I mailed 5 about their noisy adverts.
Discussion in 'UK Motorcycles' started by Muck, Apr 7, 2005.
  1. Muck
    They basicly said get stuffed, we have no plans to change making adverts
    noisier than the TV progs. Which is fair enough...
    So, what can the likes of joe public do to change this situation?
    Muck, Apr 7, 2005
  2. Muck
    tallbloke Guest
    muck@_TEETH_rulex.net (Muck) wrote in muck@_TEETH_rulex.net:
    turn the sound off when the ads come on.
    tallbloke, Apr 7, 2005
  3. Muck
    I do, but just wanted to see what they had to say about what they did.
    Muck, Apr 7, 2005
  4. Muck
    Nick Guest
    It's called Dynamic Range Compression. If you record a sample of the
    programme and a sample of the advert you will find that the advert
    will probably be 5db LOWER than the programme.
    It is illegal in the UK to have adverts at a higher volume than the
    main programme. To get around this the advert makers mix their audio
    so that everything is at a high a volume as possible, which makes it
    more noticable.
    The same kind of things are done for songs on the radio, all of the
    volumes are maxed out so that you don't keep having to turn the radio
    up/down when a different track comes on. IIRC one can get plugins
    like AudioStocker for WinAmp that do the same thing at home.
    Nick, Apr 7, 2005
  5. In uk.rec.motorcycles, Muck amazed us all with this pearl of wisdom:
    Switch night mode on on your telly.
    Whinging Courier, Apr 7, 2005
  6. Muck
    Turn it off at the wall?
    Muck, Apr 7, 2005
  7. Muck
    I just press the mute button, and sometimes go and get coffee and cake.
    If I'm recording a program, I also press pause on the recorder. Makes
    for unbroken viewing when you watch it again.
    Heh.. just wait until pop up ads come to TV.
    Muck, Apr 7, 2005
  8. Muck
    What's night mode?
    Muck, Apr 7, 2005
  9. In uk.rec.motorcycles, Muck amazed us all with this pearl of wisdom:
    It attenuates sudden noises like explosions etc.
  10. Muck
    muddycat Guest
    Shoot your telly.
    Mike
    SV650
    UKRMMA#22
    Skype: muddycat
    muddycat, Apr 8, 2005
  11. Muck
    gomez Guest
    Should not one be enquiring into the address of the owner of the ad
    company?
    gomez, Apr 8, 2005
  12. Muck
    muddycat Guest
    When I see the shrub my trigger finger gets itchy.
  13. Muck
    Cab Guest
    Anglegrinder.
    Cab, Apr 8, 2005
  14. Muck
    Vass Guest
    You mean you're one of the few male species that does'nt channel hop during
    adverts driving the other half crazy?
    Vass
    YZF-R1, CBR1100xx-x, A4 Cab
    http://www.naldernet.plus.com/index2.html
    Gamertag: RIPPPER
    Vass, Apr 8, 2005
  15. Muck
    If it was mine, maybe. :)
    Muck, Apr 8, 2005
  16. Muck
    I can't stand that, my old Land lady used to do it, a few seconds of
    this, thirty seconds of that. Just enough to get the interest peeked,
    then move on. Sign of the times maybe..
    Muck, Apr 8, 2005
  17. Muck
    Jim Crowther Guest
    Ask them why they are not using a perceived loudness meter, as do CH4
    etc?
    <http://www.teddstudios.u-net.com/ldbb.htm>
    Jim Crowther, Apr 8, 2005
  18. Muck
    Muck, Apr 9, 2005
  19. Muck
    Jim Crowther Guest
    They certainly use BPR perceived-loudness meters, but whether an earlier
    version or not I don't know.
    Jim Crowther, Apr 9, 2005
  20. Muck
    s.dt Guest
    Is it just me or does anyone else think Britney Spears song 'Poison' seems
    to jump a few decibels?
    Really embarrassing if you have thin walls..
    s.dt, Apr 9, 2005
