I appear...
Discussion in 'UK Motorcycles' started by Beelzebub, May 9, 2005.
  1. Beelzebub
    'Hog Guest
    On the K100 I eventually purged the system and went to the top dot grade
    fluid (Castrol I think). I also fitted stainless bleed nipples at the
    callipers which had one way valves (ordered from US) which made bleeding
    a cinch. It *still* had to be repeated every month or so to keep it in
    top fettle. Thinking about Champs comments about the disks, early K's
    did not have floating disks so I eventually made floating calliper
    mounts (!!)(1) which helped considerably. The 9R has floating disks tho.
    (1) and this was at least 13PE (2)
    (2) Pre Eaton
    'Hog
    'Hog, May 11, 2005
  2. Beelzebub
    Cos it's the only thing you haven't changed :)
    Seriously, I can't explain that. I didn't realise they were coming up
    good, then going away over a couple of days. The only logical
    explanation for that is that there's a leak of somesort somewhere.
    Champ, May 11, 2005
  3. Beelzebub
    Badly wrong, too.
    Why would too small bubbles compress less than one large one of the
    same total volume?
    Champ, May 11, 2005
  4. Beelzebub
    PeterT@Home Guest
    Champ proposed
    I think it should be correct though. The ratio between the combined
    surfaces of two bubbles and one bubble with a equal total volume is
    about 1.25, which means that the smaller bubbles experience less
    pressure per surface unit at the same displaced volume.
    PeterT@Home, May 11, 2005
  5. Beelzebub
    Alex Ferrier Guest
    Uh oh, here we go again.
    Alex
    BMW R1150GS
    DIAABTCOD#3 MSWF#4 UKRMFBC#6 Ibw#35 BOB#8
    http://www.team-ukrm.co.uk
    Windy's "little soldier"
    Alex Ferrier, May 11, 2005
  6. Beelzebub
    PeterT@Home Guest
    Alex Ferrier proposed
    Where? Don't think this is one of the often repeated ukrm threads, is
    it? Did I miss a meeting?
  7. Beelzebub
    PeterT@Home Guest
    Simian proposed
    So product of pressure and volume equals n(?) times the molar gas
    constant and absolut temperature, I'm not quite following you here. The
    pressure should always be the same irrespective of bubble size,
    depending on depth (outside pressure) and temperature. That doesn't
    take surface tension into account though. Wonder what effect that would
    have and at what scale.
  8. Beelzebub
    Beelzebub Guest
    It does actually say in the book to use extra heavy duty stuff, so I'll get
    what they recommend when changing the other bits and bobs.
    Beelzebub, May 13, 2005
  9. Beelzebub
    PeterT@Home Guest
    Simian proposed
    yup, so the errors of my ways.
    Oh, didn't even notice what this was originally about. Just got
    interested in the part if smaller bubbles exhibit different
    characteristics to larger ones.
    PeterT@Home, May 13, 2005
