I am a spannering god!
Discussion in 'UK Motorcycles' started by SteveH, Jul 8, 2006.
  1. SteveH
    SteveH Guest
    (Obviously that's stretching things a bit, but.....)
    The Chinese bike is running. I've just blatted up and down the road with
    it a few times.
    It's very retro in the way the engine sounds and feels.
    It's quite loud.
    Seems to go, steer and stop OK.
    The electric start is useless. But it kicks over first or second kick.
    I'm feeling quite smug now.
    SteveH, Jul 8, 2006
  2. SteveH
    TMack Guest
    Well done!
    Roumour has it that you can get a bit more out of the engine if you open out
    the end of the exhaust completely by drilling holes all round the restrictor
    pipe and then cutting through the remaining metal between the holes. I have
    a spare exhaust and I am tempted to try but I think the noise might be too
    horrendous.
    Whats the problem with the electric start? If it is just a bit sluggish it
    could be that the battery needs more charging.
    TMack, Jul 8, 2006
  3. SteveH
    Cane Guest
    Spannering God you may be but you sure purchase like a muppet :)
    Cane, Jul 8, 2006
  4. SteveH
    SteveH Guest
    Aye, I don't think I'd want to do that. Would definitely be too loud.
    Could be sluggish - it turns the engine over, but it never quite
    catches. One or two kicks and it fires up. Not a problem.
    SteveH, Jul 8, 2006
  5. SteveH
    TMack Guest
    Another thing that may help is that the engine will "loosen up" a bit after
    a couple of hundred miles so the electric start won't have to work quite as
    hard. You may also find that replacing the spark plug with an NGK (DP8EA
    IIRC) will improve starting.
    TMack, Jul 8, 2006
  6. Am I missing something here? A brand new bike whose electric start
    doesn't do what it's supposed to.......
    The Older Gentleman, Jul 8, 2006
  7. SteveH
    doesn't do what it's supposed to.......[/QUOTE]
    You've become too used to the perfection known as shite old bikes.
    This is a different ball game and you obviously don't understand the
    rules.
    Andy Bonwick, Jul 8, 2006
  8. SteveH
    TMack Guest
    [/QUOTE]
    Any completely new bike will be a bit stiffer to turn over than one that has
    done a couple of hundred miles. If the battery is less than fully charged
    it will have more difficulty with a new engine than with a looser one. FWIW
    mine started OK on the electric start from the outset. The plug swap is a
    recommendation but is not essential - I didn't bother.
    TMack, Jul 8, 2006
  9. SteveH
    catman Guest
    How so?
    It won't last ;)
    www.cuore-sportivo.co.uk
    catman, Jul 8, 2006
  10. SteveH
    SteveH Guest
    Looking at the battery, I'd say that's at fault. I've not seen a battery
    like that since I pulled the one out of my mum's Honda Melody to charge
    it up.
    SteveH, Jul 8, 2006
  11. SteveH
    Tosspot Guest
    The Older Gentleman wrote:
    Errrmmm, don't you own a Trophy? Mine was never good at starting from
    new despite numerous trips back to the shop and 'they're all like that'
    malarky. Nice German fella eventually sorted it by going over it with a
    fine tooth comb and setting *everything*[1] to slap bang in the middle
    of the tolerances. Started fine thereafter.
    The 'Bird on the other hand starts in less than a turn, first time,
    every time, from -5 to +35. But it is Japanese.
    [1] I can't remember the list, but anything that had a gap was adjusted
    and at the end he had no idea if it was one in particular or a
    combination of the lot, but I never had trouble after.
    Tosspot, Jul 8, 2006
  12. SteveH
    catman Guest
    Still
    catman, Jul 8, 2006
  13. SteveH
    I know you've got it in for the cheap import brigade, but brand new
    bikes not starting on the button is actually quite common with off-road
    bikes. They typically have *tiny* batteries to save weight, which can
    struggle to spin the motor fast enough even when at their best. Add a
    bit of under-charge & a tight new motor, & you can guess the rest.
    It's quite common with KTMs, & the latest 525s are known to lunch the
    sprag clutch the same way the early Hinkley Triumphs did.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jul 8, 2006
  14. SteveH
    HooDooWitch Guest
    <fx: taps finger on nose>
    "Honda Melody" indeed.
    HooDooWitch, Jul 8, 2006
  15. SteveH
    SteveH Guest
    Old W plater, under 800 miles from new. Shame it was stolen and
    recovered a few years ago, or it would have been an easy job to get it
    back to showroom condition. If I could get it down here, and had the
    room, I might still give it a go.
    http://www.italiancar.co.uk/Holiday/Images/1.jpg
    http://www.italiancar.co.uk/Holiday/Images/2.jpg
    http://www.italiancar.co.uk/Holiday/Images/3.jpg
    http://www.italiancar.co.uk/Holiday/Images/4.jpg
    SteveH, Jul 8, 2006
  16. SteveH
  17. Look, I'm sorry, this is still a bullshit excuse. Every brand new bike
    I've ever come across has always started on the button. The days of
    electric starters struggling to turn over engines hark back to Mark
    Three Norton Commandos.
  18. Fairish comment. Actually, my Trophy only got hard to start when the
    valve clearances started tightening up.
    A re-shim sorted it.
  19. Hmmm..... well, the CD200 Benly has an all-but-useless electric start,
    but that's still a 1970s design.
    I'd just expect a bike, in the 21st century, to start on the button.
  20. SteveH
    SteveH Guest
    As you were saying..... 'a 70s design'.
    I've been out to the garage a few times this afternoon - all the
    electric boot does is churn neat petrol out of the exhaust - leading,
    eventually, to a nice backfire and flame.
    Switching to the kickstart sees it start first time.
    SteveH, Jul 8, 2006
