're using it on a route you don't know, you'll have
    confidence in it calculating correctly?
    Owen McKenzie
    Posting from Pigeon Forge, TN
    As soon as you see the light at the end of the tunnel along comes a
    gov't program to lengthen the tunnel!
    Owen McKenzie, Jun 3, 2009
  14. Greybeard
    Gyp Guest
    I find it useful for being able to answer the "how long before you get
    home" question without having to think. And now I've got the Scraggy
    insert thingy, it tells me when there's hold ups en route too.
    Anyway, you can only record a high score when it's switched on, and if
    it's switched on you might as well keep it busy.
    BTW, currently the main to boxes are showing as follows:
    2610 = 125
    Zumo = 119
    Gyp, Jun 3, 2009
  15. Greybeard
    Greybeard Guest
    It's always handy as an aid. Timing etc should I need to let the customer
    have an updated ETA. It's also very handy, should I need to detour in a
    hurry for whatever reason.
    Oh, and the speed cam warnings are pretty useful too ;o)
    Greybeard
    Greybeard, Jun 3, 2009
  16. Greybeard
    Paul - xxx Guest
    OK, OK, all very good reasons ... which I obviously hadn't thought of
    <small voice>
    You're all bastards ...
    </sv>
  17. Greybeard
    Colin Irvine Guest
    Except that Garmin's timings in the UK are well known to be
    optimistic, so you need to be used to its standard error before you
    can use for this purpose.
    Colin Irvine, Jun 3, 2009
  18. Greybeard
    Greybeard Guest
    Oo my, I seem to have been promoted from a ****...
    But then, maybe??
    Greybeard
  19. Greybeard
    Greybeard Guest
    I can't agree with this.
    I normally find that the Garmin is uncannily correct, if you stick or get
    the opportunity, to stick to the speed limits.
    Take traffic [1] out of the equation and it's bloody good.
    [1] It's also bloody good if it get's the right info from the GTM, but that
    in itself, can be fucking _way_off!
  20. Greybeard
    Garmin times are the tightest out of the four different sat navs I've
    owned and you've got to be either living in a dreamworld or constantly
    breaking the law to hit them.
    Andy Bonwick, Jun 3, 2009
