How to get GT550 exhaust off
Discussion in 'UK Motorcycles' started by wessie, Jun 19, 2004.
  1. wessie
    Mitch wrote in
    angle grinder?
  2. wessie
    Mitch Guest
    I've been trying to get the exhaust off my Kaw GT550 but the b*****d 2 hole
    flanges that clamp the downpipes to the head are seriously seized onto the
    studs and wont shift.
    Any ideas?? Have tried levers but the alloy is so soft it just breaks the
    fins. I thought maybe a hole saw but they don't do them small enough. It'd
    be nice if I can get them off without totally destroying the exhaust and
    engine!
    Thx
    Mitch
    Mitch, Jun 19, 2004
  3. wessie wrote
    What is it with the question marks? There is no fucking question about
    it. The only solution is liberal application of the One True Tool
    steve auvache, Jun 19, 2004
  4. Heat, Plusgas, heat, Plusgas, heat, Plusgas
    etc.........................angle grinder.
    Si
    Mungo \two sheds\ Toadfoot, Jun 19, 2004
  5. wessie
    Gavsta Guest
    I had a good grindage today sharpening the lawnmover blades.
    Angle grinders truely are a gift from God.
    Gavsta, Jun 19, 2004
  6. wessie
    AlanG Guest
    Liberal application of lubricant left to soak overnight but if that doesn't
    do the trick a blowtorch should.
    AlanG, Jun 19, 2004
  7. wessie
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Gavsta
    Actually, I think they're from the other feller.
    Not that that's a *bad* thing, you understand...
    Nigel Eaton, Jun 20, 2004
