ignition wires get hot went i turn key on //// 91 gsxr 1100
Discussion in 'Motorbike Technical Discussion' started by blkujo, Mar 26, 2007.
  1. blkujo
    blkujo Guest
    why they getting hot for in juss 5 min with the key turned to on
    position ? plus my brights and high beam indicator stay on in my 91
    gsxr 1100 .
  2. Check out your high beam relay. The headlights plug into relays that
    carry the headlight power instead of running all that power through
    the headlight dimmer switch.
    Check to see if you have 12 volts through the switch to the relays.
    Potage St. Germaine, Mar 26, 2007
  3. blkujo
    John Johnson Guest
    It means that you've got a wiring fault. Find it before it burns up your
    bike.
    Later,
    John
    John Johnson, Mar 26, 2007
