I'm Freeeeeeeeeeeee
Discussion in 'UK Motorcycles' started by steve auvache, Sep 23, 2004.
  1. Gosh that was good.
    Slow, plenty of vibration and excitement from the most unusual places
    but good.
    I've never had a gearbox with neutrals between each gear before.
    Occasionally two.
  2. steve auvache
    Donegal Paul Guest
    "steve auvache" said
    I had this vision of Mrs Slocombe at the till there for some reason :)
    Donegal Paul
    Lambretta Li186 - crashed and bashed
    Vespa T5 Millenium - Wifey's (technically)
    www.thepilgrimssc.co.uk
    www.a4c.co.uk - What are YOU doing?
    www.ailishandcharlie.co.uk
    Donegal Paul, Sep 23, 2004
  3. steve auvache
    Donegal Paul emerged from their own little world to say
    Has Auvache gone for the purple rinse then?
    wessie, Sep 23, 2004
  4. steve auvache
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, steve auvache
    Oh bless. Welcome back, aged one.
    Honda GL1000K2 Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Nigel Eaton, Sep 23, 2004
  5. wessie wrote
    Still grey and still proud of it.
  6. Donegal Paul wrote
    But you won't catch me stroking my pussy.
  7. Nigel Eaton wrote
    I am a tired but happy little bunny now. So I am going to have a cuppa
    and a wicked spliff and annoy you lot for an hour and go to bed.
  8. steve auvache
    mups Guest
    steve auvache says...
    Heh, I know what you mean. I rode it for about 10 mins on the way back
    from Frankfurt. I must have found about 15 different gears and most of
    them didn't involve forward motion. Felt remarkably sporty tho, which
    was a surprise.
    mups, Sep 23, 2004
  9. mups wrote
    Provided you plan well ahead and are in the right neutral the handling
    is surprisingly smooth. It quite likes being slung through a roundabout
    chicane with a bit of enthusiasm. Opening up the throttle on the exit
    is a lesson in patience though.
  10. steve auvache
    Don't shut off. If nothing else, that was the lesson from the Frankfurt
    run.
    platypus, Sep 23, 2004
  11. steve auvache
    The endless French roundabouts; one of the bits Sean wanted Tony to film.
    Shame we never got our act together for it but time was against us [1].
    It's an abiding memory of that run. Four little bikes throttles jammed
    open whizzing through empty, smooth, clean roundabouts banging pegs on
    the floor.
    Never thought I'd say it but ground clearence was a *real* problem on the
    TS - the fixed pegs unloaded the backwheel once or twice.
    Incidentally on gearchanges: slowly and positively; "feel" the dogs
    engage. I hardly get false neutrals, just practice though.
    [1] Perhaps it wouldn't have been the same if we'd all stopped and
    got organised for filming. The whole very snatched, shaky and
    almost grainy footage Tony took sums up the whole weekend.
    sweller, Sep 25, 2004
  12. sweller wrote
    I am adopting the two step approach, rather like the double de clutching
    of old, one tweak of the boot to get it out of gear and another to put
    it in the next one. The second action has to be the gentle one as a bit
    too much enthusiasm and you go straight through the gear to the next
    neutral. Which is a bugger when you are doing you best to out drag
    kiddies scoots.
    steve auvache, Sep 25, 2004
  13. steve auvache
    Nidge Guest
    snip
    Fortunately my experience of thier roundabouts was also mostly that they
    were empty.
    I say fortunately advisedly as I never was really sure on Frog roundabouts
    whether you're s'posed to circulate clockwise or counterclockwise. On the
    logic picking the wrong one would be 100% risk exposure I either followed
    something else (they mostly seemed fairly random about which way to go too)
    or alternated clockwise - counterclockwise. People seemed to follow me too.
    In both directions.
    Which is the official you are *meant* to do it this way way?
    Nidge
    ZX6R J2 Stunning in zit yellow. KX 125 MX 'I'm snot green -fly ME'. A few
    bits of CB500S in Norwegian Parrot blue. BOTAFOT#63 BOMB#5
    'Just because I don't care doesn't mean I don't understand'.
    Homer (Simpson).
    Nidge, Sep 25, 2004
  14. steve auvache
    SteveH Guest
    Surely no-one can be this stupid?
    SteveH, Sep 25, 2004
  15. steve auvache
    Statto Guest
    This is the man with a broken main beam switch.
    Statto, Sep 25, 2004
  16. steve auvache
    (SteveH) struggled to ejaculate:
    I just thought that - the only time I can recall sitting looking at
    the screen, jaw agape ... then I realised that this is Nidge the Main
    Beam Man, here.
    Pip, Sep 25, 2004
  17. steve auvache
    Statto Guest
    At last, I get to do this for the first and possibly the last time, so
    I'm going to revel in this one:
    Ginge!
  18. steve auvache
    Arse. Beaten to it by a VFR rider. Arse.
    Pip, Sep 25, 2004
  19. steve auvache
    <blows nose, sneezes>
    If it wasn't for those pesky Paracetamol, ibuprofen, codeine and
    whisky I'd have had you, mo'fo.
    Arse again.
    Pip, Sep 25, 2004
  20. steve auvache
    Statto Guest
    Snot just me then.
    Paracetomol - check
    'profen - swap for Phenylephedrine Hydrochloride
    codeine - swap for caffeine
    The above masquerading as Tesco cold relief capsules.
    whisky - once I've finished this bottle of vino collapso.
    <cough>
Similar Threads
Loading...
