I'm glad I didn't drive to Pembrey
Discussion in 'UK Motorcycles' started by Paul Carmichael, Sep 7, 2003.
  1. Paul Carmichael
    Simian Guest
    Andy Bonwick :
    Ho hum.
    If you need any bits, I should have a spare engine by next week.
    Simian, Sep 7, 2003
  2. Paul Carmichael
    Simian Guest
    The Older Gentleman :
    Sump. There isn't anywhere else for them to be.
    Simian, Sep 7, 2003
  3. Suppose so, yeah.
    The Older Gentleman, Sep 7, 2003
  4. Paul Carmichael
    Ginge Guest
    Easiest route out if the engine is anything like the layout of other
    stuff I've seem, they could drop straight down where the camchain runs
    and find a new home in the sludge..
    Ginge, Sep 7, 2003
  5. <fx: sucks teeth>
    Ordinarily I might agree. I still might agree. It just seems too much
    like coincidence.
    It's not like the engine had ever been starved of lube or anything,
    which might have damaged the bearing - the cam lobes were like new. No
    visible wear at all.
    It's all ending happily, anyway. Simian's got a decent engine cheap, his
    bottom end and/or crankcases will presumably go to Team Ukrm, but I
    really, really want to know what it let go.
  6. Paul Carmichael
    Alan.T.Gower Guest
    That is quick.
    Yes since they would get better reliability.
    If is finishing is the priority then maybe.
    Last year was all about learning and despite what's happened you had to
    go for it this year and I personally applaud you for that. You've had
    some bad luck.
    Alan.T.Gower, Sep 7, 2003
  7. Paul Carmichael
    Alan.T.Gower Guest
    Speaking as someone who got re-ended at Pembrey last year I wouldn't
    recommend it.
  8. The Older Gentleman said:
    How is oil fed to the bearing?
    Simon Atkinson, Sep 7, 2003
  9. Splash lube from the general top end? Ball races don't need pressure
    lube.
    Oil strvation would nadger the cam lobes and plain bearings first IMHO.
  10. Paul Carmichael
    Andy Wegg Guest
    The Older Gentleman muttered
    Always a shame to see the Dukes blowing up. That was the great thing
    with the 'prilly mille first time out - I counted them out,and I
    countedthem home....huh? All the entered Italians V twins home? Huh?
    R1, mate. '99 24hr at Oschersleben when the Endurance regulars like
    Phase 1 were still building "Superbike" class machines, the R1 was
    allowed in the Stock class with slicks for the first time. First
    place, not in class, on the track.
    Before that the bikes at the front were superbikes - the Phase One
    Gixer 750 was not "stock" ( for example), no sirree.
    Andy Wegg, Sep 7, 2003
  11. The Older Gentleman said:
    Prolly I suppose. I wondered if it was fed via a drilling in outer race
    and the drilling wasn't matching up with the drilling in the head. Just
    a thought, but as you say, ball races want plenty of oil flow, but don't
    (obviously) build any pressure.
    I agree - if that's the way the oil gets into the bearing. Just a
    thought.
  12. Paul Carmichael
    Alan.T.Gower Guest
    No but I had been sitting close to SimonB, perhaps some of his smell
    rubbed off on me?
  13. Paul Carmichael
    Platypus Guest
    You should have given me a bell. I've got an old Kawasaki in the back
    of the shed you could have borrowed.
    Platypus
    VN800 Drifter, R80RT
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Sep 7, 2003
  14. Paul Carmichael
    petrolcan Guest
    Arse! Oh well, the gloves will last longer.
    Commiserations to all especially Alex.
    petrolcan, Sep 8, 2003
  15. Cnut ;-)
    Well, it was a joint effort, and if we did make a mistake, we did it by
    following the Haynes BoL assiduously.
    <fx: light dawns>
    But basically, yes. If we did something wrong, I want to know what it
    was because neither Simian, myself, Champ nor Wheelpower can figure it
    out.
    The Older Gentleman, Sep 8, 2003
  16. Paul Carmichael
    dwb Guest
    Halfords are hiring?
    dwb, Sep 8, 2003
  17. Heh. Nope. Only things that came loose were the dowels for the cam cap
    and the clips to hold the bearings in place, and we replaced them.
    I'm now tending more and more towards Muck's suggestion: the bearing was
    on the way out and went at the most embarrassing time possible. In other
    words, Law of Sod.
    I'm certain it wasn't the tensioner - but I've asked Simian to check the
    surface of the slipper blade. 50 miles of running with a severely
    over-tightened camchain will have worn away the slipper surface, right
    down to the metal.
  18. Paul Carmichael
    Alan.T.Gower Guest
    You love danger doncha?
    Alan.T.Gower, Sep 8, 2003
  19. Paul Carmichael
    porl Guest
    And yet with less and less resources to pursue it. You do realise you'll be
    reduced to playing Irish Roulette [1] don't you?
    [1] A variation of the classic Russian game of risk whereby you hit yourself
    over the head with a stick six times, once very hard.
    porl, Sep 8, 2003
  20. Champ said:
    You don't subscribe to the well proven 'hare and tortoise' school of
    endurance racing then?
    Simon Atkinson, Sep 8, 2003
