How to test a Reg/Rec without a meter
Discussion in 'UK Motorcycles' started by Whinging Courier, Jul 2, 2005.
  1. Is it as easy as putting the lights on and seeing if the bulbs get
    brighter when revving the engine?
  2. Whinging Courier
    Monkey Guest
    It was on Sally's CBR400. Brighter means _significantly_ brighter though. If
    only one of the three phases is knackered, the brightness will go up a tiny
    amount.
    Monkey, Jul 2, 2005
  3. In uk.rec.motorcycles, Monkey amazed us all with this pearl of wisdom:
    I'm not asking because I think one is knackered :)
    I'm going to have a look at a bike today and the reg/rec has been cited
    as one of the things likely to fry.
    So if the thing gets brighter (the lights) that's a good thing yes?
    Unless they go bulb poppingly bright?
    I've never bought a really SOB before so don't know these things. This
    one came out when I was just old enough to get my provisional licence.
  4. Whinging Courier
    Nursey Guest
    With the clanging of bedpans, Whinging Courier
    When mine went, it started misfiring first then after about a day, the
    charge was so low that the fucker cut out and wouldn't start.
    Nursey, Jul 2, 2005
  5. Depends on the bike. On some, all it tells you is that the alternator is
    working.
    The Older Gentleman, Jul 2, 2005
  6. In uk.rec.motorcycles, The Older Gentleman amazed us all with this pearl
    of wisdom:
    That'll do. With no reliable method of testing I'll have to rely on
    blind faith and luck.
  7. In uk.rec.motorcycles, Nursey amazed us all with this pearl of wisdom:
    Heh. If I'm passing a Maplin's in Morden (pretty much where the bike is)
    I reckon a tenner on a crappo meter's going to be a wise investment ;)
  8. Whinging Courier
    Martin Guest
    Use an oscilloscope.
    Martin:
    VTR1000 Firestorm
    Martin, Jul 2, 2005
  9. Whinging Courier
    tallbloke Guest
    LOL
    WC using an oscilloscope.
    "how do you get live8 on this thing?"
    tallbloke, Jul 2, 2005
  10. Whinging Courier
    ITYM: "What happens if I stick me knob in this hole ... ?"
    Pip, Jul 2, 2005
  11. Whinging Courier
    tallbloke Guest
    I thinks you've hit on a way for WC to test his Reg Rec there. The pitch of
    the scream should be proportional to the voltage. Or is it that the angle of
    the dangle is inversely proportional to the heat of the meat?
