I knew it was goping to be too good to be true.
Discussion in 'UK Motorcycles' started by steve auvache, Jul 21, 2006.
  1. This week, I have been mostly fettling my Bloo GS and on the whole
    things have gone swimmingly well. Until this evening.
    Today we are mostly putting it back together in the expectation of doing
    road trials tomorrow to see what (if any) jetting changes may be called
    for but with full expectation of having a fully functioning source of
    added adrenaline.
    Snot fucking working is it. Oh it fired up all right and coughed and
    spluttered in that "It is running well enough to be called a place to
    start" kind of a way that badly out of tune carbs do and then I got to
    work on getting the needles and spacers in more or less the right place
    and halfway through it decided it was going to refuse to start.
    One flat battery later and I am doing the "we'll try it one end and then
    we will try it the other" with the needle heights and the fucker still
    refused to start.
    I dunno why but something told me I should check the plugs and see if
    they were awash with fuel, which they weren't. Neither do they appear
    to be awash with sparks, which they were.
    I do know that unless it has chosen this moment to be broke it snot the
    kill switch. Nor can I see any shiny wires hanging down where there
    were not shiny wires hanging down before. This one is not going to give
    itself up easily I can just sense it. So, I am not going within a
    sword's length of it for the moment, for it's own good.
  2. steve auvache
    Peter Jones Guest
    Have you got a can of EasyStart? Works wonders for stubborn bikes, my
    70's trials bike had been sitting since the mid eightys and would not
    kick over and run. Squirt of EasyStart and ran right up.
    Failing that.. It does have fuel in the tank doesn't it?
    Peter Jones, Jul 21, 2006
  3. steve auvache
    peter Guest
    Was it only the carbs that have been disturbed? Nothing else fiddled
    with in the ignition system area - even if just to gain access for the
    carb work?
    When I did the 604 conversion on the Nordie it was a real pig to start
    with the new CR33 smooth bore carbs I put on at the same time. On
    putting back the standard Teikei twin choke unit it was fine.
    Eventually I discovered that my shiny new carbs had been supplied by
    Allens without *any* idle jets at all!
    I would have suspected idle jet shennanigans if you hadn't found a lack
    of sparks. Time for the full Pirsig sleep, before cranking up the
    'formal scientific method' approach.
    peter, Jul 21, 2006
  4. steve auvache
    peter Guest
    Just another thougfht.
    I am sure you have since tried it again with a good battery to check
    the spark, or is it CDI ignition which is not dependent on a good
    battery voltage to produce a spark?
    peter, Jul 21, 2006
  5. Peter Jones wrote
    No I haven't oddly enough. I always consider it to be an essential part
    of the SOB tool kit but for some reason seem to have run out.
    I do now have a half empty can of strong wind which was full which I
    have been having great fun blowing down the ant's nest by the back door
    though.
    It doesn't currently have a tank. Instead it is sporting an old half
    litre plastic oil can and some fish tank hose and a yard or two of gaffa
    tape as a Summer fashion accessory of the kind of arrangement you set up
    when you are doing carbs and stuff.
  6. wrote
    Theoretically yes only the carbs but who knows what gets pulled and
    pushed around when you are having an enthusiastic fettle.
    Now that I have calmed down a bit I have been out and begun diagnosis
    and the spark is most certainly not big, blue and fat, not evewn in the
    failing light of dusk. I can draw a half inch long one no problems but
    it is very thin and yellow. And given that it is the same rather weak
    insipid yellow both sides I am inclined to be looking at the electronics
    come next daylight I think.
    The jets haven't been touched (yet). I bought it a K&N filter in the
    fairly certain knowledge that I could get it running well enough to get
    me to Tesco and back just by buggering about with the needles and that
    the jets could be considered the final fine tuning which could be done
    over a period of time. I have done this any number of times before with
    mates bikes and cars and never had this issue.
  7. wrote
    No, I am keeping the good battery well away from this until I am ready
    to declare it fit to ride. It has got a "good enough" one on there and
    it is staying.
    CDI innit.
  8. steve auvache wrote
    That said I have been all over the engine and immediate area in the last
    week curing oil leaks and taking off fairing mounts and adding the right
    number of nuts and bolts to the engine mounting system and putting right
    a too long list of really rather unsavoury bodges and generally wiping a
    greasy rag over everything that I can see, so who knows what long term
    just waiting to happen problem I have uncovered.
    Although I am not one to complain me, just not the type, very much a pot
    half full rather than the jolly old vessel half empty kind of a fella,
    know what I mean? Well I have just had a text from WC announcing he is
    going to be missing from ukrm for possibly as much as 3 weeks. Laugh,
    it brightened my day no end.
  9. Wicked Uncle Nigel wrote
    See, now, you are just trying to spoil it aren't you. At least 10 days
    even with good behaviour. So much better.
  10. Hmm, is this a GS as in Suzuki? If so the CDIs on them will give a
    crappy (or non-existant) spark if the battery voltage drops a bit low -
    so just 'cause the battery has enough juice to turn the engine over
    deosn't necessarilly mean it's got enough to give a good spark.
    Molly Fletcher, Jul 21, 2006
  11. Molly Fletcher wrote
    Is there any other? Shame on you.
    Now if that had come from anybody else I would have said bollox but
    until such time as my own rapidly expanding expertise with this bike
    exceeds yours then I shall have to accept your explanation as being
    plausible. Got any evidence, even anecdotal, to back it up? I haven't
    come across anything to suggest this.
    But it has occurred to me that at the very least I disturbed the wiring
    round the pulse generator thing when I had the RHS crankcase cover off.
    But that, if it is going to be an iffy wire, shouldn't be both plugs. I
    am not confident I will find the problem there.
    I have just been out and taken the battery off simmer, so I will let it
    cool overnight and see tomorrow.
  12. steve auvache
    <panto mode>
    Oh yes it will!
    </pm>
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jul 21, 2006
  13. Krusty wrote
    Go on then explain. 4 wires, 2 line and 2 return. 1 of each to each
    generator doobry and no plug anywhere near where I have been playing.
    I'd believe one falling off and if it had been a one cylinder issue I
    would have been straight back in there.
    Granted it could be. Fundamentally it is Automotive Electrix which
    remains to this day the Blackest of Black Arts.
  14. steve auvache
    OK maybe not the wires themselves, but you may have wiggled them enough
    to break something inside the pick-up coil, or maybe disturbed it so
    the gap to the trigger wheel's gone out of spec.
    Ain't dat da troof - closely followed by inlet length & airbox design.
    And to think spannies used to confuse me.
    Krusty.
  15. Krusty wrote
    Two pulse generators. Two entirely separate low and HT circuits all the
    way really.
    Yes but.... The wheel thing is located on a lump that sort of makes it
    hard to not put it in the right place and still do it up. Keyed, I
    think is the correct term. Mind you if Molly's is wrong it will be high
    on the list of places to poke round.
    steve auvache, Jul 22, 2006
  16. steve auvache
    Dan L Guest
    <Thread Hijack>
    Did you get your Zephyr Zorst sorted Molly?
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Jul 22, 2006
  17. steve auvache
    Kim Bolton Guest
    Put on the best battery you've got, not one that 'might be good
    enough'. You've got enough unknowns there as it is.
    Kim Bolton, Jul 22, 2006
  18. Kim Bolton wrote
    I appreciate your advice but with batteries there are very few unknowns
    as far as I am concerned. The battery that is on there, which has been
    tested by a very confident about what he is doing me, is more than good
    enough and I still have a pristine spare.
    It is getting desperate now, I have got the meter out. I have had a go
    over things with it this morning and I am fairly convinced it is the
    ignition electronics. It is obviously trying to have a go but there
    just isn't enough oomph. I could be more convinced mind but the spare
    one I have got is going to have to be cut from the donor bike avec
    Dremel unless the WD40 works and that will have to wait until play
    resumes after the rain.
  19. Well there's the beemer big traily things.
    Well I've owned several GSs and on plenty of occasions had them with a
    slightly flat battery (suzuki electrics being what they are) that'll
    turn the engine over but it won't start. Checking turning the engine
    over on the starter shows a weak spark or no spark. Checking by turning
    the engine over by hand and the spark is fine. Bump start it or use the
    kickstart if it's got one and it'll start fine. What seems to be the
    case is that the CDI needs a certain voltage to fire and the drain of
    the starter motor causes a voltage drop which stops the CDI firing.
    Easiest was around it is a set of jump leads off something with a less
    knackered battery or a start charger.
    Molly Fletcher, Jul 22, 2006
  20. Not yet - it's actually Melanie's Zephyr not mine so it's when she gets
    around to it...
