How much gear do I need?
Discussion in 'Bay Area Bikers' started by Lawrence Frelot, Sep 21, 2004.
  1. Lawrence Frelot
    notbob Guest
    If you get "squashed like a bug", all the protective gear in the world will
    be of no use. Better off avoiding the "bug" scenario.
    nb
    notbob, Sep 25, 2004
  2. Lawrence Frelot
    KS Guest
    I had a feeling that was "coming."
    Khaled
    KS, Sep 25, 2004
  3. Lawrence Frelot
    H Pine Guest
    You're getting a lot of good advice here, but there's a lot more info needed
    before you should select your gear. Other factors to consider before
    choosing your gear are the length of the rides you're planning, minimum and
    max temperatures in your area, and whether or not you plan on riding in the
    rain, or when there's a chance of rain. If temps get very high (over 90), or
    very low( below 50), you'll need additional gear to what you might wear most
    of the time.There's no such thing as being " a little bit cold". Touring
    gear is different from commuting gear. A lot of modern riding suits have zip
    in Gore-tex liners that can keep you bone dry in the rain, and do a great
    job of cutting wind and cold . With liners out they'll serve you well in
    temps up to about 85. Best advice is to do your homework, and buy good
    quality and proper function the first time, rather than going half way. Even
    cheap gear isnt all that cheap, especially if you have to go right back out
    and replace it........Howard
    H Pine, Oct 4, 2004
