Identify Amal remote carby bowl
Discussion in 'Australian Motorcycles' started by me here, Apr 4, 2010.
  1. me here
    me here Guest
    Was sorting out some old british carby parts in the shed and came
    across an Amal style remote carby bowl which is different to every
    other one I've seen.
    It looks to be early twenties (prewar) manufacture as it is made from
    bronze as early Amals were.
    The bowl has no markings.
    The bowl lid is stamped Binks on the raised hexi nut boss (which later
    became part of Amal) and Amal Birmingham is cast into it.
    However, the BIG difference is that the banjo fitting is vertical and
    not horizontal.
    So it is either to be fitted on a carby body with a vertical (side
    feed) banjo OR quite possibly it is made to be remotely mounted on the
    frame away from the carby body in some way.
    Has anyone any idea what this is off of (either carby or M/cycle) ?
  2. me here
    atec7 7 Guest
    Might well be an Alcohol unit ? ( no no I mean methanol)
    atec7 7, Apr 4, 2010
  3. me here
    me here Guest
  4. me here
    atec7 7 Guest
    Looking at the picture has to be pre wwII but last time I saw something
    even remotely like it was off an old Indian from the mid 1930's
    I ran a modern version on a 500cc Bsa around 1971 when racing as the
    bowl was a twist and drop but was much more robustly built ( on pure
    Alchohol)
  5. me here
    me here Guest
    Of course. That has to be the logical (and correct) answer.
    I hadn't thought of that.
    It also explains why the banjo is about the fuel level height, So it
    aligns with the main jet in the suggested orientation.
    I recon there is a mounting adapter with a 90 degree offset in the box
    as well, which would have been used with it.
    I showed it to a neighbour out the back who used to race AJS in the
    fifties and he'd never seen anything like it.
    Thanks for that response.
    It's no good to me as I'm purely Dellorto on my bikes, so it's off to
    Ebay for this one.
    Cheers all
    Rob
  6. There is a bloke named George in Tasmania who would know what it is off
    I would guess that what he doesn't know about motorcycles, wouldn't be worth
    knowing
    Can't think of his last name though or where he lives, he has a couple of
    sheds full of stuff from carby pieces to complete running and registered
    bikes,
    Someone might know of him
    What about Kevin Gleeson, have you heard of him Kev?
    He goes to a lot of swap meets so would hazard a guess that he has seen
    something like that before
    George W Frost, Apr 5, 2010
  7. Doesn't ring a bell. Rough idea of which part of Tas he lives in?
    Kev
    Kevin Gleeson, Apr 5, 2010
  8. Not sure Kev, I will try and find where I saw his profile.
    It was on a Flicker site some time ago and there was a lot of photos of
    rallies and sales in Tasmania
