how to remove gear linkage?
Discussion in 'UK Motorcycles' started by Matt Horn, May 27, 2006.
  1. Matt Horn
    Matt Horn Guest
    I'm just stripping a fazer 600 of 02 vintage... the gear linkage is oneof
    those metal ball and metal socket arrangements. Are you meant to be able to
    seperate the ball and socket? if so how do you do it? I've not got a ball
    joint splitter that small and a whack witha drift and hammer doesn't seem to
    budge it.
    TIA
  2. In uk.rec.motorcycles, Matt Horn belched forth and ejected the
    following:
    Angle Grinder.
    Whinging Courier, May 27, 2006
  3. This might help...
    <http://www.bikechatforums.com/viewtopic.php?t=41567&postdays=0&postorder=asc&start=0>
    Si
    Mungo \Two Sheds\ Toadfoot, May 27, 2006
  4. Matt Horn
    GungaDan Guest
    Do you really have to split the ball/socket? Isn't there a splined
    shaft in the assembly?
    GungaDan, May 28, 2006
