How hard could it be to change a trye
Discussion in 'UK Motorcycles' started by AndyH, Nov 24, 2003.
  1. AndyH
    AndyH Guest
    Impossible is the answer.
    I tried all Saturday to find a garage (bike or other) that could swap
    the front tyre on the GSX. Two said they would do it, but then said
    they didn't have the time when I turned up. Looks like I'll have too
    book it in a weeks in advance.
    I blame the good weather, too many fair weather riders still keeping
    their bikes running.
    Still the weather looks like its turned, set off down the road this
    morning, little too much fist in 2nd and the rear was all over the
    place <fx:big cheesy grin>.
    AndyH, Nov 24, 2003
  2. Veggie Meldrew, Nov 24, 2003
  3. AndyH
    Tim Guest
    Maybe a friendly "fat bastid" as well, you never know when one comes in
    handy?
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm at dsl dot pipex dot com
    Tim, Nov 24, 2003
  4. Veggie Meldrew, Nov 24, 2003
  5. AndyH
    Tim Guest
    I are not fat, thank you :)
    Tim, Nov 24, 2003
  6. AndyH
    Petel Guest
    IF you really want to save the tyre then two bits of wood and a big G-clamp
    make a good bead breaker.
    If it`s shagged... angle-grind the fecker down to NEAR the rim.
    It makes it easier to break the bead.
    Fitting....do all the right things..I.E yellow mark next to the
    valve,rotation checked etc.
    Compressor up to 40psi (no more) get the tyre on (furniture polish and fat
    bastard) get someone to sit on it when it`s on the wheel (fat bastard again
    ;-) and Whoosh inflate.
    Axle thro` and sit and spin.....marking the low spot with chalk.
    Add a few twists of solder around the spoke opposite or double-sided tape
    and a slice of roofing lead if it`s a new fangled non-spoked wheel.;-)
    Petel .
    02 M2 Buell.
    C90-ZZR.
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Nov 24, 2003
  7. AndyH
    Vince Guest
    Everything went ok then? [1]
    Lemme know how you get on with the tyre. If the mileage isn't up to
    expectations, mebbe the 'road' version is worth a pop.
    [1] I admire a man who can *really* do it himself.
    Vince.
    ZX9R, CBR250
    Ex-SKoGA#3, YTC#13
    BONY#47, SBS#22, BOTAFOF#26, BOTAFOT#102, MRO#23.
    MIRTTH#19
    "Vince: more repulsive than Ginge"
    Vince, Nov 25, 2003
  8. AndyH
    curium Guest
    do you bother with balancing?
    curium, Nov 25, 2003
  9. AndyH
    curium said....
    I've never seen any tyre fitter do it when standing on one leg
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Lozzo, Nov 25, 2003
  10. AndyH
    AndyH Guest
    <snip>
    All the garages will do the easy bit of changing the tyre, its taking
    the wheel off the bike the can't do.
    Friday night I will be mostly rigging up some contraption, to hold the
    GSX1100F's front off the ground [1], so I can take the wheel in on
    Saturday.
    [1] Its one heavy bike, even the heavy duty rear paddock stand I
    bought bends under its weight.
    AndyH, Nov 25, 2003
  11. AndyH
    Petel Guest
    Vince.....Yep, no problems.
    AndyH try a scissor jack under the engine, I normally use a 4 ton trolley
    jack.
    If there`s not enough room to get a jack under (maybe the exhausts get in
    the way) use a strong plank and slide it between the exhausts and under the
    engine, a couple of bricks under one side of the plank and the jack under
    the other, then lift the whole lot to give enough clearance to remove the
    wheel.
    Worked on my 220kg Marauder.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Petel, Nov 25, 2003
  12. AndyH
    Tried a beer crate? If it's too big just rock the bike on it's side
    stand while you slide the crate under the engine/frame downtubes.
    Or don't you get beer crates in UK supermarkets? No, they're not so
    common there, I forgot.
    Ace, Nov 25, 2003
