Idling too fast
Discussion in 'UK Motorcycles' started by Eddie, Dec 3, 2006.
  1. Eddie
    Eddie Guest
    I'm sure I've heard of this problem before, but I can't remember what
    the cause or solution is...
    I've started balancing the carbs on the GSX600F. According to the HBoL,
    I set the idle speed to ~1750rpm, and start by balancing 3+4, then 1+2,
    then (1+2)+(3+4), IYSWIM.
    Easy enough, I thought, but: 3+4 were *way* out, and the nearer they are
    to being balanced, the higher the idle speed; like, *really* high,
    So, what's causing that then? I've got a feeling it's an inlet rubber
    problem, but I'm not sure why... any suggestions?
    Eddie, Dec 3, 2006
  2. Eddie
    Moon Badger Guest
    Is there a big difference between 2+3?
    A mate of mine borrowed my carbtune and got it a bit arse about face. He
    wound the centre screw until (3+4) were nearly dragging the mercury to the
    stops and the bike was screaming away at 4,000+rpm. He did get (1+2) in
    perfect balance though :)
    As the revs increased, the balance twixt 3+4 appeared to even out, so he
    dropped the idle on the adjuster until it was fully backed out and carried
    on oblivious. It was only when the engine was screaming he rang me....
    Try adjusting the centre screw to get 2+3 in balance, then the left screw to
    get 1+2, the right screw for 3+4 then a little tweak on the centre screw
    again. I always found that easier on my teapot than 3+4, then 1+2 then 2+3.
    Same on my Bandit, I just find it easier to get to 1/2 a graduation mark on
    the scale doing it that way, YMMV
    Moon Badger, Dec 3, 2006
  3. Idle speed always increases as you balance the carbs. It doesn't matter,
    as long as they're all reading the same. Get them all reading the same
    on the gauges, and then turn down the idle speed.
    The Older Gentleman, Dec 3, 2006
  4. Eddie
    Eddie Guest
    Not now there isn't, no. But that's a bit academic unless I can get the
    idle down to something sensible.
    Hmmm... I'd give it a go, but they're all pretty close now. I'm not that
    fussed about playing about with them again, unless it's going to help
    the idle problem.
    Eddie, Dec 3, 2006
  5. Eddie
    Moon Badger says...
    You really should treat 3 as the datum, try and keep that reading
    constant and not change its height on the gauge. Wind the right screw to
    get 4 to meet it and then adjust 1 and 2 to match each other. After you
    have that sorted you balance the two pairs to match each other by
    adjusting the centre screw.
    It's not that difficult if you don't have air leaks. When I start I
    always wind the tickover up so the bike is at 1,500 revs to start with,
    the engine runs a lot smoother there and makes balancing easier.
    Obviously you wind the tickover back down once balancing is completed.
    Lozzo, Dec 3, 2006
  6. Eddie
    Moon Badger Guest
    3 is the datum. The left screw does 1 ( or 2, can't find the Haynes ), the
    centre screw does (1+2) against 3 and the right screw effectively only
    controls 4.
    Champ pointed out throttle cable slack and clamps, worth checking. FWIW,
    I've used vaseline ( feed lines 'R' us ) smeared on carb inlet rubbers to
    check for leaks. It fill the cracks ( oo-er ) temporarily and doesn't
    damage the rubber.
    Another thing worth checking for is crud on the mechanism, especially
    embedded crud in the springs stopping the butterflys from closing fully.
  7. Eddie
    Moon Badger says...
    Spray carb cleaner onto them, if the revs rise you've got a leak.
    Lozzo, Dec 3, 2006
  8. Oh yeah. Duh.
    The Older Gentleman, Dec 4, 2006
  9. Eddie
    Eddie Guest
    I'm glad somebody's paying attention.
    I unhooked it, just to make sure.
    They are, but I'll double-check.
    Eddie, Dec 4, 2006
  10. Eddie
    Eddie Guest
    .... is what I'll be trying next.
    Eddie, Dec 4, 2006
  11. Eddie
    Rope - as useful as ever.
    Pip, Dec 4, 2006
  12. Eddie
    Eddie Guest
    Well, that didn't help.
    I did notice something potentially interesting though, while I was
    fiddling about: uncovering the vacuum connections whilst the engine's
    running causing the engine to die (well, duh)... but not, apparently,
    #4, which appears to make no significant difference to the running of
    the engine.
    Methinks that #4 is not a happy pot...
    Eddie, Dec 4, 2006
  13. Eddie
    Eddie Guest
    Not really, Spike.
    Eddie, Dec 5, 2006
  14. Eddie
    Eddie Guest
    "Leaking air internally"? What, into itself? ;-)
    Hmmm... how much do compression testers cost? Do you think Santa would
    bring me one for Christmas?
    Eddie, Dec 5, 2006
  15. Eddie
    Pete Fisher Guest
    A mate of mine had terrible trouble getting a Morini to idle properly
    after he had to have a second hand head quickly put on just before a TT
    trip. Even with only two cylinders, a mercury manometer gauge and an
    expert on hand (not me) we couldn't get it right. The expert eventually
    reckoned the used head must have had a slightly burnt valve.
    | Pete Fisher at Home: |
    Pete Fisher, Dec 5, 2006
  16. Eddie
    WavyDavy Guest
    Gunson compression guage is £18.99 at Halfrauds.....
    WavyDavy, Dec 5, 2006
  17. Eddie
    Eddie Guest
    Gunson? Is there stuff any good? I'd rather make Santa pay for a decent
    one...
    Eddie, Dec 5, 2006
  18. Eddie
    WavyDavy Guest
    No idea. Just thought that if you wanted it for a quick one-off check it
    ain't much to fork out.....
  19. Eddie
    Eddie Guest
    True... but I like *nice* garage equipment, not stuff that'll fall apart
    after two uses.
    Eddie, Dec 5, 2006
  20. Eddie
    I've got a few Gunson bits - remote starter, compression tester,
    multimeter & strobe. They came as a box set around 20 years ago & still
    work fine.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Dec 5, 2006
