how does a tachomter work?
Discussion in 'Australian Motorcycles' started by paulc, Jul 24, 2003.
  1. paulc
    kreatikl Guest
    to my knowledge...
    either
    the cable drives a magnet
    the magnet induces a current in a coil
    the current operates the speedo needle
    the needle deflections is proportional with the speed
    or
    it is digital and picks up pulses from a toothed somethink
    the faster, the more pulses
    the pulses are counted
    the number of pulses is proportional to the speed (more accurate than the
    above)
    kreatikl, Jul 24, 2003
  2. paulc
    paulc Guest
    It cranks over nice and fast. Never had any sort of problem starting.
    If it was a loose wire, I would have expected the needle to drop to zero.
    It actually goes off the scale at the other end (past the redline).
    paulc, Jul 25, 2003
  3. paulc
    paulc Guest
    If it is electronic, and it is jumping to double revs, I would suspect a
    The bike appears to be running fine. I can't notice any difference in the
    engine when the tacho problem shows itself. It doesn't appear to change
    when stopped in traffic, so I wouldn't have thought it was an overheating
    problem. It's a naked bike, so airflow shouldn't be a problem. (Being
    winter, I can definately attest to that!)
    Will do.
    I don't have one, but I might try and track down a friend that does.
    Thanks for that information. It sounds very promissing. The fact that it
    doubles the revs makes me think you may be onto something.
    Paul.
    paulc, Jul 25, 2003
  4. On Thu, 24 Jul 2003 14:12:10 UTC, "Knobdoodle"
    } They're simpler than that.
    } The "cable drives a magnet" ones have a simple magnetic-couple (Two
    } magnets in close proximity; when one spins the other one wants to too)
    } driving a needle on a coil-spring.
    Two magnets would couple way too strongly. It's just one magnet
    rotating
    inside a ferro-magnetic can. The can gets 'pulled along' by the
    rotating
    magnet, until the pulling force balances that of a coil-spring. The
    magnetic force on the can is linear with the magnetic flux change, and
    hence with the magnet's revs.
    // Rik Steenwinkel '85 R80ST Skippy bike
    // Enschede '91 R100GS/PD The Great Unwashed
    // Netherlands ('76 Honda CB250G Bouwpakketje)
    // "Far away is only far away '90 K75C Kommutabike
    // if you don't go there" '81 MZ TS250/1+LSW Badkuip
    Rik Steenwinkel, Jul 27, 2003
  5. paulc
    Justin Guest
    I read somewhere that speedo's and tacho's use 'stepper' motors.
    i.e. electric motors that dont rotate fully when current is supplied, rather
    they can move to a set position depending on the current.
    Could be a load of bollocks, I suppose, too.
    Yours in good faith,
    Justin
    Justin, Jul 28, 2003
  6. paulc
    Theo Bekkers Guest
    "Justin" wrote
    My experience with stepper motors is that they, well... step. i.e. rotate
    part of a revolution each time a pulse is applied. Not hold their position
    or move to a set position.
    Theo
    Theo Bekkers, Jul 28, 2003
  7. By measuring tachyons.
    I think I saw it on Star Trek or something...
    Postman Pat
    Pat Heslewood, Jul 28, 2003
  8. Maybe IntactKneeslider has one in the lab that you could play
    with?
    big
    Iain Chalmers, Jul 29, 2003
