If it isn't broken, don't fix it
Discussion in 'Australian Motorcycles' started by Peter, Apr 29, 2011.
  1. Peter
    Peter Guest
    The ignition on my DR650 was getting sticky so I added graphite powder and
    this has fixed the problem.
    Thought I would give my wife's VTR250 some graphite powder as well.
    Now I am unable to unlock the ingnition.
    Any suggestions on how I can fix what I fixed?
    Peter, Apr 29, 2011
  2. In aus.motorcycles on 29 Apr 2011 09:07:20 GMT
    What does "unable" mean?
    Can't get the key in?
    Key goes in, but won't turn at all?
    Key goes in, turns a bit one way?
    Key goes in, doesn't turn far enough?
    Zebee
    Zebee Johnstone, Apr 29, 2011
  3. Peter
    CrazyCam Guest
    Squirt WD40 through it to wash off the graphite.
    regards,
    CrazyCam
    CrazyCam, Apr 29, 2011
  4. Peter
    atec77 Guest
    Did you live in Brisbane a while back CC?
    atec77, Apr 29, 2011
  5. Peter
    CrazyCam Guest
    No. I have never actually set foot in downtown Brisbane.
    Nearest I have ever been was some big freeway thingy that took us from
    north of Brisbane, past the place and (I think) also past the Gold Coast.
    <insert puzzled look here> What brought that on?
    regards,
    CrazyCam
  6. Peter
    Moike Guest
    You are evil Cameron.
    I like that in a person.
    Moike
    Moike, Apr 29, 2011
  7. Peter
    Peter Guest
    Key goes in, but won't turn at all.
    Peter, Apr 29, 2011
  8. Peter
    Nev.. Guest
    Tried tipping it upside down and shaking it ? :p
    I dunno how locks work but sounds like the graphite might have got into
    the mechanism which spins. Maybe a powerful vacuum cleaner and a bit of
    poking with a key might be enough to dislodge it?
    Nev..
    Nev.., Apr 29, 2011
  9. Peter
    CrazyCam Guest
    ...and I get accused of being evil? :)
    Basics of engineering:
    1. if it's supposed to move and doesn't, apply WD40.
    2. if it isn't supposed to move and does, apply duct tape.
    regards,
    CrazyCam
  10. Peter
    atec77 Guest
    Oh I met some bloke from the group years ago who's bike had problems
    with the valve lash , simply don't remember who it was
    In Brisbane on the south side somewhere
  11. Peter
    atec77 Guest
    Is it the right key ?
  12. Peter
    CrazyCam Guest
    Definitely not me.
    Biggest mob of other aus.moto folk I met at one time was the Netscrape,
    at Phillip Island, but I dunno if there are many that were there that
    still hang around the group.
    It was a long time ago.
    regards,
    CrazyCam
  13. Peter
    F Murtz Guest
    Then put some graphite in to soak up the WD40.
    F Murtz, Apr 29, 2011
  14. Peter
    Deevo Guest
    Mercedes Benz do a small aerosol lubricant specifically designed to be used
    on automotive locks. Last time I recall it was about $25 a can but that
    might have changed now but it always worked a treat.
    Deevo, Apr 29, 2011
  15. Peter
    Deevo Guest
    I'd be a bit cautios of doing that, any hydrocarbon based lube could attack
    any plastics in the mechanism. There's the Benz stuff that I mentioned
    earlier or you could try a silicone based lube.
    Deevo, Apr 29, 2011
  16. Peter
    Peter Guest
    Yes.
    Peter, Apr 29, 2011
  17. Peter
    atec77 Guest
    I would be hitting the lock internally with a good wash , something like
    crc under real preassure or kero
  18. In aus.motorcycles on 29 Apr 2011 10:08:36 GMT
    I presume you have tried jiggling the bars in case something's a bit
    stuck? Some bikes need the bars moved, and it is possible yours has
    just developed that.
    How much graphite went in?
    Does the key feel solidly jammed? as in "If I didn't know better I'd
    think I was turning it the wrong way"?
    Unless you rammed a great deal in, or followed it up with something
    wet (or it was wet in there already) then I find it hard to believe
    the graphite has jammed the mechanical bits.
    Try jiggling the key, noving it up a teeny bit and trying. It is
    possible that one of the pins isn't moving for some reason and you
    need to encourage it.
    Zebee
  19. Peter
    Rod Bacon Guest
    Air compressor.
    Rod Bacon, Apr 29, 2011
  20. Peter
    Moike Guest
    With a jack hammer on the end?
    Moike
    ...oh.. yeah... ;)
    Moike, Apr 30, 2011
