I Have no luck with bike shops, What is there Problem?
Discussion in 'Motorbike Technical Discussion' started by Tim C, Feb 23, 2005.
  1. Tim C
    Tim C Guest
    I have absolutely no luck in getting my bike fixed properly at any
    bike shops. Honda Cb 650 Custom in restoration mode and just too many
    bills to descibe where so much has gone wrong. Ok it is an old bike
    but when you write down exactly what it is you want done at you go to
    pick your bike up and pay them for the good $ they want I always find
    a few things they "forgot to do"
    Example: Last fall a motorcycle shop in Misssion was givin the order
    to replace the rings, hone cylinder bores, check specs od course
    before hand, and report any problems, they also wer to do the valve
    stem seals, lapp the valves, and also report any problems back to me.
    I also asked them to replace a few front fork rubber suspension mounts
    and that was it.
    After driving the 50 miles twice to get my bike that was supposedly
    ready, they forgot the rubber seals and had to drive back the 3rd
    time. The bike leaked on the head before I took it to them and it
    still leaks today. I am returning to Mission tomorrow to get them to
    hopefully get the leak fixed in the Valve body gasket, and who knows
    where else. Hope that goes better than all others.
    I also last week Fri had bike in to another shop locally 4km away and
    asked for 3 things to get done. 1 replace the header with all new
    studs and nuts. 2 install a new rear tire and check the brakes while
    there. 3- re-jet as needed or move up the needles to make this bike
    run right with the individual K&Ns air filters and the 4 into 1
    header, so I can run this bike without the choke on all the time. (it
    was lean. After I paid the large bill, I got home and noticed they had
    used all my old hardware on the exhaust and completely ignored that I
    wanted all new studs and nuts on the exhaust system. They did not
    chrge me for the studs and am also going back there tomorrow and see
    if I have to pay for them......wow.....
    Last time I went to a Honda dealer, and asked them to put new sprokets
    and chain on they put on the wrong sproket on the front even though I
    told them and wrote down a 17 tooth.
    I think I have learned my lesson. In large letters I now will put on
    the tank for the mechanic the wriiten work to be completed with little
    boxes to check after completion. I also will now be asking if it is a
    licenced mechanic working on my bike too...
    Sad state of affairs at these bike shops, might as well do it myself.
    Tim C, Feb 23, 2005
  2. Tim C
    TaskMule Guest
    Most shops, and especially dealers have little time or interest in vintage
    machinery.
    TaskMule, Feb 23, 2005
  3. Tim C
    Mark Olson Guest
    [large snip]
    Exactly. If you are not a wealthy person, don't buy an old bike with
    the intention of paying someone else to work on it. Most so-called bike
    mechanics are not worthy of the name. Anything more complicated than
    routine maintenance is beyond their skill set. Repairing or restoring
    an old bike is quite different than working on a new bike, it requires
    skills and knowledge that take years to acquire.
    Anyone who is any good generally doesn't work at a dealership, they are
    at an independent shop, have lots of customers obtained via word of mouth,
    and charge what the market will bear.
    It's cheaper and more fun to buy a new-ish used bike that doesn't need a
    lot of fixing up. If your primary objective is to learn to work on your
    own bike, more power to you. If you want a bargain, cash-wise, and don't
    mind putting in lots of time and effort, again, owning an old bike *can*
    be a good idea, if, and only if, you have the skills and knowledge and
    time to make it work. It can also be a good way of spending far more
    than the bike is worth, on parts and repairs.
    I work with a guy (waves to you-know-who) who bought a 'bargain' 1980
    GL1100 for $600. By the time he's finished, he will have spent about
    twice that on parts, plus hundreds of hours of time and effort, and
    it will end up being an unreliable and ugly bike, due to the butchery
    its owners have subjected it to. I spent $1500 on my '86 GL1200A and
    it already is, before investing any time or money on it, an order
    of magnitude nicer than what he will end up with. If I had spent
    another $500 I could have had something that needed a lot less work.
    Another $1000, and it would need almost no work at all, but I confess
    to a weakness for bringing neglected bikes back to life.
    Mark Olson, Feb 23, 2005
  4. That's no great revelation, Tim. The mechanics working in the typical
    motorcycle emporium that wants to sell you a *new bike* are interested
    in only one thing, getting the work into the shop and out of the shop
    quickly so they can maximize their paycheck...
    Kevin Cameron mentioned the problem with "procedure-trained" mechanics
    VS mechanics who really had a talent for understanding machinery. There
    are hundreds of procedure-trained mechanics for every mechanic that
    really knows his shit...
    MC shop mechanics are typically procedure-trained, they how to change
    the oil and filter, bleed the brakes, change tires, chains, sprockets,
    etc. They even know how to adjust the valves, but they aren't going to
    want to actually *do* that procedure if the bike in question is a
    modern plastic-wrapped sportbike, where the radiator and ignition coils
    have to be removed and the camshafts have to come out to change just
    *one* shim, since only one valve is out of spec...
    No, shop mechanics aren't going to want to get into all that, they
    won't make money off of a job like that. Forced into accepting a valve
    adjustment, mechanics have been known to start the engine, warm it up,
    and ask the shop boss to come over and *listen* to the engine and say
    that the valves sound just fine to him. Then the mechanic charges the
    customer for the valve adjustment anyway!
    bike too...
    ROFLMAO! Of course the mechanics have whatever state licenses are
    required to work on customer's machines. They probably have a whole
    wall full of certificates behind their tool box in their work space.
    They've been to various distributor's tech schools and seminars and
    they have pieces of paper to prove it...
    That's what the C and D average high school student winds up with after
    he graduates with his peers. He goes to trade school, gets a piece of
    paper that says he's proficient at some trade, but such tradesmen can
    move around now, they don't have to stay in one shop and build a
    reputation. There's a steady flow of mediochre motorcycle mechanics
    from dealership to dealership, and shop to shop, and the half-assed
    mechanics manage to not only survive, they actually prosper...
    That's what restoration of old bikes is all about. Do-it-yourself, in
    your own garage, during the off-season. If you want a reliable MC for
    transportation, buy a new one, and trade in your old one every few
    years. That way, you can avoid hassles with mechanics who can afford to
    buy new bikes all the time because they are making a good living by
    just doing the minimum absolutely-required maintenance procedures on
    other customers' relatively new bikes...
    krusty kritter, Feb 23, 2005
  5. Tim C
    Charlie Gary Guest
    Tim C wrote:
    Tim,
    how long does it take to remove a steel stud screwed into an aluminum head
    after it's been through 10,000 heat cycles and 20+ years of road grime?
    Multiply that by eight. Add 200% for the two studs that break. Mulitply
    that by $1.00 a minute. How much are you willing to pay? How loud are you
    going to squawk when you find out it costs more for the stud replacement
    than the header?
    Those are the questions being asked by the service manager.
    Charlie Gary, Feb 23, 2005
  6. Tim C
    LJ Guest
    This is nothing new. Read "Zen and the Art of Motorcycle Maintenance" if
    you want a dissertation on this (and many other) motorcycle and life
    experiences. He wrote the book in the mid-70's, but not much ever changes
    when it comes to human nature.
    LJ, Feb 23, 2005
  7. Tim C
    Tim C Guest
    Charlie,
    When I requested that the studs and nuts be replaced it was because
    the nuts had bottomed out and were rusted and when you unscrewed the
    nut, the whole stud came with the nut. It was not a matter that the
    studs were going to break, it was a matter that the studs were going
    to vibrate out or loosen. The shop not only had used my old hardware
    of studs and nut in the re-installation, they never used lock-tite, as
    today once again, each stud came loose and off when you loosened
    the nuts. Today a new set of studs were installed with lock-tite and
    then new nuts went on..finally the way it should be.
    Tim C,
    Tim C, Feb 24, 2005
  8. Tim C
    Tim C Guest
    When the shop installed the header they also re-used the copper rings.
    They were just replaced less than 600km ago when the top end was done.
    That being said, I agree it would have been better to replace them,
    but..once again I left it up to the shop if they neeed them, replace
    them. It all works no leaks now and the header sounds great. And
    yesterday I had the bike back out to Mission B.C. to fix the valve
    body oil leak. We had to take the valve body off and they used some
    sort of 114 gasket compound and reinstalled the valve body. It now
    does not leak, and finally it is starting to feel and look like a job
    well done. The cleaning process can now begin again on the head to
    remove all traces of oil and get them shining.
    Next up on this bike....installing a steel briaded brake cable for the
    single disc, and then onto the forks, measure the spring replace the
    oil, and or springs and spacers if necessary...wow..never ending.
    Tim.
    Tim C, Feb 24, 2005
  9. Tim C
    Charlie Gary Guest
    Ah,
    more details cast a different light. I was going on the assumption you
    had the typical corrosion nightmare.
    Charlie Gary, Feb 24, 2005
