Ignition Problem
Discussion in 'Motorbike Technical Discussion' started by strumbiker, May 13, 2006.
  1. strumbiker
    strumbiker Guest
    Hi - I have a Giantco Prince 125cc - which is basically a Chinese copy
    of a Honda CG 125. It's only 6 months old and done 350 miles but has
    had a starting problem.
    When I turn the ignition on, the neutral light doesn't come on and the
    engine won't start on the electric start button (it doesn't even
    click). However the front and rear lights, horn and indicators all
    work fine which suggested the battery is ok. To make sure, I tested
    the battery on another bike and it's fine. I also put a known working
    battery in the bike and exactly the same problem occurs with that
    battery too.
    The engine will start first time on the kickstart though. Then, if I
    run the engine for about 10 minutes and switch the engine off, the
    neutral light comes on and it will start first time on the electric
    start button.
    If I switch the engine off and let the bike cool down for an hour or
    so, the problem starts all over again.
    I thought that maybe the engine warming up was causing some expansion
    somewhere, that was making good a faulty ground connection - which then
    reverted to a faulty connection when the bike cooled down. However,
    I've checked all connections and can't find anything obvious.
    I haven't got a clue about the electrical workings on bikes so would
    appreciate any help.
    Thanks
  2. strumbiker
    Eric Johnson Guest
    I would be willing to be there is a kickstand safety switch on it. The
    neutral switch is probably sticking. If the neutral light is not on, try
    putting the kickstand up and pulling in the clutch while starting with the
    electric starter.
    Eric
    Eric Johnson, May 14, 2006
  3. strumbiker
    strumbiker Guest
    Eric
    You're right, there is a kickstand switch. Do you think it's possible
    the kickstand switch is only working when the bike is warmed up? It
    works fine once the bike has been running a while. (However, this bike
    doesn't need a "clutch-in" start.)
    I've stripped he bike down (fairing, seat & tank taken off) to check
    every cable for breaks or faulty connections so will check the
    kickstand switch first thing once it's all back togeher.
    Thanks for the advice.
    strumbiker, May 14, 2006
  4. That is more in likely it, besides this one too. (Chinese copy)
    ROBERT MILLER, May 14, 2006
  5. Most likely the kickstand switch isn't positioned correctly.
    It could also be that it's been mechaniced on by somebody
    else who also wasn't quite sure what he was doing.
    If at all possible, try to find a service manual and electrical
    schematic. Even if you're not used to reading stuff like this
    it'll still be less painful than trying to work without the manual.
    Rob Kleinschmidt, May 15, 2006
  6. strumbiker
    strumbiker Guest
    Sorry - didn't undestand that. What one too?
    strumbiker, May 15, 2006
  7. Being a copy....
    ROBERT MILLER, May 17, 2006
