I4 question
Discussion in 'Motorcycle Technical Discussion' started by mad scientist, Jul 13, 2005.
  1. This may be a simple matter for some, but here goes...
    1984 Kawasaki ZN700
    I4, aircooled
    How in the world do you get those four tubes from the airbox to go on
    the carbeurators? Cylinders 1 and 2 go on solid, 3 goes on kinda
    sorta, and cylinder 4- forget it. I know the carbs are lined up as
    flush as they are intended to be with the cylinder head. So I know the
    carb assembly is not sitting kockeyed. As a result of unfiltered air
    getting into the carb, the rpm does not like to drop when the throttle
    is closed.
    TIA
    Charles
  2. mad scientist
    Matt Guest
    Would it help to remove the battery and the battery box so that you can
    reach in from behind?
    Matt, Jul 13, 2005
  3. Thanks for the quick reply. Unfortunately, no. The air filter goes in
    through the top. I can remove the air filter and get into the inside of
    the airbox that way, but no luck.
  4. It may well be time for new boots as they have a tendency to harden and
    shrink with age. Some tips for working with the old boots may be found at
    http://www.kzrider.com/forum/ and new ones are probably available at
    http://www.z1enterprises.com
    I gave up and bought new ones for my 650 SR.
    Good Luck!
    - Nate >>
    Nate Bargmann, Jul 13, 2005
  5. mad scientist
    Paul Cassel Guest
    Loosen the intake manifold some so you can wiggle the carbs around. That
    is, have a lot of play in the system, get all the 'tubes' attached and
    then straighten out and tighten.
    Paul Cassel, Jul 13, 2005
  6. mad scientist
    Rob Munach Guest
    That kind of nonsense on my GPz550 is what drove me to buy an airhead
    BMW. Much easier to work on for many things. Although, it has its
    *difficult* issues as well.
    Rob Munach, Jul 14, 2005
  7. You can soften old hard rubber air intake hoses by spraying them with
    an aerosol carb cleaner. The carb cleaner will evaporate and the hoses
    will be back to normal in an hour or so...
    I have a KLR-600 dualsport and the rubber hose is a bear to hook up to
    the single carburetor. I have to push the rear end of it back into the
    airbox, it just goes through a round hole on the box, and then push it
    forwards onto the carb bell mouth and then align the groove in the hose
    with the airbox hole...
    krusty kritter, Jul 14, 2005
  8. That's the kind of solution I'm looking for. Cheap and easy. Krusty,
    sometimes you post more wisdom in one day than I can ever hope to
    accumulate. Thanks.
    mad scientist, Jul 16, 2005
