how does a tachomter work?
Discussion in 'Australian Motorcycles' started by paulc, Jul 24, 2003.
  1. paulc
    paulc Guest
    Hi all.
    I'd be intersted to know how an analog tachomoter typically works on a
    motorcycle? The one on my Spada intermittantly seems to either display
    approx. double the revs that it's doing, or drop off the dial completely.
    In order to track down the source of the problem, it lead me to wondering
    how the bugger works.
    Thanks,
    Paul C - Honda Spada.
    paulc, Jul 24, 2003
  2. In aus.motorcycles on Thu, 24 Jul 2003 11:59:00 +1000
    cable driven? Cam (usually) rotates, gears rotate cable, cable rotates
    gears inside tacho, gears inside tacho move dial pointer.
    electronic? On mine, coils fire, send signal to tacho, electronics
    drive little motor that moves dial pointer.
    Zebee
    Zebee Johnstone, Jul 24, 2003
  3. paulc
    Fred Kroft Guest
    is it digitally controlled ?, or is there is torque cable going into the back
    of it ?
    digitally controlled, there would be lots of ways. i've never pulled one
    of these part to know.
    torque controlled operates by a magnetic clutch. the torque cable turns a
    little fly wheel with magnets on it. within the fly wheel is another
    smaller wheel also with magnets on it.. but is spring loaded. when fly wheel
    turns, it induces smaller wheel to turn as well, but as it's spring
    loaded it resists being turned.. at a given speed the small wheel is wound
    round at different amounts... hence the needle action you see.
    well, that's how the leyland mini speedo's and tacho's are designed !
    (which i used to pull apart when i was about 5-6 years old -- dad would
    bring them home for me to pull apart ;).
    -f
    Fred Kroft, Jul 24, 2003
  4. http://www.classictiger.com/techtips/motach.html
    The Spada one will be something pretty similar to that...
    big
    Iain Chalmers, Jul 24, 2003
  5. paulc
    Mike Doyle Guest
    I had a similar problem with my Spada. It ended up being battery
    problems. It took a while, but in the end the following electrics were
    bad (and the combination caused that prob, as well as many others).
    - Not earthing currectly.
    - Battery not recharging - due to bad earth (ended up putting earth
    straight to neg on bat)
    - Bat buggered (after months and months of manual recharging)
    - possible problems with alternator (or whatever it is called on the bike)
    - some bad wiring.
    so though I know nothing about how it works...I know it went wrong for me.
    Mike
    Mike Doyle, Jul 24, 2003
  6. paulc
    Mike.S Guest
    Actually the main reason for the "little dance" is so that the controller for the stepper motor can
    "zero" itself, and so it knows it's range.
    i.e. depending on circumstance the number of "steps" the motor may have to take today to get
    to the end of its range[1] may be 320 steps today, but tomorrow due to temp differences and sheer
    dumb luck it could be 318 or even 322 steps
    Think about the old bubblejet and even dot matrix printers, they do the little "zoom zoom" to the end
    and back whenever turned on/reset, and even sometimes halfway through printing a page may decide
    to re-centre themselves in case they start loosing track of where they are. This is exactly the same little
    dance as when you first turn on a bike with a stepper motor powered tacho or speedo.
    [1] This is actuated by a microswitch that is at the end of the range, giving "feedback" i guess you
    could say as to the number of steps until the motor hits the end limit.
    Mike.S
    Mike.S, Jul 24, 2003
  7. I actually did know that, but its a little hard to turn into a cutting remark...
    It _is_ still Harsh Week, remember???
    Spectacularly unlikely - it'll use current sensing on the stepper motor drive -
    why waste money on something mechanical like that when you can do it in the
    sofyware?
    big
  8. paulc
    Gavern Guest
    Is *intermittently* meaning regularly like clockwork ('scuse the pun) and at
    certain intervals or just sporadically at odd times..??
    I know nothing of the Spada's electrics, but my YZF1000 does that to alert
    you of other electrical problems such as running to certain RPM (3k, 5k and
    8k iirc) when there is problems with the throttle position sensor, EXUP
    powervalve etc...
    Say I am riding @ 4000rpm, the tacho shows this for 3sec then drops down to
    3000rpm for 2 sec and then to 0rpm for 3 sec and then back to 4000rpm in a
    continuous cycle until I adjust the TPS...
    Anyway, is a thought just in case......
    Cheers,
    Gavern
    Gavern, Jul 24, 2003
  9. Yes.
    **** Off Spammer Bitch!!
    big (day 31 of Harsh Week...)
  10. paulc
    paulc Guest
    Interesting. I have noticed that after starting, the lights get brighter
    when revving the engine. The starter seems to spin plenty fast enough - so
    I haven't bothered about it.
    paulc, Jul 24, 2003
  11. paulc
    paulc Guest
    I had a quick squiz at it during lunch. There doesn't seem to be cable
    going into the back (but there is for the speedo).
    paulc, Jul 24, 2003
  12. paulc
    paulc Guest
    Thanks.
    I'll have a read through that tonight. I may get brave, and attack it with
    a screw driver - see what's inside.
    paulc, Jul 24, 2003
  13. Word of advice - you're going to need to take the headlight out of its housing
    to get to all the wiring so you can unplug the instrument cluster - take a good
    long look at how it all fits in - it can be a bugger to get the headlight back
    in if you've got the plugs and wiring sitting in the wrong spot...
    big
  14. paulc
    paulc Guest
    Nope. Sometimes it doesn't work for an entire day. Sometimes it starts off
    working, then jumps to approx double the revs. It will even change while
    cruising along at constant speed on the freeway.
    paulc, Jul 24, 2003
  15. Are there any weather proof seals that I would need to especially carefull
    of ?
    [/QUOTE]
    Nope... its just the jigsaw of knowing which plug needs to sit where, and which
    bit of wiring harness needs to bend which way...
    big
  16. paulc
    That sounds awfully like a broken/loose electrical connection. Unless you
    *really* feel like pulling your tacho apart I'd start the bike and jiggle
    all the bits of the wiring harness you can reach, to see if you can induce
    it to start/stop working. If you can, narrow it down from there.
    Does it crank over well? If it seems to be labouring then start off by
    cleaning the connections to your battery.
    Best of luck!
    BT Humble, Jul 24, 2003
  17. paulc
    Moike Guest
    Hi Paul,
    If it is electronic, and it is jumping to double revs, I would suspect a
    problem with the electronic ignition (assuming you have one). The tach
    drive should be a wire taking pulses from the input side of the coil. the
    Tacho counts these (using one of a number of techniques).
    I had some problems a couple of years ago where the tacho would jump to read
    double revs for a while then the motor would lose power. Turned out in my
    case to be an air leak in a carby that was making the engine overheat. This
    caused the electronic ignition unit (or the sender unit - never found out
    which) to get too hot and it started 'stuttering'. Initially it would put
    out double sparks, which didn't affect the motor much, just wasted a few
    electrons. When it got really hot, the spark became eratic and I lost
    power. Removing a fairing section fixed it temporarily. Getting the carbs
    fixed fixed it permanently.
    In your case it may not be a carby problem, but I'd have a look at the
    electronic ignition module, check the airflow to its heat sink and make sure
    it isn't getting too hot. Also check for loose electrical connections.
    Other than that I have no idea what diagnostics or remedies might be
    applied.
    If you have an automotive multimeter that has a tacho setting, you might
    take it with you (even gaffer tape it to the 'bars). If both your tacho and
    the multimeter show the same behaviour, then the problem is not inside the
    tacho (otherwise it probably is).
    I wouldn't be exploring inside the tacho until I was pretty sure it was
    defective. There are some delicate bits in there, and exploratory
    dismantling could be disruptive.
    Hope this helps.
    Mike
    Moike, Jul 24, 2003
  18. paulc
    What happens when you cut the ignition on a "stepper" tacho?
    Do they zero or stay where they were?
    (I was on my third XJ900, a total of about 6 years and 150,000 km ownership, before I noticed it had no
    tacho-cable......)
    Knobdoodle, Jul 24, 2003
  19. paulc
    I can understand you being a bit "edgy" after months and months of "manual recharging" but you really should
    leave the native fauna alone!!
    (Get yourself a booth!)
  20. paulc
    Mike.S Guest
    This i do not know, perhaps the tacho has a light spring that can zero it back?
    Printers use "worm drives" so they stay where they are, tacho's i imagine use direct drive,
    so i can safely say "fucknose".
    Mike.S
