How to burn a lot of petrol and nearly gas yourself
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jan 10, 2010.
  1. The Older Gentleman
    frag Guest
    took a blunt brush and painted...
    So the fire started no problem? :)
    frag, Jan 11, 2010
  2. The Older Gentleman
    Beav Guest
    Not as good as ACF 50 though.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 11, 2010
  3. The Older Gentleman
    Beav Guest
    Fuel, compression and a spark at the right time and ANY fucking engine will
    start.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 11, 2010
  4. The Older Gentleman
    Beav Guest
    My thinking is pretty easy to fathom on this dodgy subject. If what you do
    is easy and does no harm, then do it. If it's not necessary you won't ever
    know and if it *is* necessary, you still won't know, coz the bikes will
    crank like they usually do.
    Doing *something* is usually better than doing nothing.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 11, 2010
  5. The Older Gentleman
    YTC#1 Guest
    Never had a Duke have you ?
    If it floods, it can be a right bastard (53 feet anyone ?)
    YTC#1, Jan 12, 2010
  6. The Older Gentleman
    crn Guest
    And that (with a subtle difference) is part of the D14 Bantam problem.
    The 25:1 2smoke mix tends to accumulate as oil in the bottom of the
    crankcase. Tickling the carb to get a cold starting mixture aggravates
    this leading to the plug oiling up after a few pokes on the kickstart.
    There is a drain plug in the bottom of the crankcase, the trick is
    to drain the crank and change the plug _at_the_same_time_ which
    gives you a fighting chance of getting the bastard started but
    only if everything else is perfect. Any 2smoke which has been left
    standing tends to also have evaporated the petrol in the float
    bowl leaving excess oil to block jets and bugger up the mixture
    which also does not help.
    crn, Jan 12, 2010
  7. The Older Gentleman
    Beav Guest
    No, but then again....maybe I should've been more precise. "The correct
    amount of fuel".
    "If it floods" means that there's too much fuel.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 12, 2010
  8. The Older Gentleman
    YTC#1 Guest
    Really ? Does it ?
    YTC#1, Jan 12, 2010
  9. The Older Gentleman
    frag Guest
    There's too much liquid.
    frag, Jan 12, 2010
  10. The Older Gentleman
    YTC#1 Guest
    Gas surely
    YTC#1, Jan 12, 2010
  11. The Older Gentleman
    frag Guest
    <talking in general>
    If there were too much gas that would just be an atmosphere.
    A flood of anything kinda implies liquid.
    frag, Jan 13, 2010
  12. The Older Gentleman
    Beav Guest
    At least YOU know it does. Explain to crn how that works will you?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 15, 2010
  13. The Older Gentleman
    Beav Guest
    Gas IS a liquid, surely?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 15, 2010
  14. The Older Gentleman
    No. Both liquids and gases may be described as 'fluid' though.
    Ace, Jan 15, 2010
  15. The Older Gentleman
    frag Guest
    Not at the same time :p
    frag, Jan 15, 2010
  16. The Older Gentleman
    crn Guest
    I bloody well KNOW how it works.
    And with 2 strokes it is not that simple.
    crn, Jan 15, 2010
  17. The Older Gentleman
    "LPG"
    darsy, Jan 15, 2010
  18. The Older Gentleman
    L=liquefied not liquid
    same root as "frozen water" or "melted fat"
    wessie, Jan 15, 2010
  19. The Older Gentleman
    Beav Guest
    Yeah it is.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 15, 2010
  20. The Older Gentleman
    crn Guest
    I have already explained the difference - but for those who missed it :
    Oil separates out from fuel mix under compression in the crankcase.
    Early 2 strokes which use a 20:1 or 25:1 mix are prone to this.
    If engine does not fire within a few kicks said oil gets thrown up
    onto the sparkplug. The 4 stroke cure of closing the choke and
    cranking with wide open throttle does not help,it just makes matters
    worse.
    crn, Jan 15, 2010
