Hugger
Discussion in 'UK Motorcycles' started by CT, May 23, 2007.
  1. CT
    I had a hugger fitted to the Sprint ST, from new by the dealer, and the
    other day noticed that it had been fouling the tyre due to a loose
    fixing. I've tightened the bolt up but it still seems very close to
    the tyre.
    Of course, as the dealer fitted it, I don't have any instructions - not
    that fitting a hugger should need any, but it might be mice to see if
    there's any info on the fixings or whether there should be some
    spacers, etc.
    How much gap should there be, as a minimum, between the tyre and the
    hugger? I can easily get my finger in the gap on the left-hand side,
    but not the right.
    I'm going to pop back to the dealer on Saturday, just to make sure as
    I'm not 100% happy with it at the moment. I guess also I should get
    them to give me an original chain guard in case I ever need to remove
    the hugger for any length of time.
    Catman (and the other poster who's got an ST but I can't remember his
    name): got a hugger on yours?
    CT, May 23, 2007
  2. CT
    Molly Guest
    I think that because the hugger is fitted to the swingarm you don't need
    much gap. All you have to allow for is the tyre flexing. If you change the
    size of your tyre you may have to fit some spacers under the hugger to give
    it more clearance.
    On my old Gixxer there was only a small gap. The same is true for my 10R
    see here:
    http://sportsbike.org/mybikes/pictures/ace6.jpg
    IHTH?
    Molly, May 23, 2007
  3. CT
    Eddie Guest
    My ZX-9R's is close enough so that after a track day, the "shaggy" edges
    of the tyre brush against it.
    Eddie, May 23, 2007
  4. CT
    Dentist Guest
    CT wrote;
    I didn't get one, but I am giving it some thought, as the shock's
    getting bloody filthy. I got the impression that it's only bolted on the
    chain side and simply rests on the swing arm for support on the right
    side. If this is true, I would expect it to sag towards the tyre to some
    extent. Is yours the carbon jobby or the more flexible plastic?
    Dentist, May 23, 2007
  5. CT
    Ah, hello. Sorry for not remembering your posting name.
    Mine doesn't seem to keep the crap off the shock very much, but then I
    haven't seen what happens without a hugger, iyswim.
    I haven't removed the whole thing yet, but there is bracket that runs
    along the front of the swing arm and the right hand side of the hugger
    bolts to this (at the font of the hugger).
    It's the latter and yes, it does sag somwhat. I'd like to be able to
    force it a bit higher but I think that will require some modification
    to the bracket or elongate the hole on the hugger that the bolt goes
    through.
    CT, May 23, 2007
  6. CT
    Catman Guest
    Sorry I missed this. No hugger as yet, but I have a Skidmarx job
    sitting at my Ye Olde Bike Shoppe just waiting for this software release
    to be done.
    Suzuki Bandit 600
    www.cuore-sportivo.co.uk
    Catman, May 24, 2007
  7. CT
    Catman Guest
    Gets very filthy indeed.
    The one I had on the Triple really was very close as well.
    Suzuki Bandit 600
