I am a spannering god!
Discussion in 'UK Motorcycles' started by SteveH, Jul 8, 2006.
  1. SteveH
    TMack Guest
    Yebbut its mid 20th century technology at a rock-bottom price. If he had
    spent £2700 instead of £700 quid on it then there would be more grounds for
    criticism.
    TMack, Jul 8, 2006
  2. Electric starts
    <nods>
    I like kick starting it though. I've got the knack, first kick every
    time.
    Work in progress, Jul 8, 2006
  3. SteveH
    Pete Fisher Guest
    Weak spark innit. Big bore nordie is a bugger start on the button unless
    the battery is absolutely fully charged. No kick start but it will start
    if bumped. Motor not spinning over fast enough for the CDI to give a
    good fat spark. A softer plug helped with that, plus cleaning up the
    ignition sensor and setting clearance between sensor and the 'pip' on
    the flywheel.
    | Pete Fisher at Home: |
    | Visit my Home Page : http://www.flarefox.com/Lesbordes |
    | "Do not adjust your mind - there is a fault in the reality" |
    Pete Fisher, Jul 8, 2006
  4. SteveH
    SteveH Guest
    The starter is a bit reluctant to even start turning the engine over at
    times. I think the battery isn't the best in the world - and it's
    possibly not fully charged (although my charger says it is).
    I'm not worried - it somehow feels more appropriate to kick it than to
    start it on a button anyway.
    SteveH, Jul 8, 2006
  5. The Older Gentleman wrote
    **** me, I am in total agreement with a fucking journo, I am going to
    slit me wrists.
    steve auvache, Jul 8, 2006
  6. SteveH
    SteveH Guest
    Whilst I'd generally agree, how many people have experienced a
    crate-fresh, never been run before, new bike?
    I mean, most people who buy a new bike have had it put together and PDI
    checked by a dealer, not screwed together a bike straight from the crate
    - IME of rebuilt engines, they can be a tad funny about starting up
    until stuff has bedded in a bit - even if this is only by starting them
    up several times in the workshop.
    SteveH, Jul 8, 2006
  7. SteveH
    I bought a new XR400 once delivered in a crate. It went together
    without any grief, but point blank refused to start. It took several
    hours of kicking, poking, prodding & head-scratching, but I eventually
    figured it out - the idle screw was set too low...
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jul 8, 2006
  8. SteveH
    ChrisDC Guest
    I'd be inclined to not only clean but polish every electrical
    connection and terminal involved in the starter circuit and make sure
    any nuts and bolts are torqued correctly, then spray them with silicon
    grease. For good measure I might also check the ends of the starter
    motor brushes to see how big the contact area is.
    ChrisDC, Jul 8, 2006
  9. SteveH
    SteveH Guest
    You might be, but I'd be inclined to start it using the kickstart
    instead.
    SteveH, Jul 8, 2006
  10. SteveH wrote
    Muppet.
  11. Me, several times. And anyone who's bought a new bike.
    That has eff-all to do with them being built up out of the crate by the
    purchaser.
    Many dealers I've encountered use the company tea-maker and
    floor-sweeper to build up new bikes anyway.
    The Older Gentleman, Jul 8, 2006
  12. **** me fucking ragged, but you're being thick.
    Price has eff-all to do with it. It's crap. It's only £700, but it's
    still crap.
  13. SteveH
    Eh? Price has *everything* to do with it. It's called value for money.
    It costs less than a fifth of the competition, so obviously you can't
    expect it to be as good. But a stripped thread & a starting problem
    that's common amongst many Austrian, Italian & Spanish equivalents
    costing five times as much doesn't make it a bad purchase. It may turn
    out to be one at some point in the future, but it's not based on what
    we know so far.
    Krusty.
    Krusty, Jul 8, 2006
  14. SteveH
    SteveH Guest
    Well, to put this into perspective.
    Looking at Autotrader, for roughly similar money, I could have a DT125
    that's of questionable history (advert says 'off road use only') or an
    absolutely ancient Honda XL200.
    OK, so it's a bit of a hassle that I have a stripped thread and that I
    appear to have a problem with the electric start (although I'm convinced
    this is down to the shite quality battery rather than anything else) -
    but it's of *far* better quality than I expected, and I'm definitely
    happier with it than I would be with some 25 year old shagged out XL200.
    SteveH, Jul 8, 2006
  15. SteveH
    SteveH Guest
    This has *definitely* never, ever, been run before I did the other day.
    The fact that it came in so many pieces and that I had to connect up the
    fuel pipe would suggest this.
    SteveH, Jul 8, 2006
  16. SteveH
    Just out of interest, did the battery come with the bike, & filled with
    acid? (I'm assuming it's not AGM).
    Krusty.
    Krusty, Jul 8, 2006
  17. SteveH
    SteveH Guest
    Yes, the battery came with the bike, but it was dry and I had to fill it
    from the little bottle of acid supplied.
    SteveH, Jul 8, 2006
  18. SteveH
    ChrisDC Guest
    If it's there it should work.
  19. SteveH
    SteveH Guest
    You're right, of course.
    However, before I do that, I'm going to get a multimeter on the battery
    and give it a couple of hundred miles to bed in and see if it makes any
    difference.
    It just feels as though the starter isn't spinning the lump quickly
    enough to start it or it's draining too much power from the battery to
    get a decent spark.
    SteveH, Jul 8, 2006
  20. SteveH
    Ah... did you follow the instructions? I presume it said to fill it,
    then leave it for a few hours before topping up & capping? Even if you
    did, I'd still dump it & get a Westco. You can't beat AGM, especially
    for off-roading.
    Krusty.
    Krusty, Jul 8, 2006
