I have a Problem with my Turn Signal Lights not working. It's a honda motorcycle with a 6 volt electrical system. Originally the signal lights would not light when switched to left or right. I checked the bulbs and they test o.k. I unpluged the 6 volt flasher (model mitsuba FR-2112 6.4V 85c/m 17WX2+17W) What does that rating mean? When I unpluged the flasher and connected the wires directly it came on the side I switched but didn't flash. So that made me think it's the flasher. When I connected it up to the old flasher again I heard a click but no lights came on. I took a flasher from a Honda Passport that also used 6 volts and that the signal lights worked (flashed correctly). I connected it up to the bike and the lights came on but did not flash. The two contact flasher has "B" and "L" marked on it. The black wire goes to "B" and the other wire goes to "L". I checked the voltage and it was between 7 and 8 volts when. What do I check next? How do I check the flasher to make sure it works/don't work? How sells 6 volt 2 contact flashers cheaper than Honda (Honda wants about for one)? How about a simple circuit that I can make that replace the flasher? Will a 12volt flasher work?
