I bought an edible motorcycle
Discussion in 'UK Motorcycles' started by Pip, Feb 9, 2006.
  1. Pip
    Thought I'd take the bike out today, the weather being clement and the
    sun doing the shining thing. So I released the beast from its Winter
    quarters in the garage and brought it out to stand in the sun for a
    while - let it warm its bones, so to speak.
    While having a coffee and a fag, thoughts of a pre-flight checkover
    came to me. Brakes seemed fine, chain similarly - but there were
    pieces of what appeared to be foam, like seat foam, stuck to the chain
    and around the front sprocket cover. Strange. Not memory foam, more
    like mystery foam iyswim.
    Thoughts sprang unbidden, speculation ran rife. Mental pictures of a
    Spiccy character doing seat repairs or mods, perhaps - The Burd having
    a sudden cleaning frenzy, sponges whirling ... or might it be that
    muscular mouse, recently evicted from its cosy Winter home in my
    welding gloves?
    It was with the icy fingers of dread dancing along my spine that I
    lifted the seat, expecting to find the arserest foam internally
    excavated - but no, no damage to the stout plastic seat base was
    visible - neither any teeth marks in the vinyl, nor any evidence of
    leverage of securing staples. No burrowing, at least - but the little
    fucker had done for the rubber bobbin that presses against the battery
    cover. A mere stump remains, with distinct lines of rodent teethmarks
    around it.
    Looking to the rear, behind the bag of spanners, I could see fragments
    of seed cases. So Mousy had been filching bird food and scoffing it
    in my bike's boot, the arse. Then I spotted something that didn't
    look like a seed case, nor a nut shell - a sliver of yellow plastic.
    Panning vision forward, the origin became horribly clear - the
    ignition wiring loom.
    Every last wire running to the ignition module has been stripped of
    its insulation, bared copper strands twinkling in the sunlight. All
    the relays that live under the seat have suffered the same fate - the
    coloured insulation has been neatly removed from the end of the loom
    tape to the plug at the end. Mousy hadn't even eaten his loot - the
    fragments of stripped insulation were visible, on close inspection,
    caught on ledges in the mudguard moulding beneath the battery.
    I can see soldering irons, insulation tape and a fuckload of
    mousetraps in my immediate future.
    Pip, Feb 9, 2006
  2. Pip
    MikeH Guest
    It's good to have a hobby. Ratbike perhaps?
    MikeH, Feb 9, 2006
  3. Pip
    'Hog Guest
    Unfuckinbelievable.
    Thank goodness they are so cute and cuddly and loveable or you might
    harm one of them.
    'Hog, Feb 9, 2006
  4. Pip
    Eiron Guest
    The ultrasonic gizmos that plug into a mains socket seem to do the trick.
    Mice ate the rubber caps on my carbs where you connect a vacuum gauge,
    thus preventing a decent tickover or easy starting.
    They also made nests in the car's airbox and a spare silencer.
    Eiron, Feb 9, 2006
  5. Pip
    muddy Guest
    See, you should have bought the speed triple, they don't taste as good
    as the jap fare.
    muddy, Feb 9, 2006
  6. Pip
    "Steak & Kidney in nicer than Sushi shocker!"
    CT, Feb 9, 2006
  7. Pip
    It's a standard clause specified on car and bike insurance over here,
    except the more usual culprit is pine martens, of which there is a
    substantial population, even in urban areas. Apparently Peugeot are
    one of the first manufacturers to specify horrible-tasting insulation
    on all wiring, to avoid this all-too-common occurrence.
    Never happened to me, mind.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Feb 9, 2006
  8. Pip
    dwb Guest
    <makes note to check bike that's been standing in the garage for a few
    months doing nothing>
    dwb, Feb 9, 2006
  9. Pip wrote
    You have seen the dangers of being a part time biker children. Don't do
    it. You know it makes sense.
    steve auvache, Feb 9, 2006
  10. <Offers small Staffie-cross dog for rodent clearing operations>
    Phil
    Phil Launchbury, Feb 9, 2006
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    <wince>
    I've got heat-shrink wossname if you want some, guv'nor.
    Wicked Uncle Nigel, Feb 9, 2006
  12. Pip
    Mikey Guest
    Same thing in wifey's car. Mice at through the seats leaving bloody
    great holes in the upholstery. I put mousetraps (non-humane version)
    in the footwell and caught 3 mice in 2 nights. Abbey National Insurance
    (may they always be praised for this) didn't bat an eyelid and paid out
    the £1500 cost of new seat covers. Lesson learned - always sniff the
    air when going into the garage for that unique mousey musty odour to
    see if the little buggers have come back.
    Note to self - take a look at the bike later...
    Mikey
    Mikey, Feb 9, 2006
  13. Pip
    I'll be doing some considerable and permanent harm to the little
    fucker, you can be sure. I've not looked under the tank yet, it might
    be a new loom job.
    Pip, Feb 9, 2006
  14. Pip
    If the little fucker had chewed a new Triple, I'd be out there with a
    pigsticker right now.
    No contest. The very thought of raw fish scoffing makes me heave.
    Pip, Feb 9, 2006
  15. Pip
    I exist only to provide amusement. I'm coming back as Sideshow Bob
    next time.
    Pip, Feb 9, 2006
  16. Pip
    An excellent plan, but there's waay too much valuable/fragile stuff
    wedged into that garage for a dog/mouse faceoff to be contemplated.
    **** only knows what else the toothy little fucker has nibbled, an
    inventory will have to be undertaken - at least it'll get tidied at
    last.
    Pip, Feb 9, 2006
  17. Pip
    TYVM, but I can't get heatshrink over the plugs: he's taken out the
    insulation 'twixt end of loom tape and plug, where the wires splay out
    from the loom to spread across the plug fittings. I'll have to rewire
    the lot, or re-loom the bike, or cut and solder new wires in - or just
    wrap the lot up in insulting tape.
    Pip, Feb 9, 2006
  18. Pip
    The little cunts.
    Plan. Mind you, the chewing machine saved me a potentially freezing
    cold ride: it is surprisingly cold out there today, as I just found
    out standing in a car park for ten minutes.
    Pip, Feb 9, 2006
  19. Pip
    *snort*
    Pip, Feb 9, 2006
  20. She does get somewhat target-fixated when chasing small nibblies. As
    the 'rapaired small Staffie sized hole' in the fence at Lydiard Park
    can attest.
    She didn't even catch the rabbit either.
    Phil
