idiotic bolt question
Discussion in 'UK Motorcycles' started by darsy, May 21, 2007.
  1. darsy
    So.
    I have a seized end-can bolt on the 'blade, and the allan-key hole is
    rounded off.
    I've tried hack-sawing a slot in it and using an impact driver, but
    still no joy.
    So, what's the next option?
    I've seen mention of people "drilling out" seized fasteners, but
    what's actually the score with this?
    darsy, May 21, 2007
  2. darsy
    Colin Irvine Guest
    Try the point of a cold-chisel in the end of the slot you've sawn,
    hammering along the circumference of the bolt head, anti-clockwise
    obviously. It's worked for me before.
    Colin Irvine, May 21, 2007
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, darsy
    LH drill bit. It just works.
    Wounded Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, May 21, 2007
  4. darsy
    that's something to try - definitely.
    The problem is that it's the bolt underneath the can, towards the
    swing-arm, so it's a twat to get at; ideally I'd turn the bike upside
    down for easy access[1]
    [1] paging Platy...
    darsy, May 21, 2007
  5. darsy
    humour me - *what*?
    I don't have a drill that goes backwards, for a start.
    darsy, May 21, 2007
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, darsy
    I do. Want to borrow it? You'll have to collect.
  7. darsy
    Well that's the next tool on the list then. Once you've got one you'll
    also need a LH drill bit, of course, and it should ideally be somewhat
    narrower than the bolt you're drilling. Then yes, simply drill down
    the centre of the bolt. As it starts to enter the bolt it will apply
    loads on undoing torque to it, as well, if it gets that far, as
    thinning the middle of the bolt such that it will no longer be as
    tight in the hole[1].
    Never done it myself, mind...
    [1] Fnaar.
    _______
    Ace, May 21, 2007
  8. darsy
    I could facilitate this en route to move the Beastly Blade, perhaps.
    Even better, I could drop TOG's stuff off too.
    I can see a plan forming.
    Pip, May 21, 2007
  9. darsy
    Monkey Guest
    Just don't break the fucking drill bit off in the hole, or you'll never get
    it out.
    Monkey, May 21, 2007
  10. darsy
    Colin Irvine Guest
    <g> The other option is to drill a normal hole down the centre and use
    an extractor such as an Easy Out. I've also had success with this
    method. Of course you need to have a set of extractors to hand, and if
    the bolt has well and truly welded itself in there is the possibility
    of snapping the extractor, making any subsequent efforts even harder.
  11. darsy
    me too, though somewhere along the line it needs to include getting
    the 'blade an MOT, as the prospective buyer is somewhat squeamish
    about taking it without one[1]
    [1] to be fair, understandably.
    darsy, May 21, 2007
  12. darsy
    TOG Guest
    Ah, that's good, because I forgot that this weekend is our annual
    Morris side's tour of Kent & Sussex[1] and I'm dancing all weekend so
    can't pick up until the weekend after...
    [1] Something like 15 pubs in the weekend
    TOG, May 21, 2007
  13. darsy
    TOG Guest
    <snip>
    Can I just add one word here?
    "Blowtorch"
    TOG, May 21, 2007
  14. darsy
    R Guest
    Gas axe and application of heat then tack weld a suitable bar on the end
    (Unless it's stainless) and apply mole grips. If still stuck the drill
    through it, remove excess threads etc and re tap hole if space allows.
    All the equipment for this operation is in my mobile workshop sitting in my
    drive.
    R, May 21, 2007
  15. darsy
    TOG@toil, ,
    wrote:
    Speaking of which, I was at the local duck race yesterday afternoon and
    they had the local morris side in attendance.
    A mixed side.
    In fact, so many women that I doubt the blokes could have made a side by
    theirselves.
    Discuss.
    ogden, May 21, 2007
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, ogden
    Then, whatever is was, it was not a Morris side.
  17. darsy
    ginge Guest
    Morrisettes?
    ginge, May 21, 2007
  18. darsy
    Well get it round here & remove this stuck bolt from my Corvette then -
    the one in an alloy casting, with nothing left sticking out the hole, &
    a snapped off tap down the middle :-/
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tigtona 955i '96 Tiger '79 Fantic Hiro 250
    Krusty, May 21, 2007
  19. Not Ring, anyway. Them Federation fellers: they allow wimmin.
    The Older Gentleman, May 21, 2007
  20. darsy
    raden Guest
    I'll have a look - what diameter ?
    raden, May 21, 2007
