Ignition advance
Discussion in 'UK Motorcycles' started by Catman, Feb 6, 2008.
  1. Catman
    Catman Guest
    So I'm confused.
    A mate has just bought and ignition advance unit for his (tuned) Fazer.
    This got us onto the discussion that most engines have ignition retarded
    to cope with low octane fuel.
    But surely ignition should be advanced (earlier) to prevent low octane
    fuel from detonating, or have a got my definition of advanced arse about
    face?
    TIA
    www.cuore-sportivo.co.uk
    Catman, Feb 6, 2008
  2. Catman
    It's about the speed of burn - the higher-octane fuel burns more
    slowly, so the ignition thereof can take place earler, such that the
    main 'bang' occurs at the optimal time. Lower-octane fuel will burn
    more quickly, so the same advanced timing will make the 'bang' occur
    too soon, causing knocking.
    Pre-ignition, or pinking, is a different thing altogether.
    _______
    Ace, Feb 6, 2008
  3. Catman
    Bad form and all, but pinking is in fact another term for knocking,
    which is different from pre-ignition. Sorry.
    _______
    Ace, Feb 6, 2008
  4. Catman
    MikeH Guest
    So pinking isn't a close-up form of dogging?
    MikeH, Feb 6, 2008
  5. Catman
    Catman Guest
    The first answer, and it makes *perfect* sense. My thanks.
    Catman, Feb 6, 2008
