I *so* thought I'd have to admit some of you were right...
Discussion in 'UK Motorcycles' started by WavyDavy, Nov 6, 2004.
  1. WavyDavy
    WavyDavy Guest
    .... when the 'door open' light refused to turn off and therefore the central
    locking on the Alfa failed after a mere 90 miles today....
    But then I found that the boot light wasn't in properly and it was shorting.
    Popped the unit back in properly and all is well.
    Anybody care to try to explain how a popped out boot light unit can cause
    the onboard pooter thingy to think that a door is open????
  2. WavyDavy
    Ginge Guest
    "Wired up by Italians."
    Ginge, Nov 6, 2004
  3. WavyDavy
    tallbloke Guest
    Courtesy lights'll be on the same circuit the pooter checks maybe, cos the
    doors also activate a courtesy light switch when they're open.
    Maybe
    If it's just a single warning light rather than a little diagram of the
    car showing which door is open, prolly isn't anything very clever that
    needs the pooter anyway.
    Mebbe.
    tallbloke, Nov 6, 2004
  4. WavyDavy
    jack hackett Guest
    Simple: The light on the dash is ignited when the circuit relating to it,
    has power flowing through it.
    On some cars, the way it works is, each door / boot switch will have a wire
    run to it on the side of the switch that is 'closed' when power isn't run to
    it, in addition to the wire that when a full circuit is made by the door /
    bootlid being opened, feeds power onto the circuit which feeds power to the
    bulb in the light in question... so, when you open the appropriate orifice,
    as well as the connection made sending power up the wire that goes to the
    light in question, it also sends a current into the circuit that ignites the
    light on the dash... so if you've had a short that's allowed power to light
    up the boot light, it's powered the warning light circuit as well.
    Or something like that.
    HTH... although it has probably confused you more! ;-)
    jack hackett, Nov 6, 2004
  5. WavyDavy
    WavyDavy emerged from their own little world to say
    Probably using a CAN bus [1]. The new BMW R1200GS has one which is causing
    all sorts of weird electrical faults.
    They were used on Xerox products when I worked for them. Great in theory as
    manufacturing costs are reduced. In practice we had endless firmware
    revisions due to piss poor R&D.
    [1] http://www.embedded.com/showArticle.jhtml?articleID=13000304
    wessie, Nov 6, 2004
  6. WavyDavy
    WavyDavy says...
    It's an Alfa, anything is possible with the electrics.
    Lozzo, Nov 6, 2004
  7. WavyDavy
    jack hackett says...
    Commonly known as having the interior lighting 'positively switched'.
    It's standard on most cars.
    Lozzo, Nov 6, 2004
  8. WavyDavy
    tallbloke Guest
    How many doors has it got?
  9. WavyDavy
    WavyDavy Guest
    Sounds like a good theory to me.. Esp when added to Ginge's theory... :)
    Welll yes, I are tight[1], so no 'pooter display, just a door warning. But
    it wouldn't be able to tell me which door, anyway, would it, if it was the
    boot light...
    [1] It seems to be very good at saying "Alfa Romeo" and what the temperature
    is and what door is currently wide open and going ';bing' when you exceed a
    pre-set speed and can't be arsed to look at the speedo. Apart from that I
    couldn't see why I should pay extra £££s for the 'pooter display...
  10. WavyDavy
    tallbloke Guest
    My old BX had a display which had seperate warning lights for each door
    *and* one for the hatchback.
    Always a good source for miles of spare wiring are dead BX's
  11. WavyDavy
    Andy Hewitt Guest
    That was going to be my answer too, and I worked with them for 6 years.
    Andy Hewitt, Nov 6, 2004
  12. WavyDavy
    WavyDavy was seen penning the following ode to ... whatever:
    Luigi was too busy snogging the boss's secretary to take much care
    with the wiring.
    Timo Geusch, Nov 6, 2004
  13. WavyDavy
    That sums up SteveH's problems in a nutshell.
    Pip, Nov 6, 2004
  14. WavyDavy
    It's an Alfa. It'll be growing new doors all the time ...
    Pip, Nov 6, 2004
  15. WavyDavy
    Bugger.
    Pip, Nov 6, 2004
  16. WavyDavy
    Andy Hewitt Guest
    <snort> is it really *that* obvious how much I like them? ;-)
  17. WavyDavy
    antonye Guest
    I was unable to switch off the instrument illumination
    on the bimmer the other night - **** knows how that
    happened! I was turning the lights between on and off
    and the clocks stayed lit. It was only when I switched
    the ignition back on then off that it went out.
    It wouldn't be so bad if it was the old one but this
    was on the 18 month old!
    antonye, Nov 6, 2004
  18. WavyDavy
    tallbloke Guest
    I was asking about the family engine sized BMW.
    tallbloke, Nov 7, 2004
  19. Short for 'alf a plug short of a wiring loom
    The Older Gentleman, Nov 7, 2004
