Idle adjust 2 carbs
Discussion in 'Classic Motorbikes' started by Ash@Work, Oct 6, 2003.
  1. Ash@Work
    Ash@Work Guest
    The RD has 2 carbs, both of which have an idle adjuster. How do I ensure
    that they are adjusted equally? Do I just guess?
    Ash ([:])
    BOTAFOT#82 UKRMFBC#8 HMC#5 YFC#0(KotL)
    ETV1000 Caponord http://www.theredline.co.uk/ballistic
    "If everything seems under control, you're just not going fast enough." --
    Mario Andretti
  2. Ash@Work
    Mike Buckley Guest
    I usually guess on the idle adjusters (adjust them so tweaking either
    has an affect on the idle speed). I usually adjust the cables by putting
    half a lolly stick under each slide and adjusting the cables so both
    sticks dip at the same time when you twist the throttle. i guess a
    similar method could be used for idle speed, but it's not that critical.
    On a YPVS you can put the sticks in just by removing the rubbers between
    the carb and the airbox - nfi if this will work on a 200.
    Mike Buckley, Oct 6, 2003
  3. Ash@Work
    Ash@Work had a fit and wibbled.....
    There should be 2 hex head bolts at the top of each carb body, up by the
    top cap. Keep the engine switched off. Take each of those bolts out and
    wind the throttle fully open. When the slide is at the top, you should
    be able to see a small mark (they look like someones started to drill a
    hole in the slide) on each carb slide through each bolt hole. Adjust the
    throttle cables on each carb until both of these drill marks line up at
    exactly the same point at the tiop of the bolt hole, when the throttle
    is wound right open. Replace the 2 viewing hole bolts in the carb
    bodies. That's the throttle cables synched.
    Next, making sure first that the timing is set up correctly, the air
    screws are set to the correct amount of turns out etc, and that the oil
    cable is adjusted, you need to balance the carbs.
    Take the left plug lead off the plug, and wind the tickover adjuster for
    the right carb in a couple of turns. Switch the bike on and kick start
    it, don't use the leccy foot, they are crap and waste the batteries on
    RD200s. The bike should start on just the right cylinder and you want it
    to tick over at a steadyish 1500 revs, you might need to adjust the
    tickover up or down to suit using the brass tickover adjuster screw
    sticking out at the base of the carb slide body. Blip the throttle and
    let it settle down, and make sure it holds 1500ish revs. Switch the
    engine off. Replace left plug cap and remove right plug cap, wind left
    tickover adjuster in a couple of turns. Repeat the procedure for getting
    1500ish revs and switch engine off again. Replace right plug cap.
    BE WARNED. When you start the bike the next time, it will rev it's tits
    off.
    Start the bike again with both plug caps in place. The bike will be
    revving very highly. Back off both adjusters an equal amount each, until
    the revs die down to the required engine speed on tickover.
    That's it, job done.
    Lozzo
    ZZR1100D, GPZ500S, CBCBCB750RSRSRS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Oct 6, 2003
  4. Ash@Work
    Ballistic had a fit and wibbled.....
    Your timing will need to be spot on before you start mucking about with
    carbs etc.
    I don't have a DTI anymore cos someone stole it. You'll need one to do
    the timing properly.
    The air screws aren't the idle screws. The idle screws are large knurled
    brass screws with a spring behind them sticking out at right angles at
    the base of the slider part of the carb body. The air screws are smaller
    and usually go in at an angle on RD carbs.
    The oil cable is the one that comes out of the junction under the tank
    where the single throttle cable from the grip splits into 3 short ones.
    2 of these cables go to the carbs and the other goes to the right hand
    front of the engine diving into the black case in front of the clutch
    housing, alongside 3 pipes. Behind that cover with 3 screws is the oil
    pump. Make sure it's set up right as per the book, or it'll seize.
    Don't you have a HBoL? It'#s all expalined in there
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 7, 2003
  5. Ash@Work
    The Smiths Guest
    <Lots of snippage>
    Anyone would think you have done that once or twice before ...
    The Smiths, Oct 7, 2003
  6. Ash@Work
    The Smiths had a fit and wibbled.....
    Ivan explained it better, but he's a fucking academic, he's used to
    that.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 7, 2003
  7. That's pretty much how I used to balance the carbs on my ShiteOldBoxer.
    Used to take 3 mins.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Oct 7, 2003
