How should I blow up a motorbike?
Discussion in 'Australian Motorcycles' started by Doctor Shifty, Oct 8, 2008.
  1. Doctor Shifty
    bill_h Guest
    I know of a Landrover tank that went boom when a rust hole was being
    welded (1). The tank had been washed, but not well enought apparently.
    So there was heat and sparks, but no pressure. The critical issue
    would be having the right vapour/ air mix. A bit like one of the
    Mythbuster experiments with methane, they finally got a dunny to
    explode but only after much experiimentation with the fuel/ air mix.
    cheers, Bill
    (1) One of the guys working on the tank was quite lucky, a bit of
    shrapnel grazed his neck, could have been a much worse outcome.
    bill_h, Oct 10, 2008
    #61
  2. Doctor Shifty
    Nev.. Guest
    A stones bomb is an explosion in the same sense that pressing the nozzle
    on an aerosol can and lighting it is an explosion.
    Nev..
    '07 XB12X
    Nev.., Oct 10, 2008
    #62
  3. Doctor Shifty
    Peter Wyzl Guest
    Coffee anyone?
    Lets take the berries off that tree, soak them in water till they go rotten
    then scrape the flesh off, dry the seeds and cook them over a fire till they
    turn brown, then grind that into a fine powder and run water through the
    powder and drink the water....
    P
    Peter Wyzl, Oct 10, 2008
    #63
  4. Doctor Shifty
    bill_h Guest
    ? Wasn't there at the time, but saw the aftermath of a Series III
    Landrover tank that was being welded (at Weipa). I recall being told
    of the tank going 'boom'. One of the guys working on the tank (a work
    mate) was lucky not to be seriously injured.
    Bill
    #64
  5. Doctor Shifty
    GB Guest
    Yeah, and it's multiplied. The place where they actually make
    the pies is on the corner of Harris and <mumble> opposite the
    entrance to the Powerhouse Museum, they have a store there, and
    there's another CdW shoehorned in around the back of the Capitol
    Theatre, right next to the tram tracks. I vaguely remember seeing
    another pop up somewhere else recently, but I can't remember where.
    On google maps/streetview:
    <http://tinyurl.com/3jvua8>
    <http://tinyurl.com/4cysxo> <-- that curved bit of roof behind the pub
    GB
    GB, Oct 10, 2008
    #65
  6. Doctor Shifty
    GB Guest
    <involuntary pucker>! Yeah, and those bastards hurt like **** and
    take a month to heal!
    GB
    GB, Oct 10, 2008
    #66
  7. There is a slight difference between a bang and a whoof,
    explosives, electrical mishaps and lightning go bang, or crack,
    petrol goes whoof or boom,
    I guess that it would be hard for the normal person not to say
    "the petrol tank went up with a bang", when it is a gradual explosion
    unlike explosives set off with a detonator, which is instantaneous.
    George W Frost, Oct 10, 2008
    #67
  8. Doctor Shifty
    Toosmoky Guest
    In such a case, there's a direct spark applied to a tank containing a
    fuel vapour and air mix in a fairly volatile ratio. Hence the
    oft-repeated advice to fill tanks with water prior to welding them.
    Vehicle fires don't replicate these conditions. Fuel vapour to air
    ratios in a tank containing liquid petrol are too rich to support
    combustion.
    Toosmoky, Oct 11, 2008
    #68
  9. Doctor Shifty
    Toosmoky Guest
    Our local rag tends to incorrectly apply the term explosion to anything
    that burns.
    Once they even claimed a car exploded twice... al-Qaeda would love to be
    able to do that trick...
    It's a shame to see cars burnt out because a fire that could have been
    put out with a hose in its early stages has been left to burn because
    the onlookers are taking cover from the "inevitable" explosion that
    they've seen so many times on TV.
    #69
  10. Doctor Shifty
    Boxer Guest
    I was near an expolsion caused by a bank of 12 volt batterys in the mid
    1970's, a soldier in the back of a APC shorted out the teminal with a
    wedding ring and the bank exploded killing him.
    Boxer
    Boxer, Oct 11, 2008
    #70
  11. And deposited him all over the walls ?
    George W Frost, Oct 11, 2008
    #71
  12. Doctor Shifty
    Diogenes Guest
    Weirdo... :)
    Onya bike...
    Gerry
    Diogenes, Oct 11, 2008
    #72
  13. Doctor Shifty
    Diogenes Guest
    Ingest enough eccies and all cane toads are sweet...
    Onya bike...
    Gerry
    #73
  14. Doctor Shifty
    Diogenes Guest
    Yep.... Been there, done that...
    Back to the subject de jour...
    And a bit of a war story...
    1968 - Nui Dat, Vietnam. Our platoon sergeant, an absolutely despised
    man, decided that the grass was growing too high in between the coils
    of barbed wire forming our perimiter. He came up with the brilliant
    idea of spraying the grass with petrol using a knapsack sprayer. So
    far so good... But did he get well clear and get someone else to
    throw the match? No, sir...
    Being a bit safety conscious, he took the knapsack off and put it down
    a few meters away and went back to light the grass...
    The grass went WOOSH... and so did the sergeant... He forgot that
    his clothes were saturated with petrol fumes...unfortunately some
    quick-acting do-goodder put him out and called the medics...
    Oh, and the knapsack? Well, the sergeant had put it down DOWNWIND
    from the sprayed section... The fumes had spread... It became one with
    the fireball, producing a VERY nice flare for a brief while...
    I think it was probably about this time that the ever-present Viet
    Cong got the idea that they could win this war...
    Post Script: The sergeant's burns healed and he returend to duty.
    There was a fragging later that year and a lieutenant got killed.
    Rumour has it that the grenade was meant for the the sergeant.
    War is hell.
    Think twice before you start another one...
    Onya bike...
    Gerry
    #74
  15. Doctor Shifty
    Boxer Guest
    Had a troop Sergent like that in the Cav, he was my APC commander and he
    used to hit me on the head with the barrel of the 50 when he wanted my
    attention, he was an ex-grunt and none too bright as we had a good intercom
    system. One day he forgot to duck as I drove under a low branch. A sad day
    really!
    Boxer
    Boxer, Oct 11, 2008
    #75
  16. Doctor Shifty
    Diogenes Guest
    I can relate to that...
    You've rminded me of the dreaded red ants...
    Onya bike...
    Gerry
    #76
  17. Doctor Shifty
    bill_h Guest
    Sounds fair.
    bill_h, Oct 11, 2008
    #77
  18. Or worse ...
    Lets forget about taking the berries off the tree. Why don't we wait
    until that cat-looking animal eats them, then we will collect the
    berries from the cat shit. Then we continue with the roasting, grinding etc.
    Kim
    Doctor Shifty, Oct 12, 2008
    #78
  19. Doctor Shifty
    Yep; that civet-coffee thing is way beyond any line I'd draw.
    I don't consume things that other mammals have shit out!
    Knobdoodle, Oct 12, 2008
    #79
  20. Congratulations everybody. This is the only place in the world that I
    can think of where a question about burning out a motorbike gets into
    recipes for cooking cane toads. Fantastic. :)
    #80
